Panasonic 58-TXAX802B Stuck on Panasonic Logo
  • Paul112004
    • Sep 2019
    • 14
    • United Kingdom
    Re: Panasonic 58-TXAX802B Stuck on Panasonic Logo
    Photos attached
    • diif
      • Feb 2014
      • 6978
      • England
      IC1600 looks like SPI flash memory.
      Is there anything on the other side of the mainboard ?
      • Paul112004
        • Sep 2019
        • 14
        • United Kingdom
        Hi thanks for that info yes on the rear side there is another chip I shall when I get home send a photo to you to take a look
        Where would I acquire the firmware dump for this tv
        Can I just download new firmware from Panasonic and use that it is it a different kind of flash it does
        New to this so pretty basic skill but if it works it works if not then not lost anything as tv is stuck anyway so may as well give it ago
        I bought some device you out a chip into and it wooes and installs into chips
        • Paul112004
          • Sep 2019
          • 14
          • United Kingdom
          Hi turns out the ic1600 was the chip I needed I think and its called a winbond w25q64fvsig flash I took mine out out it in the machine it read the chip saved to laptop
          Downloaded firmware from Panasonic then when I loaded that file it said it was to long so wouldn't open
          Must be something else I need to flash to it
          Instead I wrote the same info on chip back onto it and tries to fit back on board unfortunately I'm crap at soldering so instead think I burnt my board so after all that I have no idea if it would of worked so spares it is now for that tv
          Should of got someone to solder for me instead unforuanlty I cnat get it to stick without solder being all over the chip pins
          Thanks for your help anyway much appreciated ti make matters worse I smashed my Samsung tv screen so bad day for me
          • Paul112004
            • Sep 2019
            • 14
            • United Kingdom
            Sorted out samsung tv managed to get exactly same model so happy thats all sorted now.
            I'm going to be stripping the panasonic tv for parts now but just before I do I was wondering is it possible to put a different main board into the tv and use with the panel or would that involve changing the t con main board and power board ect basically all of it and would that even work.
            Can the panel be used on another same size tv pretty much out all parts onto that screen and then turn it on.
            Or are they set up basically just for that model type and not able to be used with other types
            Surely the screen is a screen it's the other parts that send the image to it
              • 12206
              • U.S.
              #26
              Not an expert but I believe you need to match the t-con and mainboard with the panel, the same model number can have different panels which can be incompatible with certain t-con and mainboards.
              • Paul112004
                • Sep 2019
                • 14
                • United Kingdom
                #27
                Bit of a pain then and better giving up on it as not worth the hassle of trying stuff out
                Thanks for help much appreciated
                • Swen
                  • Sep 2019
                  • 19
                  • Czech Republic
                  #28
                  did someone manage to get the original DUMP refill into the TNPH1100 2A board ???
                  Thank you.
                  • Slmed11
                    • Dec 2019
                    • Украина
                    #29
                    https://****************/dump/lcd_pd.../289-1-0-71552
                    • Samui67
                      • Dec 2019
                      • 9
                      Hi guys,
                      i am also new here with exactly the same problem. Would it be possible to correct the link in the post above for also can access the download? (Is this dump for the Panasonic Model No. TX-58AX800E - TX-58AXW804 - TX-58AXR800 LA53 Chassis?)
                      This would be really very nice. Thank you very much in advance.
                      ....and a HAPPY NEW YEAR to all !
                      • Swen
                        • Sep 2019
                        • 19
                        • Czech Republic
                        #31
                        This is only DUMP for IC1600.
                        I personally need a DUMP for IC8903 eMMC (I have very bad blocks).
                        • Samui67
                          • Dec 2019
                          • 9
                          Meanwhile i also found this dump in this russian forum - it is from 2013 (!)
                          But it seems that nowhere worldwide the complete dump for IC8903 seems to be available.
                          Pity us, no dump and no replacement board .....
                          • Swen
                            • Sep 2019
                            • 19
                            • Czech Republic
                            #33
                            No it is not.
                            I also searched and not found.
