2011 Panasonic TC-P50S30 IS DEAD
  • budwich
    • Jul 2015
    • 3097
    Re: 2011 Panasonic TC-P50S30 IS DEAD
    sorry if I step in, don't mean to break the flow. I was following / reading the exchange as I have / am working on the same set but with flashing codes... am hoping your progress is going good and ultimately successful.
    From my read of your work, I think you need to check the P board further... especially with regards to the "ic701/z701" reference. If I understand the "wired test" that you performed, that wiring actually "steps around" that ic and thus, you can't be sure that it is ok from your test. The test on page 24 seems like the one that tests that IC. Further, your question about VCC never appears to get answered. Basically you need to check the ic to see if the standby voltage shows up somewhere on the pins of that IC as shown in slide 24. You need that voltage for that IC to operate and cause "good things" there after.
    I checked continuity between the chip and p34... it appears to go from p34 and pins 5 and the last one on that side (pin 16... sorry).
    • notch8
      • Jul 2018
      • 63
      Originally posted by Andrew F. Ali
      The A-Bd sends out the TV-SUB-ON signal to the P-Bd to generate the F15V which causes the relays to 'click' and the 15V goes to the A-Bd. to produce SUB5V, SUB1.8V and SUB1.2V to power various circuits in the A-Bd. So as long as the TV-SUB-ON signal does not go to the P-Bd. the set will be dead. Again this points to an A-Bd. problem and as you said it may be easier to just look for a replacement board rather than try to replce the IC on the A-Bd that generate the TV-SUB-ON signal.
      Thanks for the info. I'm going to ease off for a bit and try some more later. I appreciate all the advice.
      • notch8
        • Jul 2018
        • 63
        Thanks for the good hopes. Google says VCC=voltage@common collector. My personal opinion of Andrews wired test was to basically bypass the A board to test the P board, which I think was successful. I agree, ic701, has to be involved. I'll check for 5vstby on z701. I'm currently double checking the pin out on ic 5000. It needs to have 5vstby going in and 3.3v coming out for the red led on the front as well as other output voltages. SMALL STEPS.
        • notch8
          • Jul 2018
          • 63
          Pin out readings on ic 5000: #30=4.75v, 29=3.1v. All other pins-0v.
          No reading on pin 28, was looking for 1.2 but nothing there. I used the stock
          pin out picture for reference, the pic is bad, fuzzy, hard to read, anyway, not much happening with ic5000.
          Pin out readings on Z701: #s 5, 10, 11, 13,16 all 5v
          #19-4.5v plus clicked both relays(rl101,rl102)
          #23-4.75v
          25-2.6v
          26-4.75v
          27-4.5v
          28-3.6v
          30-5.0v. All other pins -0v.
          All readings were taken with tv plugged in, no power buttons were touched.
          There's a lot going on on ic z701.
          • budwich
            • Jul 2015
            • 3097
            thanks... again sorry, if I have muddied the waters. I am going by the same "troubleshooting guide" you are... and the "flow charts" as posted / included thereof. To me the chart 24 is the basic starting point. IF you can't get past that "flow", then it is unlikely that the rest will follow appropriately.... hence checks in and around that flow need to be "there". Having said that, z701 is pretty "super" and I am not able to truly figure out the datasheets and operation thereof (ie. past my pay grade).
            As an example, an per chart 24, it would appear that some operation from the micro in z701 causes ic5000 to operate. IF I understand your initial tests which you indicate / point at ic5000 failure, my question is are you seeing those two voltages coming from the ic5000 ever in standby? If not, then either the "stimulas" is not there or that chip has an issue generating / switching the voltage as shown.
            Further, if I understand the "wiring test" that you followed (as suggested earlier) and it resulted in some "good things", then to me this points towards the p card and potentially the z701 as the interesting point.
