LG 50lb6300 voltages are reversed
  • nwcs
    • Dec 2015
    • 311
    • usa
    This TV came in with the picture flashing rapidly on and off. I tested the LED's and they are fine. I then checked to voltages to the led's from the power supply and the voltages were changing from high to low on led+ on the left and changing too fast to tell what voltage's were on led+ on the right. Has anyone ever seen this before?
  • nwcs
    • Dec 2015
    • 311
    • usa
    Re: LG 50lb6300 voltages are reversed
    I forgot to add that the some of the voltages to the main board from the PS are reading negative. I found pins 1,2,3,5,6,7,9,10,11,14 and 17 are all in the negative. sorry,
      You have tow boost converter circuits for two LED strings.
      The two LED strings are not the same size.
      How about good clear straight shots of the whole top and bottom side of the board?
      Also what Voltages did you test on the connector of the power supply board that goes to the main board, what are they? You need to put down pin name of each pin and follow by the Voltage reading.
        Connector has pin name for each pin, so what did you use for GND?
        That has to be reading error.
        • nwcs
          • Dec 2015
          • 311
          • usa
          I do not know why my answer to your last question did not post but here it is again. I put the ground on one of the screws on the back frame.
          1 is pwr-on -
          2 drv-on
          3 3.5v
          4 p-dim1
          5 3.5v
          6 3.5v
          7 gnd
          8 p-dim2
          9 24v
          10 24v
          11 gnd
          12 gnd
          13 12v
          14 12v
          15 12v
          16 nc
          17 and 18 gnd
          even the grounds show neg voltage.
          • budwich
            • Jul 2015
            • 3097
            the point that you are using for "reference" which is the black lead IS NOT at ground potential (most likely floating) and hence any measurement to that "reference" is probably not going to be what you are looking for.
            you can verify ALL your ground points and other areas with the set unpowered / unplugged and measure resistance between various "ground points" that you think should be grounds. They should all measure "0". Once you have determine that, then you can proceed to measuring things again.
            • nwcs
              • Dec 2015
              • 311
              • usa
              I did that and it is a good ground point
              • budwich
                • Jul 2015
                • 3097
                check your batteries in the meter... maybe.
                you checked the resistance between the "third pin" on the power in connector with rest of set grounds. Further, you checked the power cable.
                  Just to be clear, you are saying that the 3.5V, 12V, and 24 all shown as - 3.5V, -12V, -24V? Can we see the probes hookup and the screenshot of the meter display?
                  All the boards are screwed down, correct?
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    I should add that when I first turned it on the tv worked fine and it took several days to start to strobe and guess what it is now working just fine and most likely will for days.
                      Turn down the backlights level on all input to as low as possible to see if it has any affect on the symptom.
                      • nwcs
                        • Dec 2015
                        • 311
                        • usa
                        I will and run it for days again to see if it fails
                        • nwcs
                          • Dec 2015
                          • 311
                          • usa
                          I turned down the backlight on all inputs to 50% and it ran fine for one day. I turned it on this morning and back to the same problem. I ordered a power supply since the main board is not available and I will hope that is it.
                          • R_J
                            • Jun 2012
                            • 9551
                            I suspect the ground screws are not power supply ground, Use P205 or P204 near T101 transformer for ground, or use heatsink (HS4)
                            • frannyjunk
                              • Oct 2010
                              • 78
                              Did the new power supply board fix it?
                              • nwcs
                                • Dec 2015
                                • 311
                                • usa
                                No, it ended up being the main board. I did fix it and it is out the door.
                                • frannyjunk
                                  • Oct 2010
                                  • 78
                                  Do you remember if you replaced the board, or just a component? If component, which one? Thanks!
                                  • Capacitorial
                                    Powersupply has all the voltages - Monitor still no power
                                    by Capacitorial
                                    Hello guys,
                                    I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                    I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                    On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                    The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                    The weird thing is, that the Power LED is powered over the TCON board.
                                    On The TCON...
                                    12-28-2024, 02:12 PM
                                  • Pipolups
                                    Corsair K70 LUX RGB dying LEDs
                                    by Pipolups
                                    Hi there !
                                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                    10-08-2024, 11:58 AM
                                  • THE GTC
                                    Insignia NS-37D20SNA14 intermittent LEDs
                                    by THE GTC
                                    So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                    When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                    11-03-2020, 02:40 AM
                                  • seppde
                                    AMD Desktop Kit - no display, no POST (?)
                                    by seppde
                                    Hey,
                                    I've recently sold a PC and (trying to reduce e-waste) told the buyer to bring me his old setup, and I'd take a look at it. Recently I've been trying to repair laptops, mainly, with so-so results.
                                    I'm now looking at an AMD Desktop Kit with no display. Apparently this board reuses (possibly defective) Playstation 5 chips 4700s. It does not provide an internal GPU, or better say in any case it doesn't provide an output for the internal GPU.
                                    There was one obvious fault: One of the caps of the CPU power rail was missing, that happened when the previous owner was changing...
                                    12-03-2024, 12:09 PM
                                  • sorrowfulfloyd
                                    Samsung UE32J5373AS Weird LED Problem
                                    by sorrowfulfloyd
                                    Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
                                    This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
                                    12-23-2022, 07:00 AM
