LG 65UH5500 Dead
  • Diah
    • Feb 2013
    • 6560
    Re: LG 65UH5500 Dead
    Originally posted by hbdeals
    I had removed and checked all of those parts under the heatsink before. They tested ok on a cheapie LCRT4 checker. I don't know how reliable that is. C10 was shorting out and causing Q15 to read .5 ohms. Both the LCRT4 and ohm meter shows C10 as a dead short. It is a (badcap).
    All of the electrolytic caps on the power supply test good in circuit with ESR meter.
    cracked parts mean they had crack at the Insulation material on the body shape. they will tested OK but will not work normal.
    • hbdeals
      • Oct 2014
      • 55
      I finally broke down and ordered a power board. TV works! I'm going to keep the bright levels down low because these are bad for buning out LED backlights. Thanks for the help yall.
        Thanks for follow-up.
        • jason123
          • Oct 2015
          • 1136
          I know this is an older post.. but I'm running into a similar issue - I'm getting the voltages - most of the time - but large caps have ~350V even with nothing is connected to power board. Is this the case in this post? Seems he's had 360V all the time on his large caps. Is this the proper mode of operation on this board?
          https://www.badcaps.net/forum/showthread.php?t=81217
            • 12330
            • U.S.
            #85
            From what I gather, seems like C10 was bad plus something else on the powerboard was bad because a replacement board solved the problem.
            • anupkg1985
              • Sep 2020
              • 180
              I had exactly same issue with the power board for this TV. The voltage on main caps was fluctuating and the output voltages 13v and 80v were not stable. After the diagnosis found the one of the diode on secondary was short. This was causing the short circuit and forcing PFC to shutdown. In my case replacing D23 solved the issue and TV is back to live .
              • BTubbs200
                Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                by BTubbs200
                Dell Latitude 5420 P137G
                Board: LA-K491P REV A01
                I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                Board seems to have no shorts, all power rails are fine and show high resistance.
                When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                01-24-2025, 08:15 PM
              • Nagyesz
                Lenovo ideapad 330ICH - Dead, no volts on coils
                by Nagyesz
                Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                I've never encountered something like this before;
                No charging light, full dead
                Lenovo Ideapad 330-17ICH
                • PL3102: 5 ohms
                • PL3001: 3.2 ohms
                • PL3101: 2 ohms
                • PL5801: 3.5 ohms
                • PL5501: 270 ohms
                • PL701: 35 ohms
                • PL501: 146 ohms
                • PL503: 390 ohms
                • PL402: OL (0.27V) +5VALW_P
                • PL301: OL
                • PL401: OL (0.03V) +3VALW_P
                + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                10-11-2024, 10:12 AM
              • u666sa
                HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                by u666sa
                Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                Platform: ipa32 la-m024p rev 1b
                Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                I found a short on the other side:
                10-04-2025, 05:03 PM
              • MisterAIL
                PS5 digital / No Power / No Beep / Good power supply
                by MisterAIL
                Brought a non functionnal PS5. Apparently only a bad PSU...
                No beep, nothing.
                After some tests i found this :
                - PSU is fine (12 volts stable)
                - 12 volts line is shorted
                - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                - By the way, nothing change. No signal, no power, no beep.
                Mesuring all rails with my workbench psu (12 volts input)
                - 0.00 amp drawing
                - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                03-12-2024, 03:24 PM
              • _AcE_
                JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                by _AcE_
                I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                There's no physical damage...
                08-10-2025, 09:27 AM
