MP3414 IAKTH SOT23-8 data sheet help.
  • vikivng
    • Feb 2019
    • 223
    • uk
    Hi guys
    I have a sony tv that doesnt turn on but it gives me the white light followed by 4 blinks.
    Power supply seems ok but was drawn to this regulator.I have seen these chips usually have pin 1 and 2 as input and output respectively. Just wanted to confirm this is the case with this chip. thnx
    I have checked the backlights already and they all work.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: MP3414 IAKTH SOT23-8 data sheet help.
    ? Guess it helps to read the title instead of just post.
    • lotas
      • Jan 2016
      • 4668
      • Russia
      Mp3414
      • vikivng
        • Feb 2019
        • 223
        • uk
        Originally posted by lotas
        Mp3414
        Thnx..This is the sheet I saw yes.
        Just needed to be the sure the dfferent top markings didnt meant the pin out was different.
        Im getting 3.4v VIN and nothing on VOUT. 3.4v at SW
        what shuld I be getting at VOUT? (pin 2)
        • vikivng
          • Feb 2019
          • 223
          • uk
          ?? dont understand what you mean.
          • Lee M.
            LG 55LN5710 backlight diffuser sheet order
            by Lee M.
            Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
            11-29-2021, 07:52 PM
          • lfhlaw
            60LN5600 white reflective sheet
            by lfhlaw
            So I had to replace the LED lights on this TV and that worked out nicely. But the White reflector sheet that helps to diffuse the led lights evenly was glued into the back chassis which had to be removed to replace the LEDs.
            Placing the white reflector sheet caused it to not sit evenly - causing weird diffusing when TV was all put together. Picture is still decent, but now there are dark and light spots due to the white reflector sheet not sitting against the back chassis.
            Anyone have thoughts on replacement white reflector? or do I just scavenge broken TVs for...
            05-23-2022, 07:14 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Topcat
            Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
            by Topcat
            This was rescued from a recycle gaylord from a hospital along with some other things....
            I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
            Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
            08-02-2023, 10:07 PM
            TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
            I would like to know what the specifications for the transformer in this data sheet is I would like to build one
            Also for figure number 8 as well
            Also for figure number 9 as well
            Here is the data sheet I know that this item has been disconnected but I can buy them surplus
            https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
            I have a mad scientist streak in me lately and want to be a little adventurous
            The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one...
            10-09-2021, 06:21 AM
