Testing IGBT with a meter... especially fgd4536 and 30f131
  • budwich
    • Jul 2015
    • 3097
    Read thru lots of posts about fake items so there is great potential for coming across these. Of course, the simple test of the failed units showing a short isn't the point of this post.
    I wanted to get some people's experience with "stock they have on hand" to see if the "simple diode test" tells you anything more about the potential for having a good device (ie. maybe not fake) before soldering it to the board.
    In diode mode, with the black lead on the emitter, and red on the center pin, the meter should read nothing. The test then is to put the red on the gate (opposite side from the emitter) for a short period to charge the gate, then put the red back on the center pin. Doing this with one set of fdg4536, I get a reading of .9v. One of these devices failed during my initial replacement effort. I had some more of these plus another batch. I tested the other batch and them seemed to show 2.6 volts. I used them and the second attempt resulted in two of those blowing their top plus others shorted. Not necessarily blaming them as my soldering maybe suspect but failure all the same.
    I also some 30f131's ("far east" of course) and tried the same test.
    However, I can't get them to "conduct" as touching the gate never seems to switch the emitter collector junction. Are the 30f131 that much different in design than the fdg4536's???
    So my question to others here is... if you have some fdg4536 that you think / know are good, can you do a little test on one of them and state what the results of the diode test is and similarly if you have some "good" 30f131's around can you also try the same thing with one of them and post some of the results.
    I know that the test doesn't give certainty on the "fakeness" of the device but perhaps the simple diode test might reveal something for us "one timers".
    Thanks for any help / results.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Testing IGBT with a meter... especially fgd4536 and 30f131
    I have a cheap "put it together yourself " transistor tester. It is an E.S.R. meter also.
    On it a bad igbt will read as a capacitor. I have also had a few that read only as a resistor. Here is a few pics of good and bad parts.
    • foxyUK
      • 35
      • United Kingdom
      I suggest that you 'knock up' a proper IGBT test circuit as described here:-
      https://alpengeist-tvrepair.blogspot...ansistors.html
      This site has helped me greatly with fixing Panny Plasma sets. I have a batch of 50 FGD4536's from UTSource and they are fine... I can give you figures from the test circuit. All bulk 30F131s appear to be fake and no good long term. Only trust those supplied singly in Panasonic bags.
      The blog also describes some of the 'fun' I had due to fake parts!
      Regards,
      Steve
      • budwich
        • Jul 2015
        • 3097
        Thanks a bunch. That's looks readily doable for even a "one timer diy".
        One question... the blog didn't show testing of the FGD4536 but did they act similar to the 30f131's? The reason for the question is the fdg4536 that I used initially, instead of 30f131, readily were "checkable" with the diode test in the DDM using the method that you described in the blog while the 30f131 showed nothing. Of course, the fdg's didn't survive and hence my post.
        Anyways, I will see what I have around to do the circuit. Meters I got, variable resistor might need some digging... but I got an old "bread board" so it should work out overall.
        • budwich
          • Jul 2015
          • 3097
          I ran a couple of 30f131 using my "crude circuit tester". Of course, I can't tell how "tough" they are (ie. loading) but did see that the gate voltage below about 3.5 volts opened the device (no longer conducts). Above that value, it looks to conduct fine. I haven't tried the fgd4536 but those were "gateable" using the diode function on the meter so I am not cure the test circuit would be much different.
          Perhaps at least the 30f131 that I got are OK... and the fgd's were not good (ie. they blew in the SC board). I do appreciate the comments on testing the igbts.
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            weight is often a factor with fakes ...
            • budwich
              • Jul 2015
              • 3097
              interesting... I don't have a known sample to compare against... but I do have my "marjawana scale" to get an accurate reading if I do get a "benchmark"... :-)
              • petehall347
                • Jan 2015
                • 4448
                • United Kingdom
                simple balance scales fine .. if original to start with all original should balance out . p.s dont tell this to the fakers or they will overcome it becoming an issue with them
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  use the scales you use for gold scrap if you scrap gold that is
                  • andyb1712
                    • Oct 2018
                    • 41
                    • United Kingdom
                    I looked at the link mentioned earlier in this thread with details of the IGBT tester, which in turn had a link to a site https://www.transistormosfet.com/ for sourcing components.
                    Has anyone tried parts from this site and any idea where they are based? I've put a selection of part numbers in from a blown TNPA5105AB and they all show as in stock. Everything is $3 a piece too.
                    • petehall347
                      • Jan 2015
                      • 4448
                      • United Kingdom
                      as a note i have had real ones that wont switch on with my meter but worked perfectly in circuit . so in my view diode test is not reliable even for go no go testing .
                      • chth96
                        Is it possible to test small ceramic disc capacitor with analogue meter?
                        by chth96
                        I read EBOOK of Testing Electronic Component and found that
                        "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                        Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                        It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                        Is it really possible to test small ceramic disc capacitor with analogue...
                        03-09-2024, 10:03 PM
                      • chth96
                        How Can I test PWM DM0365R?
                        by chth96
                        Hello
                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                        06-18-2025, 04:14 PM
                      • khelane
                        test active pfc power with lamp test
                        by khelane
                        Hello
                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                        Is there a way...
                        06-03-2025, 01:00 AM
                      • chronic519
                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                        by chronic519
                        Hello.
                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                        Found issue with a RAM block
                        Replaced, green lines gone.
                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                        Used a good card to test and same results low errors 32+.
                        I am just search for some form of command to do a full test on the GPU.
                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                        The repaired one, ran...
                        05-20-2025, 07:56 PM
