Philips 39PFL2608/F7 No Power
  • neilc6
    • Nov 2015
    • 1550
    This TV had no power. I had repaired a similar TV with a shorted diode here
    https://www.badcaps.net/forum/showthread.php?t=71919
    Found fuse F602 blown, main switching transistor Q601 shorted and one of the SB3A0 secondary diodes shorted (can't recall which one). With the components replaced, fuse doesn't blow, main filter cap measures around 160V stable but there is no output at AMP+13V and P-ON+21V lines. There is no short on those lines - pulled up the protection zeners (still disconnected in pic), and checked C650. Odd that both have 0V since they are relatively independent fed from different legs of the transformer.
    Service manual from this thread https://www.badcaps.net/forum/showthread.php?t=56211
    May have clues from repair kit in this listing. Shows some SOT-23 transistors and power resistor. https://ebay.us/FnpoZo
  • yohnsee
    Semi-noob
    • Dec 2017
    • 198
    • Hungary
    Re: Philips 39PFL2608/F7 No Power
    the service manual is very talkative, it has voltage levels for the normal working conditions marked.
    Is Q602 not shorted? What signal does it receive on its base?
    Also check IC601, 602. They are in the feedback line, maybe your new Q601 does not get any drive signal?
    Cheers, Janos
    • neilc6
      • Nov 2015
      • 1550
      I was assuming since I measured 160V on C611 (no marked voltage on schematic but rated for 200V) the main filter cap on the hot side was working. Q602 isn't shorted. Will check optocouplers IC601 and IC602 and confirm Q602 base voltage (0.4V on schematic).
      • neilc6
        • Nov 2015
        • 1550
        Ok some measurements. Base of Q602 0.4V (measured at pin 3 of optoisolator). Pin 4 optoisolator 0.3V (14.2V on schematic). Drain Q601 159V (292V on schematic). Gate Q601 0.4V (4.4V on schematic). Will concentrate on this section.
        • R_J
          • Jun 2012
          • 9625
          Did you check R611, if Q601 was shorted the resistor could be open as well. How was the fet shorted? if all the legs were shorted IE drain to gate, D607a is likely shorted or Q602 damaged
          You might want to check R603,R604 & R614 also, sometimes one may go open. You may need to disconnect one of them to check them properly.
          • neilc6
            • Nov 2015
            • 1550
            Q602 is shorted on all pins.
            R611 (.37 ohm 2W) - measures 0.4 ohm in circuit so not open
            D609A (CES520) - measures 0.24V one direction and 1.5V the other diode mode, in circuit - questionable
            D607A (TFZVTR27B) - 0.9V one way, 1.7v other - questionable
            R604, R603, R614 (560K) - around 600K in circuit so ok
            Q602 (2SC5344SY) - base to emitter 1.4V in circuit, 0.3V reverse in circuit - not shorted but questionable
            • neilc6
              • Nov 2015
              • 1550
              Found this post searching for a cross-reference for 2SC5344S
              https://elektrotanya.com/content/eme...t-start-solved
              Recommends IRF640 (200V/18A) for Q601, 2N5551 (TO-92 not SOT-23 SM) for Q602, and potential short on D608.
              Lifting leg of R611, R611 (0.3ohm/2W) is open and D608B (36V zener) is shorted. The repair kit is looking fairly close. Figuring out what that second SOT-23 replaces would eliminate the last suspect part.
              • yohnsee
                Semi-noob
                • Dec 2017
                • 198
                • Hungary
                Looking at your photo of the board, I would say the second SOT-23 should be Q621. According to the datasheet, it protects from overvoltage. Have you probed it? If it is not shorted, it may have survived. But it doesn't cost too much to replace it also. An other idea to be sure: on the ebay auction you linked, there was a feedback from an actual buyer, maybe you should write him a message, he might remember where does the last SOT-23 go.
                Edit: looked up Q621, nothing special. 60V/150mA NPN type. You can easily find a substitute in case it has gone bad.
                Cheers, Janos
                • neilc6
                  • Nov 2015
                  • 1550
                  Q621 measures 0.7V B-E and B-C in-circuit in diode mode on my multimeter so looks ok.
                  Here is my Digikey cart
                  F602 Fuse 2.5A 250V 507-1180-ND‎
                  Q602 IRF640 N-CH MOSFET 200V 18A IRF640NPBF-ND
                  D608B Zener 36V 1N4753A-TPCT-ND
                  R611 Res 0.3 ohm 3W PPC3W.30CT-ND
                  Q602 NPN 125V 0.8A BCX41TADICT-ND‎ or 45V 0.8A BCW66GLT1GOSCT-ND (original part 2SC5344S 30V 0.8A)
                  D653, D655 SB3100 sub (have spares) SB3100FSCT-ND
                  Just in case
                  D607A Zener 27V SM TFZVTR27BCT-ND
                  D609A Diode CES520 CES520L3FCT-ND
                  • neilc6
                    • Nov 2015
                    • 1550
                    Got my parts in and TV is working. Thanks to R_J and yohnsee for pointing me in the right direction.
                    The 160V I was measuring initially at the main filter cap was just the rectified AC output.
                    D609A was good and I replaced D607A which was probably bad (damaged it removing it). The A suffixes are for surface mount versions and there are pads for the leaded axial versions (non-A suffix) which would make replacing them easier.
                    • R_J
                      • Jun 2012
                      • 9625
                      Good to here you got it working.
                      • reessi
                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                        by reessi
                        Hello:
                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                        I started on the ACER:
                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                        10-29-2024, 11:31 AM
                      • Henke
                        Philips 55POS9002/12 shorted mains
                        by Henke
                        Hi.
                        I have a Philips tv where the two main fuses are blown. I found a bad cap. I removed it, and now it seems to work. But i have to replace the cap. I do not have the exact same one at home. What's the purpose for it and what values can i use instead?
                        Its placed across the Drain and Source on a N/Channel MOS
                        The blown one is 101K, 1KV (check picture). I have 221K, 1KV at home, can i use that?...
                        08-06-2024, 03:51 AM
                      • modtool
                        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                        by modtool
                        Hi to all,
                        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                        04-01-2025, 08:22 AM
                      • BalkanBoy
                        Dead Razer Blade 14 2022, shorted CPU?
                        by BalkanBoy
                        today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                        Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                        I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                        Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                        I removed coil and injected 0.7V, it draw around...
                        09-27-2024, 12:44 PM
                      • barry101
                        Apple 820-3662 VCore shorted to ground.
                        by barry101
                        Hi, Would appreciate some help.
                        I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                        Get charger light but no fan spin or chime. No liquid damage.
                        Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                        Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                        With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                        Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                        06-24-2025, 07:34 AM
