Philips 43PUT4900/12 Stuck in Colour Test
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    Happy Christmas to those that celebrate.
    Can anyone help me with this one please?
    I have a Philips 43PUT4900/12 that is stuck in a colour test mode. When powered on, it cycles between red - green - blue - black - white.
    I've tried the following from the service manual which didn't work:
    How to Exit SDM
    • Switch the set to Stand-by, by pressing the standby button
    on the remote control transmitter or on the television set.
    • Via a standard customer RC-transmitter: key
    in “00”-sequence.
    Here's the service manual:
    https://elektrotanya.com/philips_tpn.../download.html
    Many thanks
  • zomi
    • Nov 2011
    • 511
    Re: Philips 43PUT4900/12 Stuck in Colour Test
    Bad main board ?
    try a replacment mainboard
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Try a firmware update from the philips website
      • Billsy
        • Oct 2018
        • 53
        • United Kingdom
        Ok just tried a software update and it wouldn't run, just continues cycling colours. I'll probably just order a new board next week.
          • 12330
          • U.S.
          May not work but sometimes the update dont work on first try.
          • ducky29
            • Dec 2015
            • 369
            • Europe
            Change the extension to pkg and retry
            • Billsy
              • Oct 2018
              • 53
              • United Kingdom
              PKG didn't work either. I tried both extensions a few times.
                • 12330
                • U.S.
                This might be your board, probably need to match up the numbers on the white sticker with your sticker. https://www.ebay.co.uk/itm/Phillips-...0cM:rk:13:pf:0
                  • 12330
                  • U.S.
                  Maybe try a different usb stick?
                    • 12330
                    • U.S.
                    Update procedure here. https://www.youtube.com/watch?v=IwKt1n8QWOI
                    • zomi
                      • Nov 2011
                      • 511
                      https://tinyurl.com/y854esv7
                      that one is for the 43" £23
                        • 12330
                        • U.S.
                        So whats the difference in those 2 boards, besides 3 pounds?
                        • Diah
                          • Feb 2013
                          • 6562
                          on the main boards you have 2 points listed as SDM, make them short ans start the tv, then turn yours tv out, release the short you did before.. itmay help to bring the eeprom out from sdm mode
                            • 12330
                            • U.S.
                            Ok, I see where the one I posted says 49, might want to go with the 43 to be safe, not sure if they interchange.
                            • Billsy
                              • Oct 2018
                              • 53
                              • United Kingdom
                              Diah, I can't find the SDM pads on the main board. Any idea where they are?
                              Thanks for all the help everyone.
                              • Diah
                                • Feb 2013
                                • 6562
                                your picture not clear. did you check the downside oh MB. if this set didn't listed SDM or SAM or CSM on MB, you still have service port CN410 , use USB to TTL 3.3V the middle are ground and other tow RX and TX , with command you can do allot..also this set with MT chip, on xda developer there are MT tools to play around this MT chip
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4539
                                  • Italy - Milan
                                  Hi, if this "Burning mode" is come on for a settings memory problem (maybe a transient at input) then try to reset it, the modes vary, the simplest way is to try to short circ. the eeprom chip at pins 5,6 when you plug power cord, wait 5 sec then release, first you have to locate it, its the bigger eeprom in capacity size, always a 8 pin ic, this method don't always work, probably there are other combinations like pulling high SCL or SDA or both pins (5 & 6) i.e. SCL+VCC, SDA+VCC or SCL+SDA+VCC at the power cord plug in. The other method to buy a cheap CH341A programmer with clip and erase the chip then power on tv. Sometimes the default eeprom content can be extracted from the update file unless it is compressed, but needs a little study. Last, i don't think entering SDM mode can vary the defect..
                                  • G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                    by G33RT
                                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                    It does power up when pressing the power button.
                                    I already try the power button while plugin the plug with no result.
                                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                    Could this be an PSU or eMMC issue ?
                                    07-19-2025, 03:43 AM
                                  • nono34
                                    Hisense stuck in Colors cycle like test pattern.
                                    by nono34
                                    I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                    I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                    10-24-2024, 04:31 PM
                                  • Stunt
                                    Hp Laptop Stuck on Hp protected by hp sure start screen
                                    by Stunt
                                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                    screen that's it and stuck there. I left it until the following day and i still...
                                    09-02-2025, 01:51 PM
                                  • YellowJacket
                                    SHARP LC-32CHF5111K - stuck at color test mode
                                    by YellowJacket
                                    Hi friends,
                                    TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                    So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                    02-04-2023, 03:11 AM
                                  • chth96
                                    How Can I test PWM DM0365R?
                                    by chth96
                                    Hello
                                    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                    06-18-2025, 04:14 PM