                            Even Panasonic himself does not want to give it.
                            There must be someone who copies it and puts it on a forum.
                            Unfortunately, it cannot be reached yet.
                            • smpcomms
                              • Jan 2020
                              • 5
                              • wales
                              #34
                              Has anybody been able to successfully download this dump file? If so are you able to upload somewhere else or send to me directly
                              • smpcomms
                                • Jan 2020
                                • 5
                                • wales
                                #35
                                Have managed to find a service manual for this model if any good to anyone
                                • smpcomms
                                  • Jan 2020
                                  • 5
                                  • wales
                                  #36
                                  Also managed to find a technical guide which covers a few models in the range
                                  • OCBSlimz
                                    • Nov 2017
                                    • 16
                                    • France
                                    #37
                                    Anyone manage to find a dump for this ?
                                    • cubinarium
                                      • Sep 2020
                                      • United Kingdom
                                      #38
                                      Apologies for the general post, but I have exactly the same problem with the same model (the TX-58AX802). Removing and reflashing seems like an extreme solution but if anyone has any pointers I'd be more than grateful.
                                      I guess if someone could tell me where the firmware image is stored, for example there is a replacement t-con board on ebay which I'd happily fit, but want to be sure that will fix the problem (i.e. where the firmware is stored).
                                      There are three groups of boards (excluding the power on the left), the t-con board seems to be the one at the bottom (as it's the same as the part on ebay), but the other chap here sent a photo of the board on the right (which has all of the external ports connected). The centre seems to be the HDMI control board. If anyone could let me know which board I'd need to replace, or if there's any other way of getting beyond the panasonic logo that would be amazing.
                                      This only just happened, it seems to have automatically updated itself as it had been fine since I had it which was second hand for a little over a week!
                                      *** EDIT! ***
                                      OK - so t-con = timing controller, so would imagine it's unlikely to be that, so the firmware is on a chip on the mainboard presumably. Did anyone manage to reflash it? I'm so surprised, I've seen around 15 of these panels showing the same problem just in my limited research, there's got to be a straightforward way of doing this. WOuld happily pay is anyone could reflash it for me, I'm in Huntingdon\St Neots area.
                                      *** SECOND EDIT!? ***
                                      So based upon what diif and paul said I'd need to reflash the IC1600 (so need to work out how to flash it, and need to find the firmware for it, because the standard panasonic SEC file isn't enough), otherwise I'll need to find a main board replacement!
                                      *** THIRD AND FINAL EDIT!! ***
                                      OK so there's a connector labelled CN1600 which I traced back to the IC1600 chip, presumably so it could be factory flashed.
                                      Is there any way of getting hold of the IC1600 firmware from the above broken link, and would anyone be able to flash it for me for a fee?
                                      Thanks guys,
                                      Ross
                                      Last edited by cubinarium; 09-16-2020, 02:11 PM. Reason: Updated post with more detail, refined my question.
                                      • Swen
                                        • Sep 2019
                                        • 19
                                        • Czech Republic
                                        #39
                                        There is no need to upload a new DUMP to the IC1600, but the main problem is in the eMMC IC8903 on the other side of the mainboard.
                                        • rachido_miss
                                          • Oct 2020
                                          • España
                                          #40
                                          dump for ic1600
                                          • x_orange90_x
                                            Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                            by x_orange90_x
                                            I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                            12-28-2023, 06:26 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • justice171
                                            JVC LT-50N795 Stuck on Wisdom Share Logo
                                            by justice171
                                            I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                            It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                            Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                            Thanks in advance!
                                            11-04-2024, 02:55 AM
                                          • mr.Data
                                            Macbook A1990 stuck on logo
                                            by mr.Data
                                            This Macbook Pro 2018 boots up and then gets stuck on the logo.
                                            All the normal methods of resetting this Macbook have been tried but do not work.
                                            I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                                            Any help would be greatly appriciated....
                                            04-18-2024, 11:51 PM
                                          • platinumsteel
                                            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
                                            by platinumsteel
                                            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
                                            03-18-2024, 05:16 PM
