Vizio D55un-E1 COF Lifting Tabs - Not!
  • rblack711
    • Feb 2022
    • 20
    Relatively new to TV repair - as you will see. Rescued this TV from the curb. No backlights, but I could see an image on LCD with flashlight, so suspected bad LED strips. When I got to the part of lifting the LCD off the frame, it was stuck a little bit from some tape used to hold down a thin layer of foam around the frame. I saw 8 tabs on each side of the LCD that I haven't seen on any of the 3 TVs that I have taken apart before. I immediately thought, wow the engineers that designed this were thinking about the serviceman when they put these lift tabs on here - good for them. So I started yanking on them to free the LCD screen, and it worked really well, but one of them came off. It was then that I saw it was actually a printed circuit - damn! Hope it wasn't important! After replacing LEDs, put it back together, and the backlights worked, but all kinds of funky stuff going on with the image.
    After researching this forum, I found some instances where people reported success by removing all the "lifting" tabs from one side of the LCD. So, I removed the other 7 tabs from the one side, and was amazed to see that the TV is working great now!
    The moral of this story is don't be a dope like me and think these tabs are lifting aids. But I also have a question, why do they install these COFs on both sides of the screen if they are only really needed on one side?
  • lotas
    • Jan 2016
    • 4693
    • Russia
    Re: Vizio D55un-E1 COF Lifting Tabs - Not!
    They duplicate each other, in this case the entire load went to one side (the rest on one side).
    They are placed on both sides with a large diagonal in order to distribute the load
    • rblack711
      • Feb 2022
      • 20
      I don't understand what "duplicate each other" means. They really don't back each other up, because if only 1 out of 16 fails (or detaches), the TV image is nearly useless. But if 8 out of 16 fail (or detach), the TV works perfect. That doesn't make sense to me.
      Anyway, because my TV is now running with 1 side only taking the full load, does this mean the life expectancy has now diminished significantly?
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Rozp
        70LE660U dark cloud or black screen with sound.
        by Rozp
        Hello Everyone,
        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
        08-29-2023, 05:25 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • frannyjunk
        Vizio M60-C3 left side of screen + a couple other areas dim
        by frannyjunk
        My Vizio M60-C3 was dead. No power, no lights. Just nothing. So I took the back cover off and noticed 4 bulging caps on the power supply board, so I replaced them (green low esr capacitors in the picture). The tv now works! But there are some areas that look dim (see picture). In particular, the left side has a dim band. I know that the led strips run horizontal, yet this band is vertical. Could it be that the led driver board is bad? Could the blown caps have taken out the led driver board? Or is this just a coincidence that every left side led on each strip just went out?...
        11-10-2021, 08:09 PM
