kdl70w830b main board 3 blinks
  • Brucetafer
    • Jun 2018
    • 133
    Re: kdl70w830b main board 3 blinks
    Originally posted by budm
    Each one of those LED driver IC is 4-CH LED driver (4 string of LED per IC).
    AN37011B spec sheet on how it works.
    I only see LED 1 ~ 16 on the LED connectors CN1002 ~ 1004 so it may only has 16 strings..
    I cannot verify until I can do more research on this TV model.
    The Cathode return pin Voltage of the bad LED will not be the same as the good LED string if all the LED strings have the same quantity of LED's.
    BTW, where does it indicate 125V max?
    on the driver board lower left hand side. not on the chip.
      F6.3A/125V: That is the fuse Voltage rating, not the Voltage feeding the board. Fuse Voltage rating is typically chosen to be about twice the Voltage requirement of the device.
      • Brucetafer
        • Jun 2018
        • 133
        Ok Ive pulled the panel, verified ALL leds are perfect, the the diffuser was kinda weird, so it may have shifted when hung up or moved.. Ill post up if anything changes..
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
