Samsung ue49k6300ak
  • PedroBorges9
    • Jan 2020
    • 8
    #41
    Re: Samsung ue49k6300ak
    What do you suggest then, should I measure the voltages on the PSU?
      1) Nope, the T-CON is getting the 12V for it to run but the switching power supplies on the T-CON are not running. Where did you get the new T-CON board from?
      2) Put all the cables back in place and then check the RESISTANCE at the HVDD, AVDD, .... test point with ref to GND, no power to the TV pf course.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4464
        • Italy - Milan
        #43
        pedro some advices was made but no answer from you, check well the posts, it seems you are lost..
        • PedroBorges9
          • Jan 2020
          • 8
          #44
          1) Got it off of ebay.
          2) Everything connected, TV off, not plugged in, black lead on a screw on the side of the board. The resistance in the 2k ohm range for HAVDD is 1.767, AVDD 1.648, 1.1V .216, 2.5V .590, 3.3V .478, F1 1.903 on both sides, in the 200k range VON up to 105 then down to 95.5, 2M range VSS .546
            "HAVDD is 1.767, AVDD 1.648" At 1767 Ohms and 1648 Ohms, they are not low Ohms to cause the missing HVADD (same as HVIN_12V), which should be 12v for feeding the AVDD Voltage (about 15 ~ 20V) boost converter.
            You need to trac e out the HVADD so see if it goes to the switched MOSFET so you can verify if the switched MOSFET is being turned on or not, see schematic of typical T-CON schematic to use as a guide, the designators of the schematic will not match your board but the operation of the circuit is about the same.
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              #46
              Originally posted by oxonater
              Thanks for the responses, the coloured wires go to the speakers.
              I also am not sure what OD/UD is, is there anyway to test the mainboard.
              Looking through this forum I cannot see anyone else with this issue and where to start pinpointing a problem.
              I have this issue, even 11 years later 😝
              • Ritchie_Uk
                Prawnography
                • Mar 2021
                • 185
                • Uk
                #47
                Hi guys, I just got a tv with the same problem. My HAVDD point does not have any voltage with the tv on, is that normal?
                Any luck
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  #48
                  I am having the same Problemo
                  https://www.badcaps.net/forum/showthread.php?t=98603
                    • 21606
                    Originally posted by Ritchie_Uk
                    So why are you trying to bump this old thread up when you`re already getting help from some experienced members in the other thread .
                    • Ritchie_Uk
                      Prawnography
                      • Mar 2021
                      • 185
                      • Uk
                      #50
                      Why does it matter, when on this thread a schematic was posted when it was said there isn't one available?
                        • 21606
                        It matters because you`re already getting help in the other thread as i said. Do you think @PedroBorges9 will reply,he hasn`t posted anything in over 18 months. You never mentioned a schematic in this thread,but i did see you had posted a request for it in the Desktop PC BIOS & Schematic Requests!forum ,so i moved it to the TV forum.
                        • Ritchie_Uk
                          Prawnography
                          • Mar 2021
                          • 185
                          • Uk
                          #52
                          Ok Thankyou for the kind explanation, instead of telling me what to do ��
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • Asraf Atb
                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                            by Asraf Atb
                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                            01-27-2025, 05:02 PM
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • ygorsan
                            by ygorsan
                            🧩 Problem Summary:
                            • I
                            07-28-2025, 08:34 AM
                          • Lee M.
                            Samsung UN75RU8000FXZA bad main board?
                            by Lee M.
                            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                            11-08-2023, 07:46 PM
