What's a cheap way to test HDMI's on TVs, suggestions?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hello everyone, I'm looking for a way to test tv HDMI's on the cheap, just wondering if anyone had any suggestions? Thanks
    They call me......."threadkiller"
  • capwizard
    • Jun 2016
    • 1991
    Re: What's a cheap way to test HDMI's on TVs, suggestions?
    DVD player that's what i am using. or GoPro.
    • neilc6
      • Nov 2015
      • 1550
      I use a media player.
      • linksys1127
        • Sep 2016
        • 121
        I use a cheap Roku box.
        • capwizard
          • Jun 2016
          • 1991
          Thank you, that's a wonderful idea.
          I will try that as soon as I get one because it's so compact could fit right in my pocket.
          I never have had Roku before is that needs subscription in order to have HDMI image come out? Is Roku box same as Roku Stick?
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Excellent!
            • CapLeaker
              Leaking Member
              • 8324
              old DVD player, old android box, old laptop, what ever closest to me I use.
              • Diah
                • Feb 2013
                • 6435
                my lovely parts not only to use with HDMI but also for debug my 4K Amlogic Soc HDMI pin.. android .. rotted of curse
                • linksys1127
                  • Sep 2016
                  • 121
                  No need for subscription just WiFi is all as long as you don’t need to play a movie. Home screen will allow you to check hdmi inputs. Not sure about a Roku stick though.
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    No need for subscription just WiFi is all as long as you don't need to play a movie. Home screen will allow you to check hdmi inputs. Not sure about a Roku stick though.
                    Do I need a subscription?
                    Great suggestions all!
                    • capwizard
                      • Jun 2016
                      • 1991
                      Dear Diah, would you please explain what is that ? a USB Bluetooth MP4 player?
                      • CapLeaker
                        Leaking Member
                        • 8324
                        Just search for it in Aliexpress. It's like a android box on a lil stick. Nothing special...
                        • Diah
                          • Feb 2013
                          • 6435
                          yes as CapLeaker said. but its 4K VP9 android HDMI stick. had WLAN and can add USB LAN too. the good to me with this that i can use it for debug via HDMI RX and TX much like other use programmer rt809h which it cost 15 time as this stick of course after install and inject the lib.so file since its rotted .also easy to me as i can use it with mouse. not as DVD or blue-ray ..etc.
                          • ducky29
                            • Dec 2015
                            • 369
                            • Europe
                            Im interesting in this " debug via HDMI".
                            Got any tutorial or video that I can look at so I can learn more about it?
                            • Diah
                              • Feb 2013
                              • 6435
                              similar to this way of HDMI debug only my DIY on android Terminal interface https://www.youtube.com/watch?v=zJARxT9dZxE
                              • capwizard
                                • Jun 2016
                                • 1991
                                ESTGOUS. TV Box Android 8.1 QPLOVE 4G 32G Smart Android TV Box with Backlight Keyboard RK3328 64Bits CPU Support 2.4G Wifi/100M LAN/3D/KD18.0/USB3.0 /H265 4K HD Player
                                The brain of the box is Biritch made ARM 64 bit core. RK3328 ARM Quad-Core 64bit Cortex-A53
                                • CapLeaker
                                  Leaking Member
                                  • 8324
                                  Yep, that's exactly how I do it, like the video shows with the RT809h. You can also download and upload firmware through the VGA port. It is quite useful this little thing, but I mostly use it to flash eeproms with it and I am getting my fingers wet with eMMC's on it as well.
                                  • chth96
                                    How Can I test PWM DM0365R?
                                    by chth96
                                    Hello
                                    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                    06-18-2025, 04:14 PM
                                  • khelane
                                    test active pfc power with lamp test
                                    by khelane
                                    Hello
                                    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                                    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                                    Is there a way...
                                    06-03-2025, 01:00 AM
                                  • chronic519
                                    Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                    by chronic519
                                    Hello.
                                    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                    Found issue with a RAM block
                                    Replaced, green lines gone.
                                    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                    Used a good card to test and same results low errors 32+.
                                    I am just search for some form of command to do a full test on the GPU.
                                    I just ran the mats command with my good GPU and passed after roughly 40 min.
                                    The repaired one, ran...
                                    05-20-2025, 07:56 PM
                                  • Mark01
                                    Dell Optiplex 7490 AIO - red power led after flash
                                    by Mark01
                                    Hi guys,
                                    This is my first post! 🚀
                                    I have no idea what I’m doing, but I’m learning by trial and error.
                                    I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                    07-04-2025, 12:54 PM
                                  • alltvrepairs
                                    Lg TCon test pins for screen test
                                    by alltvrepairs
                                    i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                    Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                    Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                    Appreciate your help....
                                    06-13-2025, 06:33 AM
