Sony KDL-48W605B no picture but sound
  • chrle
    • Sep 2013
    • 158
    • slovakia
    hello guys,
    today I buy Sony KDL-48W605B for repair
    tv turn on ,backlight on but no picture, i click menu sound ok.
    I found little fuse on tcon?(see pic) blown. so I solder wire to check if it work,but not working
    what do you think?
    panel or ?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-48W605B no picture but sound
    Replace the T-CON Bd.
    • chrle
      • Sep 2013
      • 158
      • slovakia
      this model have t-con glued on panel,so I cant remove it from panel.
      • chrle
        • Sep 2013
        • 158
        • slovakia
        pics
        • yokoono
          • Apr 2010
          • 486
          Safety has fired because it is a short or very high consumption. Look for a smd capacitor in short or a dc-dc converter with trouble.
            Yep, start checking for shorted cap/s on that integrated T-CON board, do not put wire in place of the fuse.
            Similar to this: https://www.badcaps.net/forum/showth...ONY+KDL-40W590
            • chrle
              • Sep 2013
              • 158
              • slovakia
              ok I am checking now...
              Vin_12V : 12.75V
              • chrle
                • Sep 2013
                • 158
                • slovakia
                great,now tv dont turn on ,just 5 red light blinks
                • chrle
                  • Sep 2013
                  • 158
                  • slovakia
                  ok guys ,I think I found something
                  I found 4 caps shorted to ground CD14,CD15,CD16,CD17
                  but what I see CD14 is cracked?
                  • chrle
                    • Sep 2013
                    • 158
                    • slovakia
                    ok removed cap from board,and now no short on 3 caps to left
                    now I need to find specifications of cap I removed,I dont have capacitance meter
                    I have old mainboard from tv, and found same size of cap
                    • chrle
                      • Sep 2013
                      • 158
                      • slovakia
                      I found old t con board from SONY KDL-42W705B ,I will desolder one capacitor same size and check if will turn on with picture.
                      or it is not good idea
                      • yokoono
                        • Apr 2010
                        • 486
                        The four capacitors are in parallel. It works with just 3. If not, there are other problems.
                          • 12200
                          • U.S.
                          Ok, so what do you get with the one bad cap removed, any change??
                          • chrle
                            • Sep 2013
                            • 158
                            • slovakia
                            tv turn on,no red light but still no picture..hmm
                            my mistake,I have tv on my bed so I dont see picture till I click menu
                            • chrle
                              • Sep 2013
                              • 158
                              • slovakia
                              ok guys , I have picture without cap that is shorted.
                              tv is working fine,I will test him for few hours.
                              anybody know that cap values? or leave it like this?
                              • jetadm123
                                • 2169
                                CD14,CD15,CD16,CD17 are probably all the same value. If you have any way to measure capacitance, then you can remove one of the good capacitors and measure it's value.
                                • yokoono
                                  • Apr 2010
                                  • 486
                                  Leave that. It also works with 3 parallel capacitors. Do not ruin him worse.
                                    • 12200
                                    • U.S.
                                    Well that's cool, good to know it will run fine one cap down.
                                      They put in 4 caps for reason, they would have put only three to save money if the fourth one is not needed.
                                        • 12200
                                        • U.S.
                                        What do you think will happen if he doesn't replace the cap?
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
                                        • KYBOSH
                                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                          by KYBOSH
                                          Previous owner said TV just went blank one day.
                                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                          I just downloaded the Sony KD-75X7800F Service Manual and...
                                          11-19-2024, 10:12 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • ronni
                                          Sony KD-43XE8005 with sound, backlight, no picture
                                          by ronni
                                          I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                          When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                          Removing the LVDS cable results in...
                                          12-01-2022, 08:44 AM
