Homemade LED tester for tv.
  • capwizard
    • Jun 2016
    • 1991
    Does anyone use their own homemade LED tester? The one can test whole LED screen and individual LED.
    Can you share your experience?
    except the one from shopjimmy. I love to make things myself, not to say that I have no money to buy but l love to do things myself.
    DIY for fun. For led tester I only use the one I made.
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Re: Homemade LED tester for tv.
    https://youtu.be/nZKjmljZqjs Check this. Id like to also add that 20$ for a led tester is a good deal, so you don't spend time and money on the homemade one.
    • capwizard
      • Jun 2016
      • 1991
      Thank you. That is very smart idea.
      But I try to built is a battery protable led tester or the tester could test led screen at the full current. Like an adjustable current and HV voltage power supply.
      • CapLeaker
        Leaking Member
        • 8146
        I use a CV CC variable lab psu.
        • capwizard
          • Jun 2016
          • 1991
          But do you have a cc cv ps up to dc 400v.
          An expensive power supply? Is it too heavy to handle?
          • CapLeaker
            Leaking Member
            • 8146
            Why 400V? Don't need that. You verify that there is a problem with the LEDs, measuring the voltages on each string. Then you have to take it apart anyway, so I just test either the individual LED or a LED strip. My PSU can do up to 60V. Heck most of the time I don't need more than 30VDC. So why using a LED tester altogether? Useless, if you know the proper troubleshooting technique. Save yourself that money and buy something more useful than a LED tester.
            • capwizard
              • Jun 2016
              • 1991
              For ex: samsung 40" up tvs. they will need 256 to 425v to test all the serial led strips at same time. LG tvs have 2 groups led strips will need to isolate the problems and give customers right estimates asap. At least should have 320v. (Ex shopjimmy's tester)
              If I do not use good tester. I opened the screen then found out I am wrong that happened to me all the time.
              I tried to achieve is the one better than the commercial one. With cc and cv Adjustable control and will cast you almost nothing.
              My goal is to help people in Africa.
              • CapLeaker
                Leaking Member
                • 8146
                Then you do something wrong. I mean once you press the power button the TV or monitor tries to start, check the voltages on each LED strip with your DMM and you should already know what is going on with the LED strings. That tells you o.k., do I have juice or nothing, why are the voltages off, what are the control voltages etc. and which way to go next. Never had a problem doing things like that. LED's are CC controlled. If something is going on, it will show up in the voltage.
                • capwizard
                  • Jun 2016
                  • 1991
                  You are so smart, you are a genius.
                  That's the way I am doing. just use led tv power supply from tv and modify to a tester. In theory you can have as many led tester as you want.
                  All you need is a potentiometer and the few resistors. I have been used this kind of homemade tester for for 5 years.
                  • CapLeaker
                    Leaking Member
                    • 8146
                    its just my way of dealing with it.
                    • capwizard
                      • Jun 2016
                      • 1991
                      Every day electronic secret recipe must be remembered .
                      Can this be used on a multi-connector LED screen? I mean some tv has led backlight connector, Connected in parallel Up to 16 connectors. Will this work? or Just patiently test each connector?
                      Do I need a multi-meter with fast/peak min/max to catch the voltage?
                      • capwizard
                        • Jun 2016
                        • 1991
                        This is the tester I've been used for years. Adusteable votage dc 2.6v to 526v. current sets to 10ma or 256ma.
                        The tester inside is a Samsung led tv power board modified with few resistors and potentiometer.
                        • CapLeaker
                          Leaking Member
                          • 8146
                          so you converted it to CV? I mean you adjust the HV up and down, right?
                          • capwizard
                            • Jun 2016
                            • 1991
                            Yes sir
                            Just similar to TL431 I put a potentiometer to change the reference voltage. And then i have a variable, adjustable voltage power supply.
                            The green wires are connected to potentiometer. The other two white wires are for the output.
                            The other side of the power supply board. I changed 12 volt to 24 volt so I can use the T12 soldering iron. I connect a potentiometer to the tl431 after I found the value then I put a resistor over there. So LED screen tester and Power supply for solder iron.
                            Somehow the meter couldn't use the 5V inside the board so I have to use external 5V power supply. I put a USB charger to provide the 5v for the meter.
                            I set the high-voltage to 300v because more than that I begin to have a feeling to the high voltage.
                            Basically if you have any led tv power supply laying around. all you need is one resistor and one potentiometer then you have it.
                            Ps...The potentiometer I used is a 500K from light dimmer with switch.
                              So it is CV supply, so how do you set/limit the LED current to be as specified?
                              • capwizard
                                • Jun 2016
                                • 1991
                                it is one of original factory settings. current control was branch out, became very complicated.
                                it wont be too hard to convert current control to voltage control which i changed Rf2 to potentiometer and Rf2 to a resistor in the picture 1
                                  Dim control will vary the current through the LED or change the existing LED CC sensing circuit that the LED driver already has.
                                  That feedback in your circuit is for sensing the output Voltage so the feedback is used for maintaining the Voltage so it is Voltage control. you need to sense the current flowing through the load to maintain constant current.
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    i knew that but it is very hard to find out cc sense circuits with no circuit diagram. 289ma at 331v was factory setting. 10ma current i used LR8 high voltage regulator to accomplish the job. if it has cc would be wonderful.
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      are both digital and analog dimming can change current of the PS.
                                      for D-Dim how can i built a adjustable PWM?
                                      for A-dim what is the voltage range?
                                        Up load pictures of the board. You can also look for the LED driver IC psec and application notes so you can modify the circuit.
                                        BTW, how do you connect the LED to the power supply board, the Anode of the LED string to the Booted Voltage output pin and the Cathode to chassis GND? or L - return pin, that is important since the LED return circuit is not directly connected to GDN but through PWM Controlled MOSFET and current sensing resistor to maintain constant current through the LED's which your board is made for, low side (active element is on the return side of the circuit) constant current circuit.
                                          Component tester which one is worth the money from it capability to test and identify
                                          by sam_sam_sam
                                          I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
                                          Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
                                          There are so many versions of this type of device and I do not have enough information to make a good decision at this point
                                          When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (...
                                          06-30-2022, 08:23 PM
                                        • nubinator
                                          how can i test individual leds without tester
                                          by nubinator
                                          Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                                          I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                                          10-25-2022, 11:05 PM
                                        • Lifeisfun
                                          Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                          by Lifeisfun
                                          Hi folks!
                                          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                          Eventually I discovered that it was related to moving the laptop.
                                          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                          I removed the board got one of those memory slot testers...
                                          06-04-2025, 02:26 PM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                          FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                                          by sam_sam_sam
                                          https://www.ebay.com/itm/405035016711
                                          I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                                          I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                                          04-13-2025, 08:17 PM
