Acer TravelMate P214 - N19Q7 main power rail shorted to ground
This topic has been answered.
  • mkdj
    • Mar 2025
    • 49
    • France
    Dear all,
    I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
    I have checked resistance across each of the 4 MOSFETS. I have the following readings:
    Both N-Channel Mosfets: nothing odd
    P-Channel MOSFET number 1:
    source - drain : 117 kOhm
    source - gate: 96 Ohm
    gate - drain: 117 kOhm
    P-Channel MOSFET number 2:
    source - drain: 6 Ohm
    source - gate: 93 Ohm
    gate - drain: 98 Ohm
    It seems to be that at least P-Channel MOSFET number 2 is dead and should be replaced (maybe also P-Channel number 1). Am I right?
    My other question is: could this MOSFET be the cause of the short to ground of the main power rail? Or this is an unrelated issue, and I will still need to find the shorted component on the main power rail?
    Regards,
    mkdj
  • Answer selected by mkdj at 08-22-2025, 06:39 AM.
    mon2
    • 14746
    At this stage, inject a voltage of 1v (not higher) onto the main rail. This will force the power supply to sink some current onto the same rail and the shorted part will heat up. Perhaps the CPU will heat up so test without a heatsink or could be a shorted cap. Ideally you will use a thermal camera but if not available, the part may dissolve on its own from the current draw. Use 3A-5A on your power supply for this injection. If you suspect a region on the board to be shorted, pour some IPA (alcohol - pharmacy grade is great) and watch who evaporates faster due to the heat generation.
    We use the 'short killer' product from Aliexpress but many clones out there now. Ours claims to offer 30A peak current and we dial it up to 0v8 for the injection. The idea is to inject a voltage lower than the lowest power rail on the board to protect from further damage.
    • mon2
      • 14746
      Both of these P-channel mosfets are suspects. A good mosfet should be hundreds of k ohms or higher (when measured off the board).
      Start with #2 mosfet -> flux and remove it and then test the resistance again when it is cool and on your work bench. Still this low in resistance? If yes, replace it.
      Repeat with #1 mosfet. Also confirm that the main power rail is no longer shorted with these parts off the board.
      • mkdj
        • Mar 2025
        • 49
        • France
        Dear mon2,
        I have replaced mosfet #2 (values off the resistance were low when removed from the board, and cool). After measuring again mosfet #1, the values of resistance are good. So my 4 mosfets are good now.
        Now, when I plug the board to my power supply, the board draws 17mA, and after one second there is a current peak and a really brief voltage fluctuation, and I can hear a small click from the board. It goes back to 19V and 17mA for a second, then another click, and this happens every second. When I activate the Over Current Protection of my power supply (set at 2.3A), it stops after the first peak, which I believe means that the current peak is more than 2.3A.
        Also, there is still a short to ground on the main power rail (I have measured it at the shunt resistance). I believe I have to find the short now. Can I inject voltage after the shunt resistance, and if not, how can I know where to inject without boardview or schematics?
        Regards,
        mkdj
        • mon2
          • 14746
          What is the exact resistance to ground for the short on the main rail?
          Remove all power. Meter in resistance mode. Touch your meter probes together. Note the resistance.
          Place one meter probe on the main rail. Other probe on the numerous inductors near the CPU. The CPU will always be a multiphase power supply with a mix of power supplies to share the heavy currents.
          What is the resistance between these points of measurement? We are testing to see if there was a high side mosfet that has leaked. Then it is usually game over since the ~20v has hit the CPU rail.
          • mkdj
            • Mar 2025
            • 49
            • France
            Dear mon2,
            Resistance to ground for the short on the main rail is 1 Ohm.
            When I touch my meter probes together I read 2 Ohm.
            Resistance between main rail and inductors are for instance 5, 8, 60 Ohm, on three different inductors.
            How bad is this?
