Sharp Aquos LC-32CHG2601 LED. Blue screen
+ More Options
Posts
  • 6BW6
    • Jan 2015
    • 55
    Blue screen, backlights OK, white LED starts flashing red after about 20 seconds and will not switch off.
    Tried Tcon ribbon, Tcon fuse and re-set. Anyone come across this?
    Thanks, Dave.
  • nomoresonys
    • 12210
    • U.S.
    Re: Sharp Aquos LC-32CHG2601 LED. Blue screen
    Here's one possible reset: Unplug the television.
    Press and hold the "Channel Down" and "Input" buttons on the panel.
    Plug the television back in while holding down these buttons. ...
    Keep holding the buttons until the television powers back on. ...
    Use the remote to navigate the "Service Mode" menu and select "Factory Reset" from the menu.
    • 6BW6
      • Jan 2015
      • 55
      1) Holding the input button down is an impossibility - the set has a 'wobble stick' as I call em', up down and side to side for vol and Channel, press 'in' to toggle off/on.
      2) "Service Mode" - also an impossibility with blue screen and no display.
      Dave
        " Sharp Aquos LC-32CHG2601" Can you please verify if that is the correct model number?
        Also please upload the pictures of the whole backside of the TV showing all the boards and the screen shot of what is shown on the screen.
        • 6BW6
          • Jan 2015
          • 55
          Re: Sharp Aquos LC-32CHG6201 LED. Blue screen
          Ooops sorry LC-32CHG6201K is the correct model.
          I Edited title. I'll get back with the board pictures shortly.
          Dave
          • 6BW6
            • Jan 2015
            • 55
            I've got 1.8 & 12V on the Tcon, the LED voltage is 48V, would that be right for this model?
            Just a dull blue screen, the LED's seem OK when looking at the back of the panel, no menu or anything.
            Here's the board
            https://ibb.co/6DpzLhX
            Dave
              We need to see the whole backside of the TV showing all the board so we can see what it has.
              How many ribbon cable between T-CON board and the LCD panel, two?
              If it has two then what happen when you have it connected one at a time?
              • 6BW6
                • Jan 2015
                • 55
                The Tcon connections comes from a bunch of wires to a inter connection board and then via the ribbon cable. here is a photo. https://ibb.co/x2K4j96
                Removing them makes no difference, still blue screen with backlight and about 20 seconds before red led flashes continuous on a regular basis.... no spaces etc.
                Edit
                Pretty sure this is a Hisense set.... Sharp gave them the license to produce sets I believe. Sharp UK doesn't recognise this model. I was hoping to get a firmware update from them.
                Thanks, Dave
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  It's made by UMC.
                    It has integrate T-CON into the panel.
                    • 6BW6
                      • Jan 2015
                      • 55
                      The Tcon can clearly be seen and this is where I checked it's 1.8 and 12V.
                      Yes, I can confirm that UMC is the maker NOT Sharp, I understand Sharp allowed Hisense to use their badge. I just received a Email from UMC stating they can send me the firmware which I am waiting for. Let you know how I get on.
                      Dave
                      • 6BW6
                        • Jan 2015
                        • 55
                        Well, I installed the firmware and brought screen activity, upon completion the set switches OFF and the LED flashed rapidly as per the instructions, at this point I unplugged and removed the USB stick as advised.
                        This took about 7 minutes as per the instruction.... after which the instructions said the update would take about 15 to 20minutes...... I got initialising in the top corner then waited and waited for at least half an hour.
                        All I got was the screen changing colours as stuck in the burn mode.... so I reckon we can exclude the T'con and the ribbon cable.
                        Thought I'd update.
                        Dave
                        • 6BW6
                          • Jan 2015
                          • 55
                          Re: Sharp Aquos LC-32CHG2601 LED. Blue screen -SORTED-
                          With set unplugged, download firmware onto a USB stick, insert an plug set in - this takes about 7 minutes with the progress displayed on the screen.
                          After which the set will shut off - WAIT until the power button flashes rapidly, this took about a minute or so UNPLUG and then remove the USB stick.
                          In my case, when plugging back in the initialising circle appeared and the screen kept changing colours.... (Burn-in mode), but the instructions from UMC said to wait 15 to 20 minutes, I got sick of trying so I did the 'proverbial', unplug the set, with the the 'wobble' button on the back pressed I plugged in - Bingo, set is now back to normal.
                          Should you ever require firmware from UMC always gave the Model and serial number.
                          Dave
                          • nomoresonys
                            • 12210
                            • U.S.
                            Holding power button while plugging in is a go to reset that works in a lot of cases.
                              Dave
                              Great, so it is working normal again. Please upload the FW so we can use it in the future and also your serial number.
                              • nomoresonys
                                • 12210
                                • U.S.
                                Originally posted by budm
                                great, so it is working normal again. Please upload the fw so we can use it in the future and also your serial number.
                                +1
                                • 6BW6
                                  • Jan 2015
                                  • 55
                                  Re: Sharp Aquos LC-32CHG6021K LED. Blue screen
                                  I'm trying to upload now. I thought I'd corrected the model number it's a LC32-6021K NOT a 2601.
                                  I give up, something went awry in the post in EEPROM dump didn't include the .rar file
                                  Dave
                                  Last edited by 6BW6; 06-25-2019, 04:08 PM. Reason: can't upload .rar file in EEPROM section.
                                  • satinser
                                    • Oct 2012
                                    • 214
                                    • uk
                                    Same issue with software needed did you ever download the software after??
                                    • scubacamper
                                      Sharp Aquos LC-70C6400U Half Screen Dark
                                      by scubacamper
                                      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                      05-03-2025, 12:19 PM
                                    • sefoster
                                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                      by sefoster
                                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                      11-20-2022, 09:29 AM
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
                                    • thesharpfella
                                      Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                      by thesharpfella
                                      Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                      07-23-2024, 10:37 AM
                                    • EazyBone
                                      Sharp LC-65Q620U White Screen
                                      by EazyBone
                                      Another TV topic!!
                                      I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                      The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                      Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                      08-21-2024, 12:56 PM
