Vizio E70i-A3 70" Success Story
  • Michale32086
    • Nov 2011
    • 1453
    Another Vizio 70" came in...
    Backlights came on, nothing on the display..
    Think TCON... Get new one..
    Fixes it.. Get a display now.. But it's "off" as in wanky. Right side of the panel is "melting" and "fluid"...
    Thinking I pull the tabs off that side... Did it... It worked!!! It still amazes me when that works..
    My question is, will there be a down side to this?? IE lower resolution, not as sharp, etc etc???
    Just seems to me that there should be SOME down side to pulling those tab boards off the side...
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Vizio E70i-A3 70" Success Story
    Yes, there is a downside. You would lose some scan lines which will lower your resolution. However, this is detected minimal to the eye sight. You would hardly notice the difference. The up side is you still get to use the TV and see movies and images/pictures.
    • Michale32086
      • Nov 2011
      • 1453
      "Yea... Yea, I can live with that..."
      -Keannu Reeves, THE REPLACEMENTS
      Thanx
      • budwich
        • Jul 2015
        • 3097
        Not sure how that can be. This is a "fixed pixel display" so losing scan lines will be visible. Put up a computer screen / fixed image, there are no missing scan lines. There will be some loss of uniformity across the panel as the "one arm drive" will be hard pressed to provide that complete "energy" needed.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          In theory, yes this is what happens but it is hardly detectable. Try it or even search the forum for success stories on removing the side tabs to 'fix' screen issues and save a TV from the e-waste dump.
          • mmartell
            • Oct 2013
            • 3189
            I think the tabs work in a push/pull configuration so no loss in scan lines and the remaining drivers seem to handle the job fine. Mine failed just shy of three years but I still wouldn't attribute that to the fact one side was ripped off.
            Certainly budwich doesn't have to look it up as he was in on it from the beginning.
            • handsworth
              • Oct 2015
              • 175
              I posted a thread asking the same question. Had the same problem and cut the side tabs also. I'm a little closer to my answer now. Thanks
              • Michale32086
                • Nov 2011
                • 1453
                Just a minor nit pick..
                Did you "cut" the tabs?? Or did you just pull them off??
                If you cut the tabs, you might not get the clean break you need.. There might be residual "wiring" or even a short.. From what I have read, it's better to pull them off..
                The best way to do that is to start from one side of the tab (top or bottom whichever is easiest) and pull upward in a single motion.. This allows a clean break and doesn't leave any remnant..
                • handsworth
                  • Oct 2015
                  • 175
                  Thanks, I'll remember that if a next time. I used a razor and cut up against the panel. Do you know what those tabs are for?
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Not really... I am more of a duct tape and superglue/knuckle-dragging ground-pounder kinda tech..
                    • flibidy
                      Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                      by flibidy
                      I have here a Magnum IA.100 which belongs to my parents.
                      The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                      Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                      What Ive done........
                      01-01-2025, 01:26 PM
                    • frannyjunk
                      Vizio M60-C3 left side of screen + a couple other areas dim
                      by frannyjunk
                      My Vizio M60-C3 was dead. No power, no lights. Just nothing. So I took the back cover off and noticed 4 bulging caps on the power supply board, so I replaced them (green low esr capacitors in the picture). The tv now works! But there are some areas that look dim (see picture). In particular, the left side has a dim band. I know that the led strips run horizontal, yet this band is vertical. Could it be that the led driver board is bad? Could the blown caps have taken out the led driver board? Or is this just a coincidence that every left side led on each strip just went out?...
                      11-10-2021, 08:09 PM
                    • rblack711
                      Vizio D55un-E1 COF Lifting Tabs - Not!
                      by rblack711
                      Relatively new to TV repair - as you will see. Rescued this TV from the curb. No backlights, but I could see an image on LCD with flashlight, so suspected bad LED strips. When I got to the part of lifting the LCD off the frame, it was stuck a little bit from some tape used to hold down a thin layer of foam around the frame. I saw 8 tabs on each side of the LCD that I haven't seen on any of the 3 TVs that I have taken apart before. I immediately thought, wow the engineers that designed this were thinking about the serviceman when they put these lift tabs on here - good for them. So I started yanking...
                      08-24-2022, 12:52 PM
                    • howardc64
                      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                      by howardc64
                      Failure Symptom
                      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                      Where is the short?
                      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                      05-27-2025, 02:56 PM
