Questions about running coax under ground in conduit
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I'm not sure if this is the correct sub-forum, but it is tv related, so I thought I should post here. If this is the wrong place, could a moderator please move this post to a more appropriate place?
    We need to run a new line from the pole to the house. Our cable provider is coming out Sunday to discuss how we're going to do this and what they will do, what I'll do.
    I have no issues getting up on their pole to hook up the cable, but I think they might.
    Anyway, this was the idea. I run 1/2 PVC schedule 40 (Cantex) conduit from where I want the entrance point at the house, underground, buried, 18", to the pole.
    This is where I'm struggling. I want the conduit to go up the pole. Regardless of whether they allow that or not, the conduit is going to have to come out of the ground sooner or later and the coax is gonna have to make it to the top of the pole. I need that end, where the coax comes out, water tight, so water cannot drip down into the conduit.
    Are there special ends that someone can point me to that are made for this? I couldn't find anything on google. I thought worse case, I could use something like the RACO Non-Metallic 1/2 in. Sheathed Cable Connector that Home Depot sells and just use some sort of water proofing caulk, but if there's an actual end that's threaded that I can just screw into the conduit, like I use when I run romex, but made for outdoor use and made for coax, that would prevent water from coming into the conduit, I'd rather go that route.
    Here's a picture of the ends I use for the romex:
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    Re: Questions about running coax under ground in conduit
    As far as I know out here in my city, any wiring inside your house is your responsibility, anything from outside is the utility/cable/phone company responsibility to keep it in working order, they will not allow you to do any change to the outside wiring.
    • Spork Schivago
      • Mar 2012
      • 4734
      When they were fixing my neighbors cabling, I had asked them about me running conduit underground, and they had said if I ran it to the pole, they would run it the rest of the way, however, this was when it was Time Warner, not Spectrum.
      Come Sunday, between 1200 and 1300, they're sending a tech to discuss our various options. The guy said one option might be they do it all and pay for it all. The other might be I run it to the pole, they do the rest. Regardless, we need a new entry point into the house.
      I'm hoping the tech will allow it. The last one said they would, but things change. I called the code enforcement office and talked to the code enforcer about it and he said because it's low voltage, he doesn't care. I asked if I needed a permit, he said no. I don't really understand why not though. How will the city know where the conduit is if I don't submit the drawing? But he says they don't care about low voltage and just run it.
      I thought that was a bit odd.
      • diif
        • Feb 2014
        • 6978
        • England
        I'm guessing they don't care as there is no harm to them if they put a spade through it.
        • Spork Schivago
          • Mar 2012
          • 4734
          Yes, but it kinda sucks for the homeowner (whether that's me or a future homeowner).
          I think what I'll do is create a drawing anyways, if Spectrum / Time Warner allows me to go the route I want to go, for references, and just pass it down if we ever sell, or because of my bad memory, reference it if we ever have any digging done.
          So, assuming Spectrum / Time Warner are still okay with the underground, I still need to find a way to seal the PVC that will be by the pole or on the pole.
          Rain is a more easier fix. I could go straight up, use a 90 degree elbow, go out a little, and then another 90 degree elbow, so where the cable comes out is facing towards the ground.
          But insects is something I'd like to avoid. I don't really want to use some sort of sealant because these cables seem to expand and contract because of the weather, hence the little loops they have on the house, and where it taps into the cable line on the pole.
          I had two ideas that I thought might work. One was trying to find a top that had something like a rubber seal covering almost the entire top (except the outer perimeter, which would be PVC), and then there'd be just a small hole to push the coax through. I'm not sure a product like this exists though. I've been looking and not finding anything.
          The other idea I had was to just take a cap that completely caps off the PVC, and drill a small hole through it, where I could push the coax through, but not too easy like. It could still expand and contract, and if I use the 90 degree elbow ideas, rain wouldn't be an issue.
          Do any of you people have any other ideas or know if there's such a product like the first one I suggested?
          Thanks!
          • budwich
            • Jul 2015
            • 3097
            you need to bend the conduit (either with heat or otherwise) in a "U" so that it is pointing down (assuming its running up the pole base some distance). Then, the "incoming cable" will go down past the "U" and up again. This forms a "drip loop" so to speak to prevent water that is coming down the incoming cable from following it into the conduit and further protects the conduit from water directly going down into the conduit.
            • CapLeaker
              Leaking Member
              • 8324
              a: I'd run conduit too
              b: I'd be doing that what budwich said
              • Spork Schivago
                • Mar 2012
                • 4734
                I was just going to use elbows to make that U shape. I'm thinking the same for the water, but I still want to keep insects out. If I seal it completely, I think that will be bad, because it needs to contract and expand (the coax).
                I've talked to the cable company. They sent the tech, but after talking to him, he called his boss, and they're going to let me run it up the pole myself.
                That's something I don't really want to do, I thought they'd let me run it to the pole, and I could provide the rest and just tell them what to do. But nope, I guess I get a ladder, run it up, and when it's done, call them and they'll hook the actual wire up to their drop or whatever you want to call it.
