Vizio M370NV Powers on for 2 seconds then shuts down
    Re: Vizio M370NV Powers on for 2 seconds then shuts down
    Originally posted by R_J
    The mainboard is telling the power supply to do what it should, turn on and then turn on the backlights. Since there is no backlight error signal etc. from the power supply back to the main, the main has no idea if the backlight is on or off and really does'nt care.
    Thats why I suspect the main board, and it could be an eeprom issue or I suspect it is more likley a bga problem on the large chip.
    +1.
    This TV does not use Backlights error signal to feed it back to the main board to tell the status of the Backlights, beside when you perform backlights forced on test, the local protection is still present so if there is issue with the Backlights, I.E. open circuit or over current condition, the local protection in the Backlights circuit in the power supply board would have kick in and shutdown the backlights, but you are not seeing that, correct? That is my theory. Taking the panel apart will be the last thing I will do.
    You make the decision on what you want to do, you can also contact shopjimmy to see what they suggest.
    BTW, what happen if you disconnect the T-CON, does it go into shutdown?
    • MisterD
      • Oct 2012
      • 668
      Originally posted by budm
      +1.
      The Backlights do stay on when I perform forced on test, I only left them on about 5 to 10 mins maximum...I don't see a T-Con board and none listed on Shopjimmy or ebay for this Vizio Model M370NV
        It looks like it has integrated T-CON.
        • MisterD
          • Oct 2012
          • 668
          Is that integrated in with the Panel? if so should I remove the 2 flat ribbon cables coming out of the Main board and power on the tv to see what happens?
          • MisterD
            • Oct 2012
            • 668
            I unplugged both flat ribbon cables that come out of the main board to the panel, still had backlights without the vizio logo on screen of course no video with them unplugged...tv powered off within 2 to 3 seconds just as before.
            • MisterD
              • Oct 2012
              • 668
              +1.
              Shopjimmy is Not offering any Technical Assistance and they do not plan on doing so in the future.also I tried to get a discount from them since they have 9 of these Main Boards( Vizio 3637-0582-0395) in stock, but got turned down for that too.
              • Diah
                • Feb 2013
                • 6602
                man if you with this waiting time took the screen apart then you are now watching TV with it. LOL
                • MisterD
                  • Oct 2012
                  • 668
                  Read all of Post #41
                  • Diah
                    • Feb 2013
                    • 6602
                    up to you and the poster..LOL
                    • R_J
                      • Jun 2012
                      • 9624
                      OK genius, How do you explain the FACT that when the power supply is operated without the main board the backlights work perfect?
                      • Diah
                        • Feb 2013
                        • 6602
                        don't try to touch my personally
                        answer to geniuses questioner ...
                        EDGE LED are different from Direct LED... his LED EDGE you want to know more ask i will answer you how they are different
                        • R_J
                          • Jun 2012
                          • 9624
                          Explain it to the op
                          • Diah
                            • Feb 2013
                            • 6602
                            LOL then wait and we will hear soon
                            • nomoresonys
                              • 12331
                              • U.S.
                              #54
                              Bigger pleeez I'm finding it hard to read.
                              • Diah
                                • Feb 2013
                                • 6602
                                hahaha nomoresonys
                                now i do know why you are suggest always heating PSU LOL... take it easy.. we are all Zero but still friends over here
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #56
                                  hahaha nomoresonys
                                  It's a good legit test, REALLY SURPRISED that you can't grasp it. You being a GENIUS and all, FURTHER is that why you have everyone who will fall for it, tearing their tv apart just to look at the backlights before the simple backlight voltage test??? You have been wrong many times and so have I BUT I don't claim to be the GENIUS that you claim to be. Last time you were wrong was yesterday NO WAIT it was today.
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #57
                                    Here's an example diah, YOU didn't even know this BASIC FACT, you were rambling on about something BUT you were WRONG AGAIN, personally I just assume that you are always smoking something, yippppeee every day is 420 day. You do know some things, not as much as you THINK you do tho, and as a lot of us regulars can attest to...as a teacher or even being able to describe something you get straight F'S FOR FAILURE.: https://www.badcaps.net/forum/showth...ht=purple+leds
                                      Any follow-up on this?
                                      • Diah
                                        • Feb 2013
                                        • 6602
                                        sure...
                                        in energy saving platform, we find TV with direct LED are in level B or A
                                        TVs with edge LED most of them on level A+ and some A++
                                        so here we are knows the infrastructure of the PSU on edge are different from Direct LED. however we can find the a mounts of LEDs on both are same. or very near to be same amount. but the edge design have power saving more than direct one. using booster of currents and less mount of LEDs on one line play here the roll. this also can be effected on the design of protection mode at HW level and SW level,
                                        again with edge one if we see light of leds on behind the LCD,, doesn't mean we have healthy all line or groups. also if currents go high by shorting one SMT LED some time HW protecting circuit failed to discover or turn whole out.. same case if we force PSU to turn on with out MB action as it play SW protection which never failed.
                                          https://www.shopjimmy.com/vizio-0500...upply-unit.htm
                                          1) This power supply has no feedback signal to tell the Main board the status for the LEDs/LED driver circuit. So How would SW protection being applied in this case?
                                          2) LED's are driven by constant current power supply, if some of the LED's are shorted out, the CC will still be forcing the same constant current, the effect will be that the PWM controlled MOSFET will be dissipating more power dues to more Vdrops to compensate the shorted out LED. You know how constant current power supply works, right?
                                          3) Where are the reference to these: in energy saving platform, we find TV with direct LED are in level B or A. TVs with edge LED most of them on level A+ and some A++.
                                          4) "so here we are knows the infrastructure of the PSU on edge are different from Direct LED. however we can find the a mounts of LEDs on both are same. or very near to be same amount. but the edge design have power saving more than direct one. using booster of currents and less mount of LEDs on one line play here the roll." LOL.
                                          Bottom line, I will not waste any more time on this.
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
                                          • survivalbloke
                                            Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                                            by survivalbloke
                                            I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                                            Any ideas?
                                            01-08-2024, 12:12 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
                                          • tec3000
                                            Sony LED 65X9005A shuts down after few seconds - looking for help
                                            by tec3000
                                            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                            03-20-2024, 07:29 AM
