47ls4500 screen has rainbow color.
  • Diah
    • Feb 2013
    • 6439
    Re: 47ls4500 screen has rainbow color.
    no you cant.. if you did the diy. use it on windows pc with player called win amplifier.. only this work
    • capwizard
      • Jun 2016
      • 1991
      Wow! I did not use windows for 10 years. I use Linux mint. Can I use Apple?
      I do have a desktop pc with Window 7 which I use only to copy eeprom and NAND FLASH. the win amplifier is the media player?
      • Diah
        • Feb 2013
        • 6439
        Originally posted by capwizard
        Wow! I did not use windows for 10 years. I use Linux. Can I use Apple?
        aha.. you are modern user..LOL.. the problem not which system we use.. but the program (Win Ampl ) only available to windows.. this player am sure 100% do the job
        • budwich
          • Jul 2015
          • 3097
          you need to use a system which processes the wav file "as is" and doesn't "modify" it for "post processing" (ie. sending it thru a blue tooth process isn't going to help things). Further, your DIY IR probably needs to be very close to the receiver as freakaftr8 found that the output "amp" of most "head phone jack players" may not have enough juice to drive the leds directly so the output "signal" is somewhat weak.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4463
            • Italy - Milan
            Hi, in the past i have tried too the wav file with a cheap tablet with the volume at the very maximum and a single output led with a generic clear led, i suspect that must be used a specific led took from an lcd era LG remote.. i have'nt any so i can't try..
            • capwizard
              • Jun 2016
              • 1991
              update. Thanks everyone’s help
              (pic1) came today. I found problem was at LVDS bits from 10 bits changed to 8 bits .....tv picture went back to normal ....but ......WHY???
              I tried to change display type from AUO to LG nothing changed.
                Glad to hear that it is fixed, so now you know that bad Gamma can be due to bad Gamma Voltage reference IC or mismatch LCD setting.
                Aren't you glad it is not bad LCD panel?
                • capwizard
                  • Jun 2016
                  • 1991
                  Thank you burn
                  I highly recommend this clone Factory service remote to everyone.
                  Now I'm going to go inside all LG TV service manu. see what's inside.
                  I did change EEFL TO EDGE_LED (THIS TV IS EDGE TV) but nothing happened. I've changed LVDS form 10 bits to 8 bits I always thought pictures may be down grade.
                  Pic1 is IN START MANU
                  PIC2 IS EZ ADJ MANU
                  PIC3 IS EZ ADJ TOOL OPTION 1
                  PIC4 IS EZ ADJ TOOL OPTION 2
                  PIC5 IS EZ ADJ TOOL OPTION 3
                    10-bit /8-bit panel.
                    https://www.walts.com/blog/samsung-s...bit-lcd-panels.
                    Your panel lc470eue(ser1) is only 8-bit.
                    http://www.lcdsolar.com/products/Pro...1#.XFy9KGkrJhE
                    • capwizard
                      • Jun 2016
                      • 1991
                      This is very precious information. so this TV portion of parameters in memory are corrupted?
                      • budwich
                        • Jul 2015
                        • 3097
                        :-) That's what I thought / suggested earlier. Lots of posts with sets that have panel versus capability settings wrong as the company has various "production differences"... glad you found the right combination for the panel that you have.
                        • capwizard
                          • Jun 2016
                          • 1991
                          first i took pictures of the service menu then changed each parameter until I found the correct combination, trial and error, it's kinda stupid but very effective method only took me less than 10 minutes.
                          • cheeky2
                            • Dec 2012
                            • 337
                            #33
                            Aaaagh responded too late as see you have now resolved.
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
                            • spice_disc
                              Vizio TV M50-C1 reboot cycle and static on screen
                              by spice_disc
                              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                              09-08-2024, 02:37 PM
