pioneer A-307R flashing leds on front panel, possible short
  • crea2k
    • Oct 2016
    • 32
    I have a pioneer A-307R here and what it does is flash all of the leds on the front and nothing more.
    I got the thermal camera out on it and saw that Q451 was getting hot, so I removed it and the lights now come on as normal, but obviously that part of the amp doesn't work.
    I tried replacing it, but it goes back to its flashing lights thing again.
    I noticed too that on the back of the board R465 - R467 - R 469 are all getting red hot (over 100 degrees C)
    Im guessing I have a short here somewhere, but so far I have not managed to find it.
    I have attached the schematic for this if anyone with a better brain can figure out what is going on here.
  • pni
    Backlight panel diffuser melt by backlight leds broken
    by pni
    Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
    10-12-2025, 12:08 AM
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
  • burntonnerings
    Pioneer VSX-1021 MCACC flashing, can't find problem
    by burntonnerings
    Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
    If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
    Entering reset mode and executing a reset doesn't change this.
    I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing....
    12-09-2023, 10:11 PM
  • EazyBone
    Samsung UN55MU6290F Panel Short, help fixing
    by EazyBone
    So the one guy said the panel short potentially could be fixed so, here's a TV. TV reboots continuously. Backlights work fine. I put some tape on the top ribbon and the TV was able to turn on and get picture. I attached a pic of which lines I taped as well as some other pics of the buffer boards. Appears the "short" is on the right side buffer board. There are no esd diodes that I see.
    Anything can be done?
    03-29-2024, 12:04 PM
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
