I was given a Sony XBR65x900c tv for free with no known condition. My house was struck by lightning last year so I have some experience replacing boards on TV's. So I purchased a board from ebay that was supposedly in new condition just had a broken screen. Installed the board and still nothing. I tested volts and the stand by voltage seems low at somewhere around 2.5 volts. Not sure if this is normal but open to suggestions on what to do next. Thanks
Sony XBR65x900c No Power
Re: Sony XBR65x900c No Power
For us to help you, we will need good clear pictures of the whole backside of the TV showing all the boards, and the straight shot pictures of the whole top and bottom side of the power supply board so we can read the printed texts on the board.Never stop learning
The standby voltage should be 3.3 volts, Is the stby voltage the same with the original board?Last edited by R_J; 09-05-2018, 10:13 PM.
Originally posted by vinceroger69 View Postyou say your house had a lightening strike a lot of times we see its the mainboard at fault as per above post what board did you replace?The board that I replaced had the power plugged directly into it so I am assuming its the power board but I really have no clue. I ordered what was called the static converter board off of ebay so we will see if that fixes it.
Originally posted by justintime_3 View PostSo my house had been struck by lightning before but this tv has never worked since it was given to me so it has not been struck by lightning yetThe board that I replaced had the power plugged directly into it so I am assuming its the power board but I really have no clue. I ordered what was called the static converter board off of ebay so we will see if that fixes it.
Originally posted by Andrew F. Ali View PostWithout measuring voltages on the Power and Main Bds. you are guessing and would just be replacing Bds hoping for a fix. I think you have a Main Bd problem though and you should invest in a DMM to check if the PS-ON signal is produced.
Well I just have a basic multimeter as seen in the pics. The ground that I was using was just a chassis ground that you would mount to the wall hangar. Also the board that was in it originally had the same voltage as the replacement one from eBay so I am assuming the power board is not the problem.
ignore wrong thread sorryLast edited by vinceroger69; 09-07-2018, 10:31 AM.
