TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
    • Jul 2011
    • 6068
    I would like to know what the specifications for the transformer in this data sheet is I would like to build one
    Also for figure number 8 as well
    Also for figure number 9 as well
    Here is the data sheet I know that this item has been disconnected but I can buy them surplus
    https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
    I have a mad scientist streak in me lately and want to be a little adventurous
    The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one for this purpose
    Or just use the standby circuit that is for this purpose but then I would have to reengineer the circuit to be able to use just this part of it
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • SluggerB
    Help making a switch work the opposite way with a relay
    by SluggerB
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
    02-07-2025, 07:57 PM
    Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
    Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
    ( needs more cam circuits for the machine to work correctly again )
    https://www.ebay.com/itm/275321870186
    To
    3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
    ( not 4 positions but the right amount of cams circuits )
    https://www.ebay.com/itm/274660439950
    I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
    03-18-2023, 05:12 PM
  • Powderfanupnorf
    Dell AL440LX power on switch circuit help required
    by Powderfanupnorf
    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
    06-24-2024, 01:24 PM
