Philips 40PFL4908/F7 Dead
  • HMRG123
    • Jun 2017
    • 20
    Have this set and the customer said it just would not turn on one day. Q601 is shorted, R611 and F602 are open. I do not see anything else as bad. Does anyone know of anything else I should check before replacing these parts?
    OOPs, just rechecked and found D653 shorted...same question: Does anyone know of anything else I should check before replacing these parts?
  • neilc6
    • Nov 2015
    • 1550
    Re: Philips 40PFL4908/F7 Dead
    The power supply on this model is probably similar design.
    https://www.badcaps.net/forum/showthread.php?t=72916
    • Unspun01
      • Jun 2011
      • 333
      You will want to check and replace at least the following parts:
      F602 (fuse, 2.5A, 250V),
      Q601 (MOSFET transistor, N-channel, 7A/600V),
      D608 (zener diode, 36V, 1Watt),
      R611 (Fusible Resistor, orange, black, silver, gold = 0.3ohm, 5% tolerance, 2 watt),
      D653/D655 (Schottky Diode, SB3A0 = 3A, 100V),
      D607A (zener diode, 27V, 500mW)
      Q602 (2SC5344SY = BJT NPN transistor, 800mA, 30V, SOT-23)
      D607A and Q602 are small surface mount parts on bottom of board.
      See attached service manual.
      • kew1701
        Philips taw6205 ambilight speaker STM32 mcu dead
        by kew1701
        Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
        04-09-2025, 03:59 AM
      • Rubenlily
        Philips 50PUS6503 - dead panel? Picture
        by Rubenlily
        Hey,
        I gave up on my last TV and got a new one to try.
        Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
        Is this fixable in any way or should I just give up on this one too?...
        08-21-2023, 01:07 PM
      • double_DD
        How can I be sure that my EC chip is dead?
        by double_DD
        As the title suggests, how can I be sure that my EC chip is really dead?
        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
        03-12-2025, 07:47 AM
      • vikivng
        PHILIPS 40PFL7007 TV DEAD. D501 testing SHORT on DMM
        by vikivng
        Hi guys pls can someone help with this set..
        Tv doesnt not power on.
        No standby light.
        There is a burn mark by the leg of D501 diode.
        The diode tests short in both directions.
        I have been reading this usually means the diode is faulty? As normally would be open.
        I have not yet taken voltages since this is obviously short I would like to replace it.
        Can someone help me with a substitute for this diode since it seems not to be the standard type?...
        08-22-2022, 10:51 AM
      • jimbofz
        philips 65PUS6162/05 dead no sby led
        by jimbofz
        hi to all,
        following on from earlier post ref:no boosted pcf voltage
        i managed to get a LD7591T pcf boost ic
        i now have 385v boosted volts.
        the psu produces 12v ok ,
        (and bear in mind the 5v and 3,3v supplies are produced by the main board not as shown on the psu board markings.)
        now, the tv has no sby led lit ,no backlight voltages
        my thaughts were that ths processor could be faulty,but i wanted to completely eliminate the psu first
        i checked all the supplies on the main board 1,5v,3,3v,5v, they are all ok,
        the psu voltages:...
        06-04-2022, 02:33 AM
