Sharp LC-55N620CU PSU 192020 help ID'ing a transistor
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    #41
    Re: Sharp LC-55N620CU PSU 192020 help ID'ing a transistor
    I would like to thank everyone for all of your help. The parts for the PSU arrived this morning. I plan to install them this afternoon and will let know how it worked out.
    They call me......."threadkiller"
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      #42
      Originally posted by R_J
      3Ω is low for the led of the opto, Did you replace the blown TL431? as for the opto 817b and 817b are the same.
      I believe N881 opto is for turning on the backlight, so don't worry about that circuit now.
      Originally posted by budm
      Something is not adding up since the Voltage on the main cap is stable but the output from the bridge is not, if output of the bridge goes up and down then the Voltage on the filter caps should follow.
      Ok I got everything installed and without messing anything up! Stand-by voltage is still absent and hot side voltages up and down like before.
      With the 1P regulator installed the short there is gone.
      Ok, so where to from here?
      • R_J
        • 9535
        What was wrong with the v810 (1P) The "transistor" 1P is for turning on the backlight circuit
        The "reference ic tl431" that was blown was the GB1 (N851), It's voltage was supplied from 12VQ, so I would check the diodes, on the T831 secondary, VD906/907 and VD819
        Which opto coupler did you replace? or was it both?
        I still think VZ810 16volt zener could be bad, it should have 16 volts on it.
        Check the resistance on the 20 volt line to ground (VD825 cathode) or across C819.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          #44
          v810, 1P transistor base and collector were shorted
          VD906/907 check with expected diode readings. VD819 does not reverse bias but seems to have a low reading of .298 on both legs
          Both OPTOs were replaced.
          VZ810 has 6.87 to 6.95v across it.
          Across C819 there is 99,700ohms
            • 12141
            • U.S.
            #45
            Maybe test your powerboard by itself, see if you get standby voltage and or more stable readings.
            • R_J
              • 9535
              Do you have a 16 volt zener diode that you can replace for VZ810? or a zener around that voltage (12-15v)? There should be 16 volts on that zener, If there is only 7 volts, that V812 whisch is acting like a regulator would only output 8 volts for VDD, this is not enough to keep N834 running
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                #47
                The power supply was out of the TV during testing.
                I may be able to come up with one on another board. There look to be letter markings on the zener, is there a cross-reference somewhere I can use to turn those letters in to a datasheet to make sure I have the right one. or at least one that is close enough?
                • R_J
                  • 9535
                  MMSZ16T1G, I can't make out the letters from here.
                    • 12141
                    • U.S.
                    #49
                    And you're sure your rectifier diodes are ok?
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      #50
                      The letters are WK, picture below. The picture with two Zener's are on a scrap board. Will either of these work for testing?
                      Yes, just checked it again.
                        • 12141
                        • U.S.
                        #51
                        Does T902 check out ok?
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          #52
                          Unfortunately I don't have a way to check transformers, therefore I don't know for sure.
                          • llonen
                            • Sep 2014
                            • 495
                            • hampshire
                            #53
                            If your sure this is a psu board problem, then given the time I would probably opt for an used example, of which there seem to be several reasonably priced examples available to you.
                            https://www.ebay.co.uk/itm/Sharp-55-...8AAOSwhfxZb97g
                            • R_J
                              • 9535
                              The WK diode seems to be a BZT52C13 13 volt zener, put one in and see if that voltage gets to 13 volts, if it does you know the original is bad, no weather the power supply will operate at 13 volts is boarderline
                              this part of the circuit could not be simpler, 160v through 3 series resistors (which you checked are ok) to the 16 volt zener, the voltage at the zener will be whatever the zener is.
                              • R_J
                                • 9535
                                I misread post 50,
                                Here is a pdf of the zeners
                                And if you look at Diodes incorporated
                                WK = 16 volt
                                WM = 20 volt
                                WT = 39 volt
                                I would try and find something closer to 16 volts if you can, if not try the 20 volt
                                Some mfgr's list the WK as 13 volts but I will trust the schematic
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  #56
                                  Well Satirday was a total loss for me, we had 55mph winds here and the power went out for several hours and then a friend of mine showed up and stayed for a while.
                                  Hopefully today I will have time to continue on this.
                                    BTW, you can use LED tester to test the Voltage of the Zener diode.
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #58
                                      Out-of-circuit I'm guessing? I had no idea you could obtain their voltage that way, what a great tip budm! Thank you!
                                        Yes, out off the board, the test current will be only about 30mA. Try it on known good Zener and see what the Voltage on the LED tester display will show.
                                        • DXseekerMO
                                          • Feb 2018
                                          • 1119
                                          • US
                                          #60
                                          I wasn't able to find a Zener in my pile yet, so I popped VZ810 off the board and with the backlight tester it passes 16.9v through it.
                                          This has to mean it is ok.
                                          • michalk3777@gmail.com
                                            Sharp Hisense - LC-65N7004U Error codes
                                            by michalk3777@gmail.com
                                            Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
                                            Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
                                            Regards,...
                                            12-15-2024, 09:20 PM
                                          • DrvLikHell
                                            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                            by DrvLikHell
                                            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                            The...
                                            02-05-2025, 01:44 AM
                                          • Coolgoodman
                                            Faulty Hisense 85Q6NAU TV
                                            by Coolgoodman
                                            85” Hisense TV
                                            Greetings,
                                            Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                            Dear TV technicians of forum, I hope this message finds you well.
                                            I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                            I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                            Today, 03:02 AM
                                          • ShahZaib Ghumman
                                            Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                            by ShahZaib Ghumman
                                            Hey folks,
                                            I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                            A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                            So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                            03-25-2025, 10:59 PM
                                          • nono34
                                            Hisense stuck in Colors cycle like test pattern.
                                            by nono34
                                            I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                            I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                            10-24-2024, 04:31 PM
