Need help about "G2920T11U" / "G2990" / "2990(x) SMD SOT23-5 replacement
  • mecmast
    • Jun 2021
    • 19
    • Cyprus
    I've searched the internet but couldn't flnd a replacement/substitute for this part.
    It is marking as "2920N" SOT23-5 case.
    I am looking for the "G2920T11U" 3.3v version.
    Also uploading the datasheet.
    Thank you all.
  • mon2
    • 14661
    I just found this on AliExpress: US $1.74 | (5-10piece)100% New original G2920T11U G2920 29205 2920L 2920 SOT23-5 Chipset
    https://a.aliexpress.com/_mt8PzOp
    • mecmast
      • Jun 2021
      • 19
      • Cyprus
      Thank you But they do not ship to my country
      I've found on Alibaba but never have shopped there. I don't know how to.
      • mon2
        • 14661
        https://e2e.ti.com/support/power-man...-replace-g2920
        • mecmast
          • Jun 2021
          • 19
          • Cyprus
          Thank you
          I've searched and seen it before.
          It has no enable PIN and i couldn't manage how to get 3.3v from it.
          So i have to discard it.
          BTW i've found junk PCBs that have 2920A. I hope it solves the problem.
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
