Panasonic 58-TXAX802B Stuck on Panasonic Logo
  • Ben198585
    • May 2018
    • 7
    • Uk
    #41
    Re: Panasonic 58-TXAX802B Stuck on Panasonic Logo
    Hi, jumping in on the end of this talk about the poor fast dying model the TX-**AX802.
    I have some good news!!!
    I picked up a main board from a TX-**Dx902 flagship model off the bay for £40 (not bad compaired to £150)
    If one ever turned up on the bay, it would most definitely end up going bad. A Bit like a £150 ticking time bomb lol...
    A little bit of modification to back cover with the metal snipped & removal of the 5 aux ports on top of the main board, also add putting correct pin to pin rewiring main to power, main to ir & buttons. This is not plug n play!!! Be warned!!! Also remove original HDMI/backlight control boards.
    Stitch up after rewire, zap with 2.6 jigga watts and Frankenstein is alive.
    I know it's A bit ghetto but keeps recycling fun
    • nomoresonys
      • 12314
      • U.S.
      #42
      VERY nice work, it's very cool when someone solves a puzzle like that and everything works fine, as long as no protection was disabled, just did one not long ago, needed a snip here and there and presto. Nice save.
      • Ben198585
        • May 2018
        • 7
        • Uk
        #43
        Thanks my friend
        • Jamjon
          • Jan 2021
          Sounds good, what is the exact description oft the bord you used? You thik it depends in the sitze oft the TV?
          Could u show the wiring that you changed?
          Regards
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4521
            • Italy - Milan
            #45
            The problem is only software for me. there's non need to replace any chip. The point is that it needs to succesfully have access to the system through the debug port and no other strange obstacles prensent , finally needed a good basic knowledge of linux systems. If out there some of you would risk to spend money for sending the board to me, i can try to do the work in the time intervals, i need to be payed for the work anyhow.. The main risk is that there can be a software protection when accessing system..
            • zen
              • 511
              #46
              Hi
              Even if you manage to programme up the E M M C chip & get the set working , i suspect there may be issues with the HDMI hand shake , as i believe the chip is paired with the CPU .
              Most TV manufacturers have now started to do this , & as of yet , i don't know of anyone that has found a workaround .
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4521
                • Italy - Milan
                #47
                Zen i don't think the thing is made so, i guess : in factory it is written the firmware, after it is launched an application from within the tv that reads the CPU registers and initializes the right keys in the right files. The problem with the eprom copying is that it is like two cars turning with same ... sorry i don't know the name.. plate??
                • zens electronics
                  • Jan 2021
                  • 31
                  • uk
                  #48
                  Thanks for the information Davi .
                  Haven't experimented with this model myself , but was told by another engineer about the pairing thing .
                  • Jamjon
                    • Jan 2021
                    My 50axw804 is hanging in a boot loop. Sometimes its working (when it passes some point in the boot process) normal unto the next boot. It doesn't show any error code whithin the test mode.
                    @David: what would be your plan, which debug port you mean?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4521
                      • Italy - Milan
                      #50
                      Jamjon i thought you had same model same problem and instead nothing, this is not the place for you, open.your own thread please
                      • KarlNecher
                        • Nov 2020
                        Hi, this is such a great work!
                        I can't really understand how u wired the backlight between the new main board and the inverter board. Or is there no need for wiring. Could you please explain that to me.
                        Best Regards
                        • Ben198585
                          • May 2018
                          • 7
                          • Uk
                          #52
                          I just downloaded both service manuals, then compaired both power boards and main boards to put correct pin 2 pin.
                          It does get very confusing lol... As long as you check your wiring 3 time over before you switch it on.
                          I wired the B/L on to the standby button, and when you turned tv off with remote it didn't turn off the B/L.
                          So that was the only thing that wasn't perfect!!
                          but just ment turning it off with the button on the side instead.
                          • narsil
                            Enas
                            • Dec 2017
                            • 84
                            • france
                            #53
                            Does anyone have a emmc file?