            Regards,
            mkdj
            • mon2
              • 14746
              • mkdj
                • Mar 2025
                • 49
                • France
                Dear mon2,
                I have found the short on the main rail. That was a capacitor. I removed it, and I don't have a short on the main power rail anymore. I haven't replaced this capacitor yet. Also, I eventually had to change the second suspected mosfet. Now I have 19V on the main power rail (measured at the shunt resistance). I have checked voltages at some coils, and I have 3.3V at one of them. I have 0.22V on another, but no voltage on the others.
                I have put the motherboard back, plugged the CPU fan, the screen and the keyboard for the power button. When I press the power button, I have no image, and the fan starts, but stops immediately. Current drawn by the board stays at 370mA, and nothing else happens.
                I have checked resistance to ground of the inductors, and I have fairly low values on many of them, like 290 Ohm, 4 Ohm, another 4 Ohm, 21 Ohm, 55 Ohm.
                EDIT: I had not put back the RAM... Now I have, and it works, I have picture!
                A big big thank you mon2 for your help! I have one last question: do I need to replace the bad capacitor? What are the risks if I don't replace it?
                Regards,
                mkdj
                • mon2
                  • 14746
                  Congrats on the successful repair!
                  While you can share the exact location of the cap for a review, the cap does not need to be replaced. The logic here is that the designers will majority of the time apply multiple caps on the same line for filtering the ripple of the power supply. Respectively, if this one cap is missing, will the power supply halt from operating correctly? No. You will be fine. If it keeps you up at night, certainly order a few spares of this part for a future replacement project.
                  • ganiboy76
                    Model: Acer P214-52 Model No: N19Q7 SHORTED MAIN PWR
                    by ganiboy76
                    Good day.
                    I would like to request a schematic diagram or board view for the following laptop?
                    board id: DAOZ8IMBACO REV: C
                    thank you​
                    02-19-2025, 09:32 PM
                  • HERETIK10
                    MSI GT70 2PE Voltage dropping on the main power rail
                    by HERETIK10
                    I have a strange problem (for me) on an MSI GT70 2PE laptop.
                    When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                    The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                    On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                    I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                    11-24-2023, 06:06 AM
                  • exerion5000
                    ACER MODEL N19Q7 TRAVELMATE P214 SERIES TPM214-52-57H0
                    by exerion5000
                    Hi Everyone,i need help with this BIOS , Unit POWER-On but No Video signal in screen (Black screen), same by HDMI , i suspect corrupted BIOS , i try download fron ACER support site but the extacted file size is 16mb (for 128mb flash memory) , the flash size of this unit is 32mb (256mb flash memory) and connot find where download,maybe someone can fix the original bios attached,thanks in advance!
                    Brand : ACER
                    Model : N19Q7 TRAVELMATE P214 SERIES TMP214-52-57H0
                    S/N : NXVLMAL0021431F26C7600
                    SNID : 14312759676
                    Motherboard P/N : DAZ8IMB1AA0
                    WINDBOND 25Q2...
                    06-29-2025, 04:21 PM
                  • reeluff
                    LENOVO P1 G1 (X1 EXTREME) 0.8V MAIN POWER RAIL [LPM-1]
                    by reeluff
                    No shorts on any main power rails.
                    All power mosfets over the whole board test good.
                    Have 20v into first DC in mosfet, when power button is pressed main power rail is at 0.8V. Not sure if it is the EC or BQ creating that 0.8V or?
                    The 2 input DC mosfets are not driving voltage, 2nd mosfet is N channel and no 25V on the gate. Again is this coming from the EC or BQ chip.
                    BQ chip has 25.6V at ACDRV.
                    Thankyou
                    01-23-2024, 11:25 AM
                  • Mugar
                    asus fa507re - hn021 plyta DA0NJNMBAD0 REV D model NJN - no reaction, main power rail shorted
                    by Mugar
                    Hey guys got laptop like above. Came to me with shorted main power rail and battery protecion on ( 0V on output). Got rid of short but nothing. Bench power supply says it takes nothing, but still got all voltages 1,2v,3.3v,5v - all good. Thermal cam showed nothing is starting even for a sec. I believe that since all coils etc are good resistance to ground it's probably one of chips. Can be IO chip or maybe something else? Could somebody help me out with this one - it's blowing my mind lol
                    05-12-2024, 01:53 AM