            Still further... I realize that the charts are a "reverse engineering effort" and may NOT be any way near how the actual system works ... :-( As an example, I did not find any "direct connection" from p6 to z701... it likely goes thru some sort of transistor or otherwise. Similarly from p6 to the p34 although the p34 to z701 is there (meter wise).
            • notch8
              • Jul 2018
              • 63
              Hey budwich, you're not muddying anything, I need all the help I can get. My pay grade is the lowest...lol. Chart 24 is important...agreed. The two voltages I got from ic5000 WERE from/during standby. Standby voltage is all I have now. New observations: A1 pin1-3.2v, A1 pin2-2.0v, A1 Pin3-3.2v YEA(as per chart 24). Also as soon as I plug the tv in, ic5000 gets so hot you can't hold your finger tip on it. Unplug tv, it cools as quickly. One after dark observation:with tv plugged in D3050 on Aboard glows red, like a red led. I never saw that in daylight. Ic5000 concerns me getting so hot(possible short to ground,IDK). Closing on an up note. Having 3.2v @ A1 Pin3 is good, it shows me that ic5000 is doing something. SMALL STEPS
              • notch8
                • Jul 2018
                • 63
                Ok sports fans, new news. The relays are now clicking when I plug the tv in...why...I don't know. Maybe they were from the beginning, I'm about half deaf and they aren't very loud anyway or maybe my testing did something, IDK. Anyway, we're going a new direction on the troubleshooting flowchart now, pic included, it looks like a bad Aboard...period. IDK if I'll replace, try to test and repair(way over my head) or just give up on it, like the original owner did. Anyway, thanks to all. SMALL STEPS!
                • notch8
                  • Jul 2018
                  • 63
                  On a side note, the last test was slide 33 from Panasonic manual. It says to momentarily ground P6 pin8. P6 pin8 is marked ground on the board...? I'm asking myself...is this a controlled ground? Answer...NO. It is a constant ground. Then I ask, what's the point of momentarily grounding it if it's constantly grounded anyway? My head hurts....it beats me!
                  • budwich
                    • Jul 2015
                    • 3097
                    sorry but I am not sure I follow this about voltages and "new observations"... please clarify.
                    are you saying when you first started this "testing", you only saw the "5v" standby and nothing else... on the "A card"... and now after doing some testing, you are seeing additional voltages? are they now there or you never checked for them before.
                    Further, I re-read your "wired test". I am not sure that the outcome of that test was totally good... but maybe. You indicate that you measured 12v at points that were suppose to be 15v... maybe ok as the "test load" loaded down the power (I didn't trace thru the test completely). Further, you indicated that you may have shorted a connection. That might be a problem as I am not sure what those points included but it appears that it may have impacted the 15v supply.... hopefully not.
                    some of your further observations don't give me a good feeling about how hot ic5000 gets. It may be bad OR the subtending connection (power to other points) are drawing more power than they should causing IC5000 a problem.
                    lastly... after your "wired test" and now with everything back to "as designed" (ie. things have been removed and the circuits are all plugged in), do you get voltages as identified on slide 25 (assuming you are pressing ON, I think to cause the 15v action)?
                    Also I take back my statement about the "wire test bypassing the z701"... the connection to p6 pin 7 stimulates z701 which then actions the switch of the 15v supply to the tested p6 pins... it does test a bit of z701. I think the wired test does appear to bypass the standby operation of z701.... but if I understand some of your observations, more voltages in standby appear to have shown up (ie. 3.3)
                    Lastly, in your current state, can you confirm that you have no LED showing / lit.
                    just re-read your quoted post about the diode glowing.... that doesn't sound good. You should try and see if you can trace where / what circuitry it involves.
                    • budwich
                      • Jul 2015
                      • 3097
                      ok... the D3050 is just the optical audio output... yep its an LED and will glow... :-) It would appear that the A board has some form of function / powering based on that.