                            TX-50AX800E
                            TNPH1100
                            • 661305
                              • Mar 2019
                              • uk
                              #54
                              I know i'm reviving an old thread here but i'm wondering if the OP Ben198585 has any more info on what they did as i'm in the exact same boat now.
                              I have the exact same boards and i'm going to frankenstein them!
                              Physical mods i'm fine with.
                              I have both service manuals.
                              regarding pinout mods, you mention main board to power, buttons and ir.
                              Are the below the mods you made?
                              * - Main board (A-Board) >>> power board (P-Board)
                              * - Main board (A-Board) >>> IR receiver (K-Board)
                              * - Main board (A-Board) >>> Buttons (GK-Board)
                              • Lou G
                                • Jun 2022
                                After weeks of searching forums, I have now managed to rectify this problem (rebooting logo issue) myself thru the found bits and pieces and trial and error method.
                                1. Format an 8GB USB drive and download the latest 3130 firmware to it(. (You maybe able to use a bigger USB drive but this was the info I found on the web and what I tried).
                                2. Plug your USB drive into port 1 on the tv(TXAX802B) power on an let the 1st boot cycle begin.
                                3. On reboot, press the power button on the tv so it powers the tv off
                                4. Then hold down the vol – button on the TV whilst powering on from the TV power button
                                5. Keep holding the vol - , the screen will still boot with the Panasonic logo however at the end of the first cycle the tv power light should flash from green to red.
                                6. During some point of the red period I then released the vol – button.
                                7. On reboot the screen did not show Panasonic logo but just a black screen.
                                8. I repeated steps 3 to 7 several times (releasing the vol- at different points of the red light period) until one time the “USB detected” came up on the screen(bottom right), however this time the green power light started flashing on and off in intervals for about one minute.
                                9. I waited for the power light to stay stable on for about 30-45 seconds the when I switched off and on again the TV came on all as normal!!!
                                10. Once the TV came on, I went straight into the menu and noticed the firmware I had was not the latest(312?) to the one on my USB drive, so I unplugged the usb drive from port 1 and plugged it in again and updated to the latest firmware(3130) immediately.
                                My TV has been working fine for the last 2 days!
                                As I first said, it was all trial, error and some luck, I hope the above steps help someone!
                                • nomoresonys
                                  • 12314
                                  • U.S.
                                  #56
                                  Nice fix, thanks for sharing.
                                  • Chouaaib
                                    • Aug 2022
                                    • 5
                                    • Maroc
                                    #57
                                    Salut
                                    Combien de fois pour que votre téléviseur detecte usb
                                    Hi
                                    How often for your tv to detect usb
                                    • Chouaaib
                                      • Aug 2022
                                      • 5
                                      • Maroc
                                      #58
                                      Please dump for tx-50ax800e
                                      • Chouaaib
                                        • Aug 2022
                                        • 5
                                        • Maroc
                                        #59
                                        Salut si quelqu'un a le flash du panasonic tx-50ax800e parce que on rien trouver après plusieurs recherche même si il est payant et merci infiniment
                                        • lotas
                                          • Jan 2016
                                          • 4817
                                          • Russia
                                          #60
                                          https://av.jpn.support.panasonic.com...uk_cis_05.html
                                          https://av.jpn.support.panasonic.com.../P143_3130.zip
                                          • conghuyms
                                            MacBook Air A2179 stuck logo , pls help me !
                                            by conghuyms
                                            Hey everyone,
                                            I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                            When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                            I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                            11-05-2025, 08:30 AM
                                          • x_orange90_x
                                            Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                            by x_orange90_x
                                            I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                            12-28-2023, 06:26 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Blallowinformatic
                                            Help with laptop stuck on logo!! MACHENIKE L15A
                                            by Blallowinformatic
                                            Laptop MACHENIKE model L15A RN
                                            Board model V150RNEMB-OD
                                            Stuck on logo no boot, suspect Clean ME
                                            Please help me!...
                                            10-21-2025, 03:44 PM
                                          • justice171
                                            JVC LT-50N795 Stuck on Wisdom Share Logo
                                            by justice171
                                            I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                            It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                            Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                            Thanks in advance!
                                            11-04-2024, 02:55 AM
