Sharp LC-60LE741E 3 Blinks
  • diif
    • Feb 2014
    • 6978
    • England
    #41
    Re: Sharp LC-60LE741E 3 Blinks
    The service manual.
    • Diah
      • Feb 2013
      • 6417
      regard to SM attached by dilf. your are now at BGA issue at CPU. put tape on the cpu tightly and use heat GUN to cook it. hopefully it will work if you dont have reball or BGA station
        • 12214
        • U.S.
        #43
        Originally posted by london-freddie
        just warmed mainboard using a hairdriver and tv powered up to a good picture, however before i could get remote to do a factory reset it powered off
        Now thinking nothing to loose maybe worth sticking mainboard in the oven for ten minutes
        THIS makes me think it might be a bad cap or something, where did you heat it to get that result?
        • london-freddie
          • May 2015
          • 472
          Re nomoresonys,THIS makes me think it might be a bad cap or something, where did you heat it to get that result?
          I baked mainboard in oven 220c 10 minutes
          my searching on google seems to suggest 1 fast 3 slow is powerboard, but my previous 3 blinks prior to baking suggests mainboard problem
            • 12214
            • U.S.
            #45
            Was wondering which part you heated with the hairdryer to make it work for a minute, may have been a certain capacitor that got back it's low esr when the heat was applied??
            • london-freddie
              • May 2015
              • 472
              No I played the heat gun all over the main board just to warm it in general, but it did come back to life even though it was for only a short time.
              But it did also come back to life when I used the freeze spray on the main board, again only for a minute or so
              Can not get it on now just got the 1 fast 3 slow blinks of the led
              • diif
                • Feb 2014
                • 6978
                • England
                #47
                The initial 3 flashes and the use of freeze spray/heat to boot it suggests it was an eeprom issue.
                Your new flash error suggests you've unsettled the BGA under the processor(hopefully).
                • london-freddie
                  • May 2015
                  • 472
                  Well powered this tv this morning led blinking has reverted back to its original 3 blinks
                    • 12214
                    • U.S.
                    #49
                    • Egidio85
                      SHARP LC-40LE814E does not turn on 2 flashes
                      by Egidio85
                      hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                      the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                      reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                      now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                      to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                      07-21-2023, 11:49 AM
                    • joblo37pam
                      Sharp LC-80LE844U Blinks 2 slow, 5 fast
                      by joblo37pam
                      It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                      The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                      10-26-2023, 02:17 PM
                    • Biruslapio
                      Panasonic P58V11B 8 and 12 blinks error "fix"
                      by Biruslapio
                      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                      04-13-2021, 07:13 AM
                    • JayPoorJay
                      sharp LC70EQ10U 2 slow, 2 fast blinks
                      by JayPoorJay
                      Good morning... I'm new here and have a LOT to learn.
                      I'm a rescue-er. I live in NYC and I don't even want to get started on the amout of stuff that makes it onto the curb, to be crushed and in a land fill, simply because our repair shops have been sold out and because - well, it's a disposable society... Anywho
                      I have 1 motorcycle, 3 Jaguars and a Porsche that were all headed to the crusher due to a couple handfuls of needed parts and a Lil Love,,, I'm hooked on the rescue. A member of several forums and a huge fan of DIY environments such as this one. Hats off to you...
                      01-24-2022, 09:26 AM
                    • Anzio
                      Sharp LC60E79u 2 blinks power/3 Blinks OPC
                      by Anzio
                      I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                      The service manual indicates this as a “DET_5V (33pin) error (L). 5V is not applied.”
                      I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                      07-03-2020, 01:12 PM
