Samsung PN43F4500FXZA turns on no picture or sound
  • nwelec
    • 61
    • usa
    TV turns on I get proper VA of 58V but VS is 250V and should be 208V and I can not adjust it with the pot. Also voltages at CN4009 are correct when first turned on then they start to drop to 0. I can not find any thing online about this problem with this model and was hoping for some direction.
  • Beau28713
    • Feb 2018
    • 50
    Re: Samsung PN43F4500FXZA turns on no picture or sound
    Remove pot and test pot for proper operation first. Then move on.
    • R_J
      • 9588
      What meter are you using to measure the Vs voltage, sometimes cheap meters react that way due to the high y drive pulses (lg/goldstar meters act that way)
      This may not be your problem but I thought I would mention it.
      You say the voltages on CN4009 are correct? pin 6 is the Vs pin, so it is 208v? then drops to 0
      • nwcs
        • Dec 2015
        • 311
        • usa
        I use a Fluke 77 and have used fluke for 40 years. I will check the pot in the morning to see if it is defective. I will check pin 6 again tomorrow to see what it reads.
        • R_J
          • 9588
          I only mentioned the meter because I (and a couple others) have seen this, I normally use a Fluke but also have a cheap lg on the bench and on some plasma's, checking the Vs, even on 1000 volt scale will show OL. So I check with the Fluke and the reading is fine.
          • nwelec
            • 61
            • usa
            So I tested both the pot which does adjust out of circuit and pin 6 of CN4009 which I thought was dropping but I found that it is steady at 250v but all other pins drop to 0v.
            • R_J
              • 9588
              That high voltage could be due to a lack of feedback to control the voltage, check the components around the control all the way to the optocoupler, I would also check on the primary side of the optocoupler. most power supplies go down in voltage when they loose feedback for safety
              Check that 0Ω off of DS853C, It supplies the low voltage for the feedback circuit on the secondary
              • nwelec
                • 61
                • usa
                Don't know how I missed this but there is corrosion all over the power supply board.
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Dodgethis
                  Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                  by Dodgethis
                  Hello all,
                  This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                  09-11-2024, 07:39 AM
                • JohnML1975
                  Samsung UA50TU8000W no picture and no sound
                  by JohnML1975
                  Hello All
                  have seen posts on this model in here but my problem sounded different so thought i would create a thread
                  TV will not turn on
                  There is no standby light
                  When I press ON button for remote the red standby light does flash but no picture and no sound
                  From the back of the TV I can see the red light on the back of the mother board
                  Holding torch to the screen I cannot see a picture
                  I removed the back cover
                  Observing the boards I cannot see any damage
                  I disconnected the main board from the power supply
                  the back...
                  08-30-2025, 09:40 PM
                • marekk
                  Samsung QE55Q67RAT no sound and bad picture when streaming
                  by marekk
                  I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                  I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                  Mainboard is based on pcb BN41-02695A BN94-14007B
                  I will appreciate any help
                  Many thanks
                  Marek...
                  05-29-2025, 02:23 AM
