Smd wp9f
  • kodiac
    • Jul 2010
    • 121
    Smd wp9f
    I would appreciate knowing where I can find the data sheet for SMD components WP9F and WP9U.
    The 3 terminal WP9F, SOT23 component is from a RCA / Proscan LED TV.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Smd wp9f
    can we see a high resolution pic of the board marked with the location where these supposed to be? Also the model number of the TV and board.
    • kodiac
      • Jul 2010
      • 121
      Re: Smd wp9f
      RCA N14080154 (LSC460HJ04-W) Main Board
      • kodiac
        • Jul 2010
        • 121
        Re: Smd wp9f
        CapLeaker, you still online?
        • CapLeaker
          Leaking Member
          • 8352
          Re: Smd wp9f
          Yeah I am still around, just busy...
          let me guess... you don't have any panel power on that LVDS connector next to it, right? It is probably some lower power mosfet.
          • R_J
            • 9627
            Re: Smd wp9f
            I found this site for the WP9U https://translate.google.com/transla...79&prev=search
            • bman4
              • Jul 2015
              • 210
              • canada
              Re: Smd wp9f
              I had the same thing happen on a diy lcd controller. I accidentally sent 12v to a 5v panel fried the lcd conroler and panel 5v regulator. If you really had to you could connect a diy lcd controller. Im just hopeing it didnt take out panel . if its a 12v panel i think it should be ok. Can u you get a pic of the lcd model.code?
              • R_J
                • 9627
                Re: Smd wp9f
                That wp9 P-channel mosfet is a WPM3407C The (F) and (U) sorry, are the month codes
                The (H)1A is a MMBT3904 I believe (H) is the date code
                • kodiac
                  • Jul 2010
                  • 121
                  Re: Smd wp9f
                  " you don't have any panel power on that LVDS connector next to it, right?"
                  Yes sir that is correct.
                  Thanks for all the information
                  All the WP9*'s are the same type of P-channel mosfet WPM3407C.
                  I replaced a WP9F with a WP9U and the WP9U overheated and burned up.
                  Thanks for confirming the WP9F and WP9U are the same type of p-channel mosfet.
                  • kodiac
                    • Jul 2010
                    • 121
                    Re: Smd wp9f
                    Please help with a blue screen on this RCA RLDED4633A-D TV
                    I have 5v standby
                    I have 12v supply
                    When the TV is turned on I only get a blue screen
                    The Power Button is working normally for on/off control
                    All other Control buttons have no control
                    • mercur
                      • Mar 2017
                      • 6
                      • algeria
                      Re: Smd wp9f
                      The smd codebook
                      • mercur
                        • Mar 2017
                        • 6
                        • algeria
                        Re: Smd wp9f
                        The smd codebook