                I was going to use my RG6 quad shielded cabling, but the tech really thinks I should go for the RG11, and in all honesty, if I don't run the RG11, it'll probably haunt me at night....I dunno.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  I called the city and figured for at least the digging, I'd need a permit, but code enforcer says he really don't care about low voltage wires and no permit needed, just talk to the cable company and see what they want done or how they want it done.
                  I talked to them, they were good, and they're letting me do it, but even letting me go up the pole, which I don't really want to do. Anyway, they said I'd be dealing with Spectrum Business by the time I got it hooked up, not regular Spectrum techs.
                  We're not switching to business though. I've called and talked to them a few times, looking for a business account that works for us, and there just isn't. Also, our state says they're kicking Charter (who owns Spectrum) out of our state. I guess they have two months to get out, because they been doing some unsafe stuff, haven't done what the state said they had to do, etc.
                  It'll be interesting to see how this plays out.
                  • angelos
                    • Dec 2012
                    • 573
                    • South Africa
                    Normally coax that i buried in a conduit needs to be protected from the inadvertent accumulation of moisture. We use a polyurethane type that reduces moisture ingress. Its a little more expensive but lasts longer.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Is that "coax tape" or something else? If you don't mind sharing the name of the product with me, I certainly could use it, although, I believe this project is now going to have to be postponed until next summer.
                        https://www.cablewholesale.com/suppo...ial_corner.php
                        https://www.anixter.com/en_us/produc...Cable/p/CS5730
                        Notes, Outdoor: NO NOT OUTDOOR GRADE MATERIAL
                        Notes, Dielectric Material: FPE-FOAMED (CELLULAR) POLYETHYLENE
                        Direct Burial RG6 Coaxial Cable: https://www.primuscable.com/store/c/...ial-Cable.aspx
                        RG6 vs RG59: https://sewelldirect.com/learning-center/rg59-or-rg6
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          Thanks. I love how the RG6 vs RG59 page shows the signal loss for the two cables.
                          You think I should stay away from the hardline, like this: https://www.anixter.com/en_us/produc...Cable/p/B1618A
                          I see they make low-loss RG6.
                          I'm staying away from the RG59. I have RG6 for inside, but was questioning whether I should keep that or run RG11 instead.
                          I like Belden a lot. I'm also trying to future proof a little (I know that can be hard). It seems people are slowly making the shift to 4k, and it might not be too long before we have 4k in the house (maybe another 10 years?) Granted, by then, coax could be completely dead. Here, we have the option of fibre for television, internet, and phone. That might be the future. I'm trying to decide if it's worth spending a lot on good coax that we currently don't need, or just good coax that supports our current needs.
                          Thanks BudM!
                          Last edited by Spork Schivago; 08-20-2018, 07:03 AM. Reason: Added future proofing shit
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            We have been in touch with Belden and our distributor. We have a quote for Belden 1525A.
                            Attached is a datasheet for the 1525A. I was hoping instead of Bare Copper Covered
                            Steel, we'd be able to find something that was pure copper for the conductor, but after talking to Belden, they confirmed we wouldn't really find anything better that fit our requirements (direct burial, okay for sunlight, RG11, 75 ohm impedance, etc).
                            What do you guys think? Thanks!
                            • angelos
                              • Dec 2012
                              • 573
                              • South Africa
                              The information that budm sent you is spot on. Couldn't have said it better myself.
                              • FALKLAN
                                Running Line Voltage and Integrating LED Pods - Automotive
                                by FALKLAN
                                Howdy everyone! I hope all is well where ever you are!
                                I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                02-05-2025, 12:30 AM
                              • mkdj
                                Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                                by mkdj
                                Dear all,
                                I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                                I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                                Both N-Channel Mosfets: nothing odd
                                P-Channel MOSFET number 1:
                                source - drain : 117 kOhm
                                source - gate: 96 Ohm
                                gate - drain: 117 kOhm
                                P-Channel MOSFET...
                                08-20-2025, 06:08 AM
                              • barry101
                                Apple 820-3662 VCore shorted to ground.
                                by barry101
                                Hi, Would appreciate some help.
                                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                Get charger light but no fan spin or chime. No liquid damage.
                                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                06-24-2025, 07:34 AM
                              • rumpumpel1
                                ThinkPad X1 Carbon 4th Gen running only at 400 MHz
                                by rumpumpel1
                                Oberservation:
                                X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
                                In rare cases (1 out of 20) it runs at normal speed.
                                It does so when running on battery or only with the charger.
                                When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
                                The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
                                Flashing CleanME and a different BIOS made no difference.
                                Intel's XTU utility...
                                09-18-2023, 06:13 AM
                              • Kambi13
                                Samsung NP370E4K No backlight running on battery
                                by Kambi13
                                Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
                                Tried different battery - no change
                                Tried different screen - no change
                                Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
                                09-04-2023, 11:06 AM
