Sharp Hisense - LC-65N7004U Error codes
  • michalk3777@gmail.com
    mk3777
    • Nov 2016
    • 33
    Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
    Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
    Regards,
  • lotas
    • Jan 2016
    • 4710
    • Russia
    If it is Hisense, then you need to check the backlight first; due to faulty backlighting, the power supply unit is blocked in them (modern Hisense models)....
    • DrvLikHell
      Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
      by DrvLikHell
      Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
      The...
      02-05-2025, 01:44 AM
    • Coolgoodman
      Faulty Hisense 85Q6NAU TV
      by Coolgoodman
      85” Hisense TV
      Greetings,
      Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
      Dear TV technicians of forum, I hope this message finds you well.
      I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
      I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
      07-24-2025, 03:02 AM
    • ShahZaib Ghumman
      Can I Swap Screens Between Two Hisense 75” QLED TVs?
      by ShahZaib Ghumman
      Hey folks,
      I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
      A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
      So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
      03-25-2025, 10:59 PM
    • nono34
      Hisense stuck in Colors cycle like test pattern.
      by nono34
      I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
      I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
      10-24-2024, 04:31 PM
    • DXseekerMO
      HiSense 55H7B/Sharp LC-55N7000U main boards interchangeable?
      by DXseekerMO
      I recently ordered a main board #189557 for a HiSense 55H7B and was sent a main board for a Sharp LC-55N7000U #192209. I sent it back and asked for the right board. They turned around and sent me back the Sharp main board saying it was the same as the HiSense #189557.
      Am I missing something here? Does anyone know if this is maybe a dual-use board with the HiSense firmware upon it and I just need to call it up from the service menu or something?
      Thanks in advance.
      04-15-2019, 10:23 AM
