panel or Tcon ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    panel or Tcon ?
    Hi, not been on for a while. have a Panasonic tx-48cx400b which has 1 side of screen faulty. is it T-con or screen itself ?
    video is here : https://www.youtube.com/watch?v=Wm1ZBgaT1oA
    Re: panel or Tcon ?
    Panel's knackered.
      Re: panel or Tcon ?
      Originally posted by tom66
      panel's knackered.
      +1
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        Re: panel or Tcon ?
        thanks guys, was afraid it was panel. bad luck on this one i guess.
        • x_orange90_x
          • May 2015
          • 765
          Re: panel or Tcon ?
          I would check the tab bonds just to be sure. That's the exact same symptoms my Sony KDL-46XBR4 had when I got it. Half the screen dark with horizontal bands and ghosting.
          • budwich
            • Jul 2015
            • 3097
            Re: panel or Tcon ?
            you can likely save the panel using the tape cutoff method that uses a piece of tape to block some pins on the tcon if there are no side tabs. if there are side tabs, then the save involves removing those on the dark side and the picture will be good. lots of threads on this type of save.
              Re: panel or Tcon ?
              Only applicable for the larger panels that have two drivers, one for each side.
              It's a 48" Panasonic likely using a cheap Chinese panel by TCL, so who knows? But seems unlikely.
              • budwich
                • Jul 2015
                • 3097
                Re: panel or Tcon ?
                IF there are side tabs....otherwise try the tape cutoff method.... it will likely be saveable
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
