About replacing individual LEDS on BL strips
+ More Options
Posts
  • edugimeno
    • May 2017
    • 568
    • Spain
    Hi There!
    Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
    At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
    How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I can see the LED lighting up very dim, due to the low voltage applied from the multimeter in DIODE TEST mode. Can I trust this level of brightness to compare to other LEDS in order to find a compatible replacement?
    Would you also just "jumper" an individual LED just to skip it? Maybe with an equivalent resistor?
    Thanks a lot!
  • neilc6
    • Nov 2015
    • 1550
    Re: About replacing individual LEDS on BL strips
    LEDs wear and burn out just like light bulbs and it is recommended to replace all the LEDs with new instead of individual replacement. New strips are relatively inexpensive these days. If I can't find new strips or if they are too costly, I will do an individual replacement and turn down the backlight level. LEDs typically fail short circuit and in models with shutdown protection, the decreased sense voltage will trigger protection shut down on the LED controller.
    • edugimeno
      • May 2017
      • 568
      • Spain
      Yes I've been purchasing them at between $10 and $20 each SET, so that's not bad, but to get that price I need to get them from Aliexpress and it has taken up to 3 months for the shipping some times here to Spain. That's why I would like to get my best with what I have at hand (used strips)
      Everytime I've replaced led strips I've asked the user to keep the BL level at LOW-MID to make sure it won't happen again. Also on LG's that have gone purple due to LED decay I've done the same
      But still I would like to know the conditions I need to check to replace individual LEDs and know what to check for compatibility, in case I ever take that route.
      Thanks!
      • alfatv
        • Sep 2020
        • 353
        You can check this thread to get an idea:
        https://www.badcaps.net/forum/showthread.php?t=92999
        Main differentiators are TV brand, size, shape, pads, voltage, color.
        • tmhobadcap
          • Apr 2019
          • 146
          • CANADA
          I have come across with 3V, 6V, and 9V leds. When I replace them, I will use a power supply to apply the required voltage and check the current it will draw. Then choose an led which draw the same or closest amount of current for the replacement. Of course, I will choose the one with the same or similar size.
          Please note, I did not studied electronics in college. It is just one of my hobbies. I would also like to know the correct way to do so.
          • edugimeno
            • May 2017
            • 568
            • Spain
            Ok so you measure current flowing while applying right voltage, but how do you find out the right voltage before? Trying from 3V then 6V then 9V?
            • tmhobadcap
              • Apr 2019
              • 146
              • CANADA
              The power supply I use is with adjustable voltage and adjustable maximum current.
              When checking if the led is good or bad, I will start with 3V and limit the current to 20mA. If the led lights up and draws 20mA, then the led is 3V and is good. If the led does not light up but still draws 20mA, then the led is bad and is shorted. If the led does not light up and draws 0mA, then the led is either bad (open circuit) or not 3V. This can be confirmed by using higher voltage, like 6V and 9V or testing other leds from the same tv. If you do not have such power supply, you may need to add a resistor to limit the current.
              When finding the matched replacement led, then set the current to about 1 or 2 A.
              • edugimeno
                • May 2017
                • 568
                • Spain
                Ok, at this time I don't have an adjustable PS at hand so I guess I will use other ways to provide incremental voltages to the LEDs and try
                Will see as soon as I got one to repair.
                Thanks!
                • VitalComputing
                  Replacing Mode Indicator LEDs
                  by VitalComputing
                  I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                  I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                  I thought I could just put a resistor...
                  09-17-2023, 04:43 PM
                • Kingfreddie
                  LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                  by Kingfreddie
                  Ok.. this is the story:
                  Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                  This is kinda how it looked, just that mine were at the bottom of the screen:
                  09-11-2021, 01:57 AM
                • Pipolups
                  Corsair K70 LUX RGB dying LEDs
                  by Pipolups
                  Hi there !
                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                  10-08-2024, 11:58 AM
                • lmcancu
                  RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                  by lmcancu
                  Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                  Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                  Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                  Instead of putting it back together I decided to replace...
                  04-01-2023, 01:11 PM
                • nubinator
                  how can i test individual leds without tester
                  by nubinator
                  Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                  I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                  10-25-2022, 11:05 PM
