JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
  • _AcE_
    Capt. AcEitor
    • Jul 2023
    • 5
    • South Africa
    I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
    There's no physical damage to the board or any of the components. I cannot for the life of me find any issues anywhere on the board. There are no shorts, no blown components/fuses, caps seem fine, resistors and diodes all seem to check out when testing with my multimeter.
    What I've tried replacing (made no difference, so I reinstalled the originals):
    • Replacing the bridge rectifier
    • Replacing the OB5269CP PWM controller
    Looking at pages 23 & 24 (Soundbar Power Board - CIRCUIT DIAGRAM) of the attached schematics, can we all agree that the DC output of the CON2 connector should be 23 volts, right? Push comes to shove, I'd then just replace the dead PSUs with another aftermarket 23-volt power supply with sufficient current ratings. CON2 is where the PSU then connects to the main board in the soundbar.
    I've attached high-res photos, videos, and thermals of the PSU, along with an attachment of the boardview/schematics. If anyone could point me in the right direction, any and all help would be appreciated.
    Full-Res Imgur Photos:
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8887
    If that primary is pulsing, a very good chance there is a short on the secondary of the PSU or there is a short on one of the other boards that is / are connected has a short. There are 2 power supplies, one for the sound bar with 23VDC and another one for the Sub with 34VDC.
    Could be also there is something wrong with the feedback like the optocoupler, voltage reference or that zener.
    First you got to find out if there is indeed a short on the PSU secondary or on the other boards connected to it.
    Also look if the PFC is running on the primary of the PSU. No PFC = no high DC voltage output. Check the voltage on the main filter capacitor. If the PFC booster is working, you should see like 380VDC on the capacitor. What about the gate drive circuit?
    The bridge rectifier isn’t the problem. Also check the primary of the transformer… maybe it is open?
    The deep bass PSU is 34VDC. Makes me wonder if you are looking at the correct PSU?
    Your vid shows the soundbar psu. So something isn’t right.
    • TonyNYE
      Klipsch Icon SB1 Soundbar with Wireless Sub. **No sub output**
      by TonyNYE
      Problem:
      No sound at all coming from subwoofer (soundbar works fine).
      No issues for 5 years, then for about a month the sub would produce a hardly noticeable background hum. Then it went dead.
      My (amateurish) troubleshooting:
      - LED on sub turns red, then blue, showing wireless connection established. This is normal.
      - Volume control makes no difference.
      - Disconnected sub speaker – the cone moves smoothly by hand, and 9v battery produces a thud.
      - Measured 0 volts at amp output (terminals going to speaker), with music playing. But I think I did...
      01-07-2026, 08:16 AM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • MicroSMD Lab
      JBL Bar 2.1 Deep Bass subwoofer works for short time
      by MicroSMD Lab
      Hi, I'm trying this sound bar. The bar works. the bar and subwoofer have independent power supplies and connect via 5Ghz wifi (Everestek EV01SA Rx module). If the subwoofer is unplugged overnight, it works for a couple minutes then stops. The power supply is good. The 12V and 3.3V are present. The STANDBY is not present. The schematic is a bit confusing to me. Seems like the STANDBY is created by the EN of U4 (WS4603E Power distribution switch). Also, the STANDBY seems to be providing the gate signal to Q7 (WPM3407 P-channel mosfet) but +12V and A_12V are present. I disconnected R133 and R25 to...
      10-09-2026, 02:14 PM
      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
      I bought this from an eBay seller but unfortunately they only had one
      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
      I bought three of from them to also make battery packs with this output power limit in mind
      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
      04-23-2025, 05:50 AM
    • karlox
      Dell OptiPlex Micro 7010 - No DisplayPort Output, HDMI Works Fine
      by karlox
      I have a Dell OptiPlex Micro 7010 in the shop with a rather unusual issue. The integrated DisplayPort (DP) has no video output, while the HDMI output works perfectly.
      So far, I have performed the following troubleshooting:
      Disassembled the unit and inspected the motherboard and all internal connections. Everything appears to be in good condition with no visible damage.
      Installed the latest official Dell graphics drivers.
      Tested with two different DisplayPort monitors (one newer and one older), both known to work properly. The result...
      07-29-2026, 07:34 PM
