Panasonic 58-TXAX802B Stuck on Panasonic Logo
  • Chouaaib
    • Aug 2022
    • 5
    • Maroc
    #61
    Re: Panasonic 58-TXAX802B Stuck on Panasonic Logo
    thank you lotas but I want the flash and not the firmware update
    • angel-boy
      • 550
      #62
      I try and i try but cannot manage to fix this loop . i have a 50-AXW804
      Originally posted by Lou G
      After weeks of searching forums, I have now managed to rectify this problem (rebooting logo issue) myself thru the found bits and pieces and trial and error method.
      1. Format an 8GB USB drive and download the latest 3130 firmware to it(. (You maybe able to use a bigger USB drive but this was the info I found on the web and what I tried).
      2. Plug your USB drive into port 1 on the tv(TXAX802B) power on an let the 1st boot cycle begin.
      3. On reboot, press the power button on the tv so it powers the tv off
      4. Then hold down the vol – button on the TV whilst powering on from the TV power button
      5. Keep holding the vol - , the screen will still boot with the Panasonic logo however at the end of the first cycle the tv power light should flash from green to red.
      6. During some point of the red period I then released the vol – button.
      7. On reboot the screen did not show Panasonic logo but just a black screen.
      8. I repeated steps 3 to 7 several times (releasing the vol- at different points of the red light period) until one time the “USB detected” came up on the screen(bottom right), however this time the green power light started flashing on and off in intervals for about one minute.
      9. I waited for the power light to stay stable on for about 30-45 seconds the when I switched off and on again the TV came on all as normal!!!
      10. Once the TV came on, I went straight into the menu and noticed the firmware I had was not the latest(312?) to the one on my USB drive, so I unplugged the usb drive from port 1 and plugged it in again and updated to the latest firmware(3130) immediately.
      My TV has been working fine for the last 2 days!
      As I first said, it was all trial, error and some luck, I hope the above steps help someone!
      • mpcgsy
        • Oct 2015
        • 9
        Hi
        Does anyone know what else would cause the stuck on Panasonic logo followed by 13 flashes other than the IC1600 (25Q64FVSIG) on a TX-50AX502B set?
        The service manual does not even have circuit diagrams.
        Thanks for any info....
        MC
        • lotas
          • Jan 2016
          • 4814
          • Russia
          #64
          Originally posted by mpcgsy
          Hi
          MC
          Problem with eMMC.
          • mpcgsy
            • Oct 2015
            • 9
            Hi
            I thought IC1600 (25Q64) was the eMMC - can you advise which chip this actually is please?
            MC
            • lotas
              • Jan 2016
              • 4814
              • Russia
              #66
              Hi
              MC
              IC8903: H26M31003GMA, TNPH1111 1A board
              • mpcgsy
                • Oct 2015
                • 9
                Hi lotas
                Thanks for your prompt and efficient reply.
                Looks like I have zero chance of changing that BGA IC
                Is it a programmed device would you know?
                TIA
                Mike C
                • lotas
                  • Jan 2016
                  • 4814
                  • Russia
                  #68
                  All the main firmware is in it.
                  • Swen
                    • Sep 2019
                    • 19
                    • Czech Republic
                    #69
                    cannot be repaired by yourself. Very complex (a lot of security codes - pairing with cpu, HEVC, etc.).
                    • Swen
                      • Sep 2019
                      • 19
                      • Czech Republic
                      #70
                      find an expert, preferably from panaconic - as I did (the TV was repaired even after my intervention in the eMMC) :-)
                      • R2OBD
                        • Oct 2013
                        Hi just throwing out there, that I am after a faulty main board to use as a doner board for my issue (not boot / stuck logo). So if you have an faulty board / tv then rather than throwing it out , I will buy the board of you. Let me know cheers this is the panassonic AX802B models
                        • Ben198585
                          • May 2018
                          • 7
                          • Uk
                          #72
                          I have a few.
                          AX902
                          AX802
                          Mains with boot loop
                          • MVC
                            • Jul 2015
                            • 33
                            So I have the big brother for this TV. A TC-65AX800U.
                            It recently started getting stuck after the logo. Red LED then flashed 6 times, over and over. Stuck, had to unplug to boot again or hold power button down and release. Was intermittent but eventually it was broken for good.
                            From repair manual it said 6 blinks was Mainboard issue.
                            Part TNPH1097 (A)
                            Got a pull from China for $141. TV fixed.
                            Reading this thread I'm curious what really brought my board down.
                            I still have the “bad” one and I have an SPI programmer with SOIC-8 adapter.
                            It's on Ebay as parts/repair but if I can dump the flash, happy to help.
                            Would love to know what really went bad.
                            Got the good board on Ali-Express, they had the boards for the 50 & 58” versions as well, as of 3 weeks ago.
                            The 65AX800 is back in service, if I can dump any files that would help, tell me how. I won't be taking it apart, but maybe I can access another way?
                            • wekokid841
                              • Oct 2022
                              • France
                              #74
                              Hello guys,
                              My TV TX-58AX800E also died - error code, code 13 blinking led, motherboard TNPH11002A.
                              The eMMC seems now to be available here :
                              * https://**************/dump/lcd_pdp_tv/panasonic/panasonic_tx_65axw804_shassi_main_board_chassis_la53/289-1-0-138885
                              https://kenotrontv.ru/files/file/969...-h26m31003gmr/
                              Before going further, i would like to know : what kind of hardware is required for programming this eMMC ?
                              The chip is "H26M31003GMR" from SK hynix (IC8903).
                              From the service manual, it seems to be safe replacing the IC8903 :
                              "When eMMC (IC8903) is replaced, Main IC (IC8000) is not necessary to be replaced the same time."
                              Thank you for your help !
                              • conghuyms
                                MacBook Air A2179 stuck logo , pls help me !
                                by conghuyms
                                Hey everyone,
                                I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                11-05-2025, 08:30 AM
                              • x_orange90_x
                                Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                by x_orange90_x
                                I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                12-28-2023, 06:26 AM
                              • G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                by G33RT
                                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                It does power up when pressing the power button.
                                I already try the power button while plugin the plug with no result.
                                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                Could this be an PSU or eMMC issue ?
                                07-19-2025, 03:43 AM
                              • Blallowinformatic
                                Help with laptop stuck on logo!! MACHENIKE L15A
                                by Blallowinformatic
                                Laptop MACHENIKE model L15A RN
                                Board model V150RNEMB-OD
                                Stuck on logo no boot, suspect Clean ME
                                Please help me!...
                                10-21-2025, 03:44 PM
                              • justice171
                                JVC LT-50N795 Stuck on Wisdom Share Logo
                                by justice171
                                I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                Thanks in advance!
                                11-04-2024, 02:55 AM
