Samsung UN48H6350AF Black Screen w/ sound
  • thetonywarren
    • Feb 2013
    • 167
    Just got this TV, boards seem to power on, at least main board shows light on the optical audio output, the led on front of set is on and there is a blue led on the t-con board. Sound is there when I press the power button and make selections in menu, but nothing on screen, doesnt seem to have anything with flashlight test either.....Any help would be great. Thanks!
    Re: Samsung UN48H6350AF Black Screen w/ sound
    No AC to TV then disconnect the cable between the power supply and the main board then apply AC to the TV, do the backlights to come on and stay on as long as the AC is present?
    We also need to to get the Voltage readings (all boards connected) of all the pin of the power supply connector that goes to the main board, there are two rows of pins, the odd number pins are the exposed pins you can get to from the top side of the board, the even number pins you need to get to them via the wire entrance of the connector.
    You MUST put down pin name and follow by the Voltage reading for each pin when Power switch is off and when power switch is activated.
    Power supply/LED driver board is P/N BN44-00703A.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by budm
      no ac to tv then disconnect the cable between the power supply and the main board then apply ac to the tv, do the backlights to come on and stay on as long as the ac is present?
      We also need to to get the voltage readings (all boards connected) of all the pin of the power supply connector that goes to the main board, there are two rows of pins, the odd number pins are the exposed pins you can get to from the top side of the board, the even number pins you need to get to them via the wire entrance of the connector.
      You must put down pin name and follow by the voltage reading for each pin when power switch is off and when power switch is activated.
      Power supply/led driver board is p/n bn44-00703a.
      +100
      • thetonywarren
        • Feb 2013
        • 167
        When main board disconnected, AC power applied, backlights work.
        With all boards connected and TV powered both On and Off readings are the same as shown below.
        Pin Readings (All VDC)
        1: 12.83
        3: 12.83
        5: 12.83
        7: 12.83
        9: 0.01
        2: 3.37
        4: 0.09
        6: 3.34
        8: 0.01
        10: 0.01
        Thanks, I really appreciate your help!!
          So where are the pin names to go with each one of those readings?
          • thetonywarren
            • Feb 2013
            • 167
            Ok, sorry, I thought the PIN numbers were the names. Are the actual "names" labeled on a table on the board itself?
            Thanks!
              https://www.badcaps.net/forum/attach...5&d=1559357105
              If you look at the pinout chart, you will see pin number and the name of the pin, just edit your post to add pin names.
              • thetonywarren
                • Feb 2013
                • 167
                1: 12.83
                3: 12.83
                5: 12.83
                7: 12.83
                9: 0.01
                2: 3.37
                4: 0.09
                6: 3.34
                8: 0.01
                10: 0.01
                1: A13V: 12.83
                3: A13V: 12.83
                5: A13V: 12.83
                7: A13V: 12.83
                9: GND: 0.01
                2: OD/UD: 3.37
                4: BLU ON/OFF: 0.09
                6: PS ON/OFF: 3.34
                8: GND: 0.01
                10: GND: 0.01
                  "4: BLU ON/OFF: 0.09" Main board is not sending the command signal to turn on the backlights circuit.
                  My post #2:
                  "No AC to TV then disconnect the cable between the power supply and the main board then apply AC to the TV, do the backlights to come on and stay on as long as the AC is present?" Did you do that test?
                    • 12274
                    • U.S.
                    My post #2:
                    Yes backlights on, confirmed in post #4.
                      OK, I miss that, so main board troubleshooting next.
                        • 12274
                        • U.S.
                        Looks like they want about 100 dollars for the mainboard one there on ebay from shopjimmy, does have a make offer option: https://www.ebay.com/itm/Samsung-BN9...IAAOSwCA5cX79T
                        • thetonywarren
                          • Feb 2013
                          • 167
                          Ok, so what can we do to troubleshoot the main board next......I'd rather try to troubleshoot repair main board first, before buying one......
                            • 12274
                            • U.S.
                            Could try reflowing the bga chip, trick is to heat it enough to melt the solder under the chip, overheating can kill it, usually the fix don't last too long but if it works after the reflow, you know what the problem is. Here's one example on an lg, there's probably plenty more that go into greater detail: https://www.youtube.com/watch?v=SfVnVl6Q0sk
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Here's the service manual, there are some voltages to check on the mainboard to start.
                              • thetonywarren
                                • Feb 2013
                                • 167
                                Are you suggesting the pins on pages 5-7 and 5-8 of all the connections? are there specific areas of the board I should focus on and look for particular voltages? Any help is appreciated.
                                Thanks!
                                I'd rather try to troubleshoot it this way before trying to re-flow the BGA.....
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  Thanks!
                                  The voltages I was mentioning to check are on page 4-4 to 4-6.
                                  • thetonywarren
                                    • Feb 2013
                                    • 167
                                    So I tried following those steps and testing/troubleshooting, but some of the steps did not make sense or I couldnt find the components that were referred to on some of the steps.....I did get some readings though....The first one looks suspect to me, but not sure what that eludes to.
                                    L204: 1.55v
                                    L201: 5.15v
                                    IC202: 3.32v
                                    L203: 3.37v
                                    L306: 1.04v
                                    L305: 1.16v
                                    L2001: 5.04v
                                    • boyebaran
                                      • Sep 2015
                                      • 249
                                      • iran
                                      hi
                                      you can try re flashing firmware.
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        L204: 1.55v
                                        L201: 5.15v
                                        IC202: 3.32v
                                        L203: 3.37v
                                        L306: 1.04v
                                        L305: 1.16v
                                        L2001: 5.04v
                                        Yes, that does look suspect, it's where I would focus my attention. Can you take a photo of that area ?
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • totof
                                          LG 43UF640V backlight good but black screen and no sound
                                          by totof
                                          Good morning.
                                          I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                          I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                          In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                          HVDD : 7,28...
                                          04-13-2024, 11:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
