Insignia NS-50d40SNA14not turning on
  • henryvrensburg
    • Oct 2018
    • 104
    Hi guys
    I have a Insignia as mentioned in the Title. If plugged into the outlet, the Standby light comes on, but the TV doesn't switch on. I tested the backlights with a backlight tester, seems to be working.
    Voltages on the Power Supply as follows:
    On Main Capacitor = 171V
    ON Connector to Back Lights = 0V on any connector
    On Connector to Mainboard (with Neg probe on chassis)
    1 = 4.114V
    2 = 0.0009V
    3 = 0.945V
    4 = 4.628V
    5 = 0.0009V
    6 = 5.096V
    7 = 5.096V
    8-16 = 0.000V
    I'm thinking it is the Power Supply. You guys have any advise.
  • captainKKK
    • Sep 2018
    • 287
    Re: Insignia NS-50d40SNA14not turning on
    Since the 12v are not present, and the brown cap only has 171 volts, the secondary side of the PS is not turned on, either b/c of a PS fault or a non existent signal from the MB. Try to power on after unplugging CN3. If no 12v on any pinouts, then Check the PS fuses, bridge, mosfets and diodes. Can u provide CLEAR pic of PS?
    • CapLeaker
      Leaking Member
      • 8321
      This PSU doesn't have a PFC, so 171V on the main filter cap is correct.
      Either there is a short on the 12V rail on the main board, dragging the PSU down, or there is a problem with the 12V rail on the secondary side of the PSU. There are some big diodes... have a look at those.
      recheck the backlights again.
      • henryvrensburg
        • Oct 2018
        • 104
        - If I remove connector CN3, the TV does seem to try to turn on, because the Standby light goes out, but I still can't find 12V anywhere.
        - If I power the Backlights with my Backlight Tester, there still is no picture.
        - I tested all the diodes on the board, found the 5V on the D36 and D55, but can't find 12V at any point.
        - I tested the backlights again, they do come on at 89,3V on both strips.
        Bank 1 = 89,3V
        Bank 2 = 89,3V
        Thank you
        • captainKKK
          • Sep 2018
          • 287
          good pics now. How about taking out your paint brush and knocking off the cobwebs everywhere, especially around BS1
          • henryvrensburg
            • Oct 2018
            • 104
            Cobwebs taken care off, sir.
            • CapLeaker
              Leaking Member
              • 8321
              check dm4 diode for a short.
              • captainKKK
                • Sep 2018
                • 287
                Can we see the back of the PS, especially around CN2? Your power pins only have TWO 12vdc wires......on pins 10 and 13. There are no wires connected to 5, 9, 14. We need to see the back of this PS to trace pins 10 and 13. You did not say specifically you got 8, 11, 12, 15 and 16 showing grounded...are they to the chassis?
                • henryvrensburg
                  • Oct 2018
                  • 104
                  The Pins mentioned is grounded to chassis. Herewith photo of back of Power Supply
                  • R_J
                    • 9588
                    Does your voltage on CN2 pin3 change when you press the power button? You are likely not getting the PWR_ON signal to turn on the power supply
                    • henryvrensburg
                      • Oct 2018
                      • 104
                      It stays at the same voltage, doesn't change if I try to switch it on
                      • neilc6
                        • Nov 2015
                        • 1550
                        LED failure is very common in these Insignias. Did you remove the panel to ensure all the LEDs are lit. If one or two are shorted, it may be hard to detect without visually confirming they are all lit. If probing through the LED connector, the voltage readings may not be the same if each wire pair isn't driving the same number of LEDs.
                        • R_J
                          • 9588
                          If the PWR_ON never chainges you will not get the power supply to turn on the 12 volts
                          If you want to rule out the power supply, disconnect CN2 from the main board, connect a 500-1000Ω resistor between 5.1v_STB (pin6 or 7) and pin 3, That should turn on the12 volts.l
                          • captainKKK
                            • Sep 2018
                            • 287
                            After following R_J, report on voltage from PIN 10 and 13 of CN2, my bet that DM4 is bad, check please and report voltages / continuity on the 3 pins of DM4 (darn, that CapLeaker is smarter / faster than me and didn't even see the back of the board). Since CapLeaker can now SEE what he is looking for, I know he knows your answer. Pardon my tracing, but my resolution is not good and I took small guesses on the 2nd one.
                            • patrax
                              • Feb 2014
                              • 33
                              Had this very set come thru about a month ago and fought it for three days till I finally removed the panel completely (Be very very gentle with these and use good quality suction handlers) and there it was staring at me surrounded by 50 some working diodes was the burnt black eyed sob. Replaced all 10 strips in less than 30 mins, BAM working set. Needless to say lesson learned remove the panel and check the LEDs guys very common failure in this brand.
                              • CapLeaker
                                Leaking Member
                                • 8321
                                How did you turn on the back lights then?
                                  • 12268
                                  • U.S.
                                  So whats the report on DM4?
                                  • neilc6
                                    • Nov 2015
                                    • 1550
                                    Bank 1 = 89,3V
                                    Bank 2 = 89,3V
                                    If these are your strips (pic found on ebay and some blog), you have a total of 8 x 4 = 32 LEDs. If they are wired into 2 banks of 16 and you are measuring 89V off each bank with an LED tester, then I would assume they are 6V LEDs and you have one short LED in each bank.
                                    • patrax
                                      • Feb 2014
                                      • 33
                                      Exactly, you have a shorted strips which in effect is really hard to pinpoint.
                                      These sets have some of the weakest leds Ive ever seen.
                                      Every one of the strips I R&Red were yellow around the SMD on the strip and the unit I repaired had really low hours. I initially had thought I could replace just the shorted diodes until I realized just how low quality they actually were.
                                      Play it safe and replace them all if want any reliability at all.
                                        https://www.shopjimmy.com/insignia-5...eprom-only.htm
                                        Symptoms EEPROM replacement MAY fix:
                                        - On screen display is stuck on logo screen
                                        - TV won’t power on with remote or buttons (LED indicator remains same color)
                                        - TV won’t turn on after being off for 30+ minutes
                                        - TV shuts off by itself during channel scan or when switching inputs
                                        - TV turns on and is stuck in color test pattern mode forever
                                        - TV turns on but there is no backlight (LED indicator shows TV is on but there is no image)
                                        • Tomylee
                                          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                                          by Tomylee
                                          Sorry for the person who’s going to read all this !
                                          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                                          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                                          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                                          07-11-2025, 11:52 AM
                                        • 5mall5nail5
                                          Help identifying connector for ASUS 4090 Strix RGB LED connector
                                          by 5mall5nail5
                                          Hi All -
                                          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                                          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                                          05-04-2025, 07:47 AM
                                        • bussincaps
                                          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                          by bussincaps
                                          Hello All,
                                          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                          08-03-2023, 12:57 PM
                                        • michhak
                                          Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                                          by michhak
                                          Hi guys,
                                          i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                                          It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                                          11-17-2021, 05:45 AM
