kdl70w830b main board 3 blinks
  • Brucetafer
    • Jun 2018
    • 133
    hey guys, florida did it again, and killed my 70 inch bravia tv.. its blinking 3 times, I already had another brand new power board from sony as we thought it was the issue.. 3 blinks says power board or main board, and i see some rain bowing coloration by the main chipset on the main board and its greasy for some reason.. anybody have any ideas on these big bad boys? ill get pictures as soon as you ask for them.
    there is 4 boards, main power, led distribution board, main board and tcon.
  • Brucetafer
    • Jun 2018
    • 133
    Re: kdl70w830b main board 3 blinks
    Update, I was able to verify all the voltages, and I froze the main board for fun, and it turned on for 5 seconds with a spinning loading sign I've never seen before.. then shuts off with a relay click and blinks 3 times..
      • 12187
      • U.S.
      Good pics. of the whole back and close up of each board?
      • Brucetafer
        • Jun 2018
        • 133
        As you can see the horribly reflected picture of the spinning arrows, they spin like its in a restore mode or something.. now when I plug the TV in it does that for 8-12 seconds then click, screen off, and 3 red blinks over and over.
        • R_J
          • 9535
          A 3 blink code does point to main baord as primary suspect, The spinning arrows seems to indicate it's trying to update its firmware, Leave it connected to the internet (over night), or download the firmware to usb stick and try that, If that does'nt work, its likely a fault with the X-Reality chip, maybe poor bga connections?
          The grease on the main board is likely from the thermal pad attached to the rear bracket that covered the main board
          • Brucetafer
            • Jun 2018
            • 133
            Thats what I figured, Im going to try to force update.. that doesn't work then run a lan cable to it and hope for the best.. thanks again!! looks like the 830 840 and 850 main boards work in it so im not stuck with just one board..
            • Brucetafer
              • Jun 2018
              • 133
              No luck at all, board is locked up. Im going to try and pull the 2 big caps and test them and see.. and try to see if there's any blown resistors or caps on the board.. its 100% the main board unfortunately.. 100 bucks on eBay, unless someone else has a hookup..
              • Diah
                • Feb 2013
                • 6371
                failed to load driver... its much like you have AV board issue... disconnect speaker socket from MB and the AV board from MB and then turn it on.
                • Brucetafer
                  • Jun 2018
                  • 133
                  100% correct, I bought a brand new power supply and another board from a 60-850 and uploaded the correct firmware and works, but now the problem is the middle of the screen is dark (see picture) and no idea what could have caused that..
                  • Brucetafer
                    • Jun 2018
                    • 133
                    the outside is clean white 1/4 on each side rest is dark
                    • Diah
                      • Feb 2013
                      • 6371
                      as i know Sony up 60 the LED backlight are edge one. mean its one piece at the bottom of the set. from your photo it look one piece LED failed.
                      • Brucetafer
                        • Jun 2018
                        • 133
                        Shoot... I gotta take it back down then... Ugh!! I have an led tester so that's good . Do you know if the LEDs are power supply driven or main board.. I have another brand new power supply
                        • Diah
                          • Feb 2013
                          • 6371
                          No, all boards PSU or LED driver are okay.. its just one SMT LED ... need to take screen apart to reach the LED back light... tester will not work unless to test each LED stand alone
                          • Brucetafer
                            • Jun 2018
                            • 133
                            Thank you very much, Ill report back with an update soon, I have to wait for my friend to take it off the wall as its freaking heavy!!! and 6 feet in the air..
                            • Brucetafer
                              • Jun 2018
                              • 133
                              Ok, theres a driver board, with 4 sets of LEDS. one per corner, and they all match output wise, and manually tested them and they all look good..
                              is there a diffuser that maybe broke or fell when I took it down? or do you know what the output voltages are supposed to be on this unit? im getting 52.2 volts per group and 6.65-6.85 on the test points.
                              Id hate to take the screen off and ruin this gorgeous TV.
                              • Diah
                                • Feb 2013
                                • 6371
                                dfifuser could make effect if they are not tight to the back of screen. but most cases will be effect on the corners of the set ( try massage the LCD gently with dry cloth if the effect will be better )
                                SMT LED are currents not volts. open LED mean it will not lid on but its FW current Ziner Diode in tact and forward currents to next LED.
                                if you hate to to go further. better stay on it as its now but be ready that other LED will die soon or later as they have same age of working hours.
                                play around to adjust backlight level and contrast to have best picture with less darkness.
                                One things more.. i recall before i had scraped KDL 65 size because it had smashed panel. it was edge backlight too. i found the first plate of flex glass reflector made of 2 pieces and glued with fine transparent type . like they use one piece of 55 and add rest of other piece. ... but the place where they glued was on the first third left side not at the middle..
                                • Brucetafer
                                  • Jun 2018
                                  • 133
                                  Exactly what I thought.. I'm stumped man.. I wish I could find a voltage cheat sheet..
                                    Is this your LED driver board?
                                    https://www.shopjimmy.com/sony-49-p2...led-driver.htm
                                    The LED driver IC's are AN37011B?
                                    • Brucetafer
                                      • Jun 2018
                                      • 133
                                      Yes, 8 of them for 4 strips or groups of leds.. the board says 125v max.
                                        Each one of those LED driver IC is 4-CH LED driver (4 string of LED per IC).
                                        AN37011B spec sheet on how it works.
                                        I only see LED 1 ~ 16 on the LED connectors CN1002 ~ 1004 so it may only has 16 strings..
                                        I cannot verify until I can do more research on this TV model.
                                        The Cathode return pin Voltage of the bad LED will not be the same as the good LED string if all the LED strings have the same quantity of LED's.
                                        BTW, where does it indicate 125V max?
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
