Smd wp9f
  • kodiac
    • Jul 2010
    • 116
    Smd wp9f
    I would appreciate knowing where I can find the data sheet for SMD components WP9F and WP9U.
    The 3 terminal WP9F, SOT23 component is from a RCA / Proscan LED TV.
  • CapLeaker
    Leaking Member
    • 7982
    Re: Smd wp9f
    can we see a high resolution pic of the board marked with the location where these supposed to be? Also the model number of the TV and board.
    • kodiac
      • Jul 2010
      • 116
      Re: Smd wp9f
      RCA N14080154 (LSC460HJ04-W) Main Board
      • kodiac
        • Jul 2010
        • 116
        Re: Smd wp9f
        CapLeaker, you still online?
        • CapLeaker
          Leaking Member
          • 7982
          Re: Smd wp9f
          Yeah I am still around, just busy...
          let me guess... you don't have any panel power on that LVDS connector next to it, right? It is probably some lower power mosfet.
          • R_J
            • 9515
            Re: Smd wp9f
            I found this site for the WP9U https://translate.google.com/transla...79&prev=search
            • bman4
              • Jul 2015
              • 210
              • canada
              Re: Smd wp9f
              I had the same thing happen on a diy lcd controller. I accidentally sent 12v to a 5v panel fried the lcd conroler and panel 5v regulator. If you really had to you could connect a diy lcd controller. Im just hopeing it didnt take out panel . if its a 12v panel i think it should be ok. Can u you get a pic of the lcd model.code?
              • R_J
                • 9515
                Re: Smd wp9f
                That wp9 P-channel mosfet is a WPM3407C The (F) and (U) sorry, are the month codes
                The (H)1A is a MMBT3904 I believe (H) is the date code
                • kodiac
                  • Jul 2010
                  • 116
                  Re: Smd wp9f
                  " you don't have any panel power on that LVDS connector next to it, right?"
                  Yes sir that is correct.
                  Thanks for all the information
                  All the WP9*'s are the same type of P-channel mosfet WPM3407C.
                  I replaced a WP9F with a WP9U and the WP9U overheated and burned up.
                  Thanks for confirming the WP9F and WP9U are the same type of p-channel mosfet.
                  • kodiac
                    • Jul 2010
                    • 116
                    Re: Smd wp9f
                    Please help with a blue screen on this RCA RLDED4633A-D TV
                    I have 5v standby
                    I have 12v supply
                    When the TV is turned on I only get a blue screen
                    The Power Button is working normally for on/off control
                    All other Control buttons have no control
                    • mercur
                      • Mar 2017
                      • 6
                      • algeria
                      Re: Smd wp9f
                      The smd codebook
                      • mercur
                        • Mar 2017
                        • 6
                        • algeria
                        Re: Smd wp9f
                        The smd codebook
                          TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
                          by sam_sam_sam
                          I would like to know what the specifications for the transformer in this data sheet is I would like to build one
                          Also for figure number 8 as well
                          Also for figure number 9 as well
                          Here is the data sheet I know that this item has been disconnected but I can buy them surplus
                          https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
                          I have a mad scientist streak in me lately and want to be a little adventurous
                          The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one...
                          10-09-2021, 06:21 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • vikivng
                          MP3414 IAKTH SOT23-8 data sheet help.
                          by vikivng
                          Hi guys
                          I have a sony tv that doesnt turn on but it gives me the white light followed by 4 blinks.
                          Power supply seems ok but was drawn to this regulator.I have seen these chips usually have pin 1 and 2 as input and output respectively. Just wanted to confirm this is the case with this chip. thnx
                          I have checked the backlights already and they all work.
                          03-01-2022, 05:00 PM
                        • Nevillet
                          Identifying a 'FS45' SOT23 device
                          by Nevillet
                          Hi All,
                          I'm trying to repair a PCB that has some surface mount SOT23 devices that apear to be transistors but testing them on the board are giving confusing results.
                          Its named FS45 but I can't find a datasheet that seems correct.
                          The device is used in 10 places on the PCB. In 4 cases they appear to be controling triacs and the attached picture it shows it connected to a BT136 triac with the FS45 connected to the gate leg of the BT136.
                          Can anyone identify the device and suggest an alternative?
                          Many thanks.
                          PS: I have...
                          06-19-2024, 11:42 AM
                        • Lee M.
                          LG 55LN5710 backlight diffuser sheet order
                          by Lee M.
                          Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
                          11-29-2021, 07:52 PM
