Sony KDL-40W2000 3 LED Blnks Error
  • Mikes043
    replied
    Re: Sony KDL-40W2000 3 LED Blnks Error
    Originally posted by dick_barton
    So you have all the supply voltages. 3.3V, 10.5V, 15V and 18V
    I am going to check that !
    in thought just measure 18v and if it was the specified voltage @ 1 terminal In de connector.
    the rest would be good also
  • dick_barton
    replied
  • Mikes043
    replied
    Hello , In the first place I have to thank all the people for sharing their knowledge on the subject.
    I have the same problem as the OP.
    I did the the voltage check by doing the Resistors trick
    I used 470 ohm resistors from standby 3.3 to POWER_ON and RLY_ON
    I put the 2 resistors on the single standby connector
    than I measured n CN6202 18v to ground and that works.
    Can someone tell me how to proceed ?
    replied
    Originally posted by StephenU
    Hi all just like to thank everyone for their input and help getting this tv back up and running, replaced the Mainboard and all works fine now. I matched my replacement board up with my panel # LTY400HS-LH3.
    Thanks for the follow-up, too bad the thread got this long due to wasted time on the power supply board, especially the IC6100.
    replied
    Another save, well done.
  • StephenU
    replied
    replied
    You need another resistor for the RLY_ON (Relay On), pin 5 (CN6200) to pin 4 (CN6202) with another 470 Ohm resistor.
    Yes, you will be taking the Voltage measurement of the power supply connector since there will be no connection to the main board, we are doing the test to find out if the power supply board is OK or not.
  • StephenU
    replied
    Re: Sony KDL-40W2000 3 LED Blinks Error
    Originally posted by budm
    So what happen if you run the power supply board by itself and do the force on using 300 ~ 470 Ohms resistors between 3.3V and the POWER ON, and RLY_ON?
    Do you get all the Voltage outputs as shown in the diagram?
    Hi Budm, I have ordered a replacement Mainboard. Although I can try out these measurements over the weekend, can I take the measurements direct from the CN6200 pins 1, 2, 7, 8, 11, 13, 14 or locate the points you have highlighted on the Schematics? I've attached a pic to illustrate my connections between CN6202 pin 2 and CN6200 pin 5.
    Thanks for your help Budm
    S.
    replied
    replied
    Ok, I see 2 type boards on there, make sure you match the panel # LTY400HS-LH3 and you should be alright.
  • StephenU
    replied
    Usually need to match up the top letter/numbers on the white sticker of your mainboard, what is your panel number?
    Look for A-1196-582-G, on sticker of your board and the replacement board.
    This MIGHT work I see the very last letter is different F vs G, don't know how knowledgeable the seller is but you could contact m and ask if they know weather it will work or not, panel number matches: https://www.ebay.co.uk/itm/MAIN-BOAR...4AAOSwUv9c0UnY
    Thanks for this I will update Post in due course.
    S.
    replied
    F and G may be some kind of Country code, not sure, F may be the correct one for your Country.
    replied
    replied
    Look for A-1196-582-G, on sticker of your board and the replacement board, this is one I see here in U.S.
  • StephenU
    replied
    The Panel is LTY400HS-LH3
    replied
  • StephenU
    replied
    Seems like we were thinking mainboard about 25 posts ago, this IS a good example of the (blink code) sometimes known as the (dummy code) being wrong, which I found out on many occasions the hard way, then we were taken on a fantasy journey involving IC6100, so looks like it's the mainboard at fault, hmm that sound familiar: https://www.ebay.co.uk/sch/i.html?_f...0W2000&_sop=15
    diah was right about:
    "wrong 3 error blink very wide at Sony platform" but then he went down some fantasy trail which led to nowhere.
    Seems like its the main board will get one ordered and see how things go. Thanks for your input nomoresonys.
    Do all part numbers of this need to match up or is it the Panel number that would determine this, I see 2 types of panel for this Model LTY400 and LTZ400.
    S.
    replied
    replied
  • StephenU
    replied
    Originally posted by Brucetafer
    OK, I just dealt with this myself the SONY 3 blink power supply IMMEDIATELY goes into safe mode when the main board is bad. I think he's having issues exactly the same reason I did. the big click then click and 3 blinks, its sending the power supply into safe mode and shutting it down.. when you unplug the power supply from the main board it does NOT turn on anything like most boards.. I was going crazy over this for almost a week..
    Exact issue I am having Brucetafer, was your model the same as the one I have?
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • jchon
    Sony A1e 5-blinks help
    by jchon
    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
    I found the service manual, which was critical to know where to probe.
    https://www.manualslib.com/manual/20...1e-Series.html
    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
    Unfortunately the 5-blinks...
    06-28-2023, 11:52 AM
  • Nicktronic
    Sony XBR-65X850D 2 Red Blinks
    by Nicktronic
    I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
    Any Sony experts out there that can help??...
    11-19-2023, 06:51 AM
  • dumbdd
    Sony 75X9400E TV.. 5 Red blinks
    by dumbdd
    I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
    When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
    The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
    07-01-2023, 08:54 PM
  • Nicktronic
    Sony XR-55X90J 4 blinks
    by Nicktronic
    Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
    Thanks!...
    02-13-2024, 07:01 PM
