Lg 37lf2510
  • gemadar
    • Aug 2013
    • 6
    Lg 37lf2510
    Hi, I have an issue with teh TCON board, i have had the AS15 chip replaced, but it still shows the same symptoms, guessing its the fuse, how do I find out what the fuse should be to replace?
    t370hw02 vc v402 37t04-c0m is the tcon board.
    thanks,
    mark.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Lg 37lf2510
    If the fuse has failed there would be no picture.
    The AS15 are sensitive to heat, perhaps when it was fitted there was too much heat.
    There are test points on the TCON that can be measured to confirm its a gamma issue.
    • gemadar
      • Aug 2013
      • 6
      Re: Lg 37lf2510
      ahh ok, thanks for that, as I do have a picture, but it is washed out white, the picture is just about visible though, which is why i suspected the as15 chip, i sent it away to get it reaplced, but it came back the same issue.
      they are having another go with it at the moment, so maybe it is just that and they overheated it maybe????
      thankyou, ill see what happens when it comes back again, if it is still teh same i will post some pictures, to see if anuybody has any ideas?
      thanks,
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Lg 37lf2510
        I know I've had to redo a couple of AS15 and I have one fail due to the lack of the thermal pad.
        It's possible that there is something on the thin board between the TCON and panel that has an issue and is causing the image problem. Check for shorted ceramic capacitors.
        • gemadar
          • Aug 2013
          • 6
          Re: Lg 37lf2510
          ok, board came back, flicked normal for a couple of seconds and then went straight back to a white screen with picture behind.
          checked the fuse, and fuse was fine, board was getting a steady 11.94 volts
          noted voltage on the test points i could find:-
          1-15.18
          2-14.93
          4-12.34
          6-10.71
          8-9.93
          10-8.00
          11-7.76
          12-6.78
          13-7.04
          15-4.85
          17-4.34
          19-2.767
          21-0.535
          22-300mv (basiclaly dont think this read a voltage, but not 100% sure as so low)
          anybody an ideas what could be the issue, or does anyone know a good place to get a replacement board, as ill quite happily get a replacement board if needs be.
          ill post a couple of pictures of board in a sec.
          thanks,
          mark.
          • gemadar
            • Aug 2013
            • 6
            Re: Lg 37lf2510
            pictures of board attached.
            regards,
            mark.
              Re: Lg 37lf2510
              "11-7.76
              12-6.78
              13-7.04"
              That is not right.
              • diif
                • Feb 2014
                • 6978
                • England
                Re: Lg 37lf2510
                Was the thermal pad and shield fitted ?
                Who is it that has done the repair ?
                • gemadar
                  • Aug 2013
                  • 6
                  Re: Lg 37lf2510
                  Budm, yep didn't spot that, any ideas, is this still the chip?
                  Doug, tcon board was sent to have as15 chip replaced,
                  I removed from TV and refitted.
                  Mark.
                  • noledud
                    • Dec 2013
                    • 413
                    • united kingdom
                    Re: Lg 37lf2510
                    I replace the AS15 chips myself but have also used TCON repair services on ebay - not sure if i can post the name but if you search TCON repair you should find it.
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • triplefour
                      Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                      by triplefour
                      Samsung UN55ES7003
                      made house call.
                      red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                      psu has self test feature.
                      disconnected from mainboard.
                      determined PSU ok BL ok.
                      suspect mainboard.
                      disconnecting tcon has no change on operation.
                      markings on mainboard:
                      BN97-06531P 0151
                      BN94-06123R
                      found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                      for 54$
                      second house call:
                      with replacement mainboard, tv turns on, has sound,...
                      07-13-2022, 03:53 PM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • corrize
                      A funny fuse story – Lumix LX100 II
                      by corrize
                      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                      10-19-2023, 09:58 AM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