                      • R_J
                        • 9625
                        I think you missread that, it says to momentarily ground pin 8 of A1, which is just bypassing the power switch. [key3]
                        This seems to be refering to the tc-p50sT30 gpf14du chassis. The tc-p50s30, A1 has 6 pins the tc-p50sT30 A1 has 8 pins
                        • notch8
                          • Jul 2018
                          • 63
                          Good call RJ, I confused A1 with P6, you're also right about different model #. I had already figured that out but it's all I had to go by. My A1 has 7 pins...? See pic. Unless I can get more info for my model, I'm at a standstill. I think A-board failure but not going to throw money at it to find out, many thanks.
                          • R_J
                            • 9625
                            What info? do you have the service manual? If not, download it fromhere
                            • notch8
                              • Jul 2018
                              • 63
                              I did a search on IC5000. I remembered about someone else having one that got hot. I found the thread and I realize it's a different model Panasonic than mine. His result was A board replacement. Some pics for reference
                              • notch8
                                • Jul 2018
                                • 63
                                Yes I have it. It doesn't help much, I'm a novice. My ac input is good, my fuses are good, I haven't figured out what NG means yet and I don't know how to check/test the Aboard.
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  #36
                                  Now that you did the self-test with the P-Bd. and the Test lamp came on bright and remained on and all the voltages were produces and the Vda is OK. There is no need to further troubleshoot the P. Bd. Remove the bypass resistors and re-connect the P. Bd to the rest of the TV. Leave the Test lamp in place and try to turn on the TV. If the Test lamp come on and stay on then that is an indication the Main Bd. is OK. Remove the Test lamp and the ac input and measure across the SC Bd. where the P2 connector would go. Do yo have a short??
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    #37
                                    Previously posted: If the Test lamp come on and stay on then that is an indication the Main Bd. is OK.
                                    I forgot to mention the you should, with the Test lamp still connected, measure the voltages on P6 to the Main Bd to verify the Main Bd. is not pulling down the 5V and 15V etc, before testing for a short on the SC Bd.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      #38
                                      Yes I have it. It doesn't help much, I'm a novice. My ac input is good, my fuses are good, I haven't figured out what NG means yet.
                                      NG stands for Not Good. Common abbreviation in Japanese service manuals and schematics.
                                      A working TV? How boring!
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        I think your early observation about the ic5000 is good indicator of a problem on two fronts: first, the "hot" doesn't sound right and two, the missing 1.2v missing doesn't sound right. Both the 3.3 and 1.2 come off the same "stby" voltage input which would suggest that there is a problem with that regulator in the chip... although it could be that the 1.2 is being pulled down by the subtending chip. Without 1.2v, the main processor will not be functioning. Either way, unless you are into chip replacement, it would certainly appear that you at least have an A-board issue.
                                        lastly... are you now seeing the led indicator on the panel light in standby?
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          with power off / disconnected, check pin 28 on ic5000 (ie. 1.2v supply for the micro) for resistance to ground. Mine reads in the >50K ohms. This tells me at least that the supply voltage will see a relatively good load from the main processor. I suspect yours will read badly... :-(
                                          • Rensiee
                                            Panasonic TH-50PX8EA Black screen, only relay clicks
                                            by Rensiee
                                            I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                            I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                            When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                            I have measured the voltage in the VSUS line, which...
                                            06-18-2024, 12:58 PM
                                          • Rav_tangle
                                            MacBook Pro 2011 turns on with keyboard light , screen dead
                                            by Rav_tangle
                                            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                            is this...
                                            05-31-2024, 04:09 PM
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                            11-24-2024, 11:27 AM
                                          • mostachio
                                            Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                            by mostachio
                                            Hi Badcaps,
                                            I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                            TV Details:
                                            Model # - TH-65DX700Z
                                            Symptoms:
                                            The television turns on and displays a picture then makes a clicking sound and turns off.
                                            I haven't opened it up yet but...
                                            09-04-2024, 02:32 AM
