how can i test individual leds without tester
  • nubinator
    • Jan 2012
    • 37
    Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
    I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8813
    • Fixing Failed Fuhjyyus
    Re: how can i test individual leds without tester
    I usually use 3 or 4AA with a drop resistor to limit to about 10mA, so it can only test LEDs one at a time. However this does not tell the difference between a shorted or open LED nor its ability when at full current (and full brightness).
    One simple mod is use 4AA and a red LED in series with a limiting resistor and the device you want to test, so you can definitively tell the difference between a shorted and an open LED - though in most situations it doesn't matter the failure, if it doesn't light it needs to be replaced anyway...
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4838
      • Italy - Milan
      you have to scratch the bars in the right points and connect the battery, but this simple test is not enough to find those half damaged leds.. you better build a self made led tester with two testing currents, one medium, one very low, with very low one you will probably find those near to full shorted, thus semishorted
      those are 6v leds
      • nubinator
        • Jan 2012
        • 37
        Thanks guys I added another two AAs and found one LED not lighting up at all so thats all the confirmation i need to order a backlight set for it
        • nomoresonys
          • 12370
          • U.S.
          https://www.youtube.com/watch?v=1qi9QS3tRfM
          • ramondo
            Confused Member
            • Jun 2015
            • 40
            • tinkering
            add this electronic circuit to your multimeter and get an amazing option
            https://www.youtube.com/watch?v=SJkx8HRmCTQ
            Mextraf on youtube. I have made this and used a cheap harbor freight mm and it does work.. Try to use a lamp circuit with a transformer on board (safer maybe) I did have plenty of home depot eco smart bulbs that were flikkering of going off after 10 mins.
            Thanks to all for being__WAR_KITTENS____!
            • nubinator
              • Jan 2012
              • 37
              i saw a vid to just bridge the bad LED and i did that and tv all working again. ill keep backlight level low and hope others dont blow.
              I'm surprised nothing broke I dont even have suction tools to lift panel. i copied this guys method and it worked a treat. https://youtu.be/JHvysrIbY1U?t=486
              • nomoresonys
                • 12370
                • U.S.
                ok, but I hope you didn't have that same long awkward trip to where he put it.
                • vladimir1909
                  LlamaTester Alpha V0.1 Macbook Quick test
                  by vladimir1909
                  I would like to share a small MacBook diagnostic application that I've been developing. The goal of this tool is to provide technicians and repair enthusiasts with a simple way to test and gather information about a MacBook. Current features
                  • Display test
                  • Keyboard test
                  • Camera test
                  • Audio test
                  • System overview with relevant hardware information
                  • Charger and power adapter information
                  The application currently works on macOS Monterey and newer versions.
                  Please note that this is still an alpha release, so you may encounter bugs or incomplete...
                  07-09-2026, 12:07 PM
                • howardc64
                  Samsung UN65NU6950 edge lit TV LED bar after 10k usage hours
                  by howardc64
                  Edge lit LED TV has 1/4 section backlight out. Replaced the LED bars and sharing the findings on the original 10k hour LED bar.
                  These are 6V LEDS (reads ~5.4+ on my LED tester) New bars read about 147V per 1/2 of each bar. Clearly original LED bar has some problems
                  • One section is 153v with a dead LED so clearly built up resistance
                  • One section flickers but magically fixed itself after driving individual LEDs. All done with an LED tester so don't know if would work driven by PSU backlight circuit and how long it would last
                  • Connector pin to test pad resistance is nearly 0 ohms.
                  07-07-2025, 12:18 PM
                • PatElectron
                  Denon AVR-X1400H — no audio from any source, internal test tone OK, no HDMI output, "Assigning" phase at every boot
                  by PatElectron
                  I bought this AVR-X1400H (E2, Europe) cheap as faulty, to repair. Seller said it died suddenly: no sound, no picture, headphones silent too. I have the service manual and a **working AVR-X1500H** on the bench as a reference. I've done a fairly complete diagnostic already — full details below so nobody wastes time on ground I've covered.
                  Symptoms
                  - No audio from any source: HDMI, USB, network/HEOS, analog IN1 and IN2, tuner. Nothing, on any input.
                  - The internal DSP test tone plays correctly** through the speakers, on every channel.
                  - No...
                  09-10-2026, 09:11 AM
                • lmcancu
                  LED Strip test points and testing?
                  by lmcancu
                  Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
                  Thanks in advance...
                  03-20-2023, 07:52 AM
                • Pipolups
                  Corsair K70 LUX RGB dying LEDs
                  by Pipolups
                  Hi there !
                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                  10-08-2024, 11:58 AM
