lg 50lb6300 flashing leds after 10 min.
  • bmmc
    • Nov 2009
    • 13
    set came to shop with flashing leds.found 3 bad leds on 3 different strips using SJ led tester.replaced all strips with new ones from SJ.no joy. hard wired and soldered all strip jumpers and connections.also reflowed solder connections on power board where led connecter plugs in.same result.all 5 rows light up at plug in but after 10 min 3 rows begin flashing and nothing from other 2 rows.jumper 2 center pins on led plug all 5 rows light using tester.I'm thinking nothing else could be the culprit other than power board.anyone run into this problem?
  • nwcs
    • Dec 2015
    • 311
    • usa
    Re: lg 50lb6300 flashing leds after 10 min.
    I forgot to add that the some of the voltages to the main board from the PS are reading negative. I found pins 1,2,3,5,6,7,9,10,11,14 and 17 are all in the negative. sorry, I posted to the wrong thread.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        turn down the back lights to next to nothing and see what happens
          He made new thread for his TV: https://www.badcaps.net/forum/showthread.php?t=75053
          • nwcs
            • Dec 2015
            • 311
            • usa
            Yes, sorry I replied to the wrong thread.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              no worries...
              • edugimeno
                About replacing individual LEDS on BL strips
                by edugimeno
                Hi There!
                Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
                At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
                How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
                11-07-2022, 11:12 AM
              • rddube
                LG 50lb6100 flashing backlights unsusual fix!
                by rddube
                Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
                Read all the discussions on the web and on Badcaps (wonderful forum!!) and...
                03-16-2022, 05:46 AM
              • crea2k
                pioneer A-307R flashing leds on front panel, possible short
                by crea2k
                I have a pioneer A-307R here and what it does is flash all of the leds on the front and nothing more.
                I got the thermal camera out on it and saw that Q451 was getting hot, so I removed it and the lights now come on as normal, but obviously that part of the amp doesn't work.
                I tried replacing it, but it goes back to its flashing lights thing again.
                I noticed too that on the back of the board R465 - R467 - R 469 are all getting red hot (over 100 degrees C)
                Im guessing I have a short here somewhere, but so far I have not managed to find...
                10-05-2023, 03:51 PM
              • Akira81
                LG 55LF652V-ZA flashing led bars despite their replacement
                by Akira81
                I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
                If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
                Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
                04-14-2023, 11:50 AM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
