Samsung TV - UE49K6300AK
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Hi People
    I have been given very cheaply an immaculate Samsung TV - UE49K6300AK.
    The only problem is that the.
    1. The Backlight Does Glow
    2. No Audio
    3. No Graphics or Menus on the Screen.
    4. The Remote DOES Respond
    5. THE PSU Voltages seem Ok
    6. The 32V Fuse on the Lower Board is OK
    I am suspecting the Logic board, but what do you people think?
    I would really appreciate it if anybody could Upload a Schematic please, as I have come to a halt, with respect to what to do next.
    I don't want to go Buying Boards, as I am a firm believer that by doing that, as I will start losing money that I will make on the lovely Set.
    The Main PCB is Info
    Hawk_M_FHD_PRO2
    Code: BN41-02534B
    MODEL: BN41-02534
    Date: 2016.02.23
    I would really appreciate it if anybody could Upload a Schematic please, I really can't seem to find one for some reason.
    To be honest, I don't want to go Buying Boards, as I am a firm believer that by doing that, as I will start losing money that I will make on the lovely Set,
    and I want to keep the Environment healthy.
    Thanks in Advance
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Re: Samsung TV - UE49K6300AK
    Photos of the PCB
    • diif
      • Feb 2014
      • 6978
      • England
      If you can't find a schematic or service manual, there probably isn't one. Samsung will replace not repair boards under warranty, so there is no need to release them.
      Record the voltages from connector CNM803.
      No electronic/electrical waste goes in landfill in the UK, except stuff put in the bin at home by ignorant/lazy people.
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        Hi can anybody please helpfully suggest what would cause the Symptoms I have described?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Not sure what could cause the fault but this board on ebay looks a identical match https://www.ebay.co.uk/itm/Samsung-U...xoCoXcQAvD_BwE
          it says offers so you maybe able too get it at a lower price then you could use this board too fault find yours and resell it.
          • tiki66
            • Jul 2016
            • 54
            • Croatia
            If TV responds to RC and turns on backlight, my main suspect would be panel/tcon board, not main board...
            Google says it has a t-con board, you can start by measuring if 12V comes to tcon, then check fuse, then check if any SMD capacitor is shorted...
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              Hey Vince - I have just spoken to Samsung and they got me to Reset the TV.
              This managed to get it to do more, ie on Startup now it makes a Sound.
              But still a Blank screen and No Logo
              Said it might be the screen and I said what with the TV still this year do they suddenly go and I said yes but I don't actually know that it's true what they said
              Thanks for being helpful, and will keep you updated
              Ritchie
              • Ritchie_Uk
                Prawnography
                • Mar 2021
                • 185
                • Uk
                Hi Tiki66 - I will take the board off and put it under the microscope and do some cold checks.
                Thankyou I will keep you updated .
                ps - I reset it by holding the power switch in for 10 seconds and then switching it off like the remote control and that's when the sales on boot up started working but no more Sila black screen
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  Ritchie
                  what tcon board does this set use, if this was my set i would probably try a replacement one in this set too rule it out.
                  • tiki66
                    • Jul 2016
                    • 54
                    • Croatia
                    It's ok to take it off and try it under a microscope but only to test shorts and fuse. If there is a short on smd capacitor while tcon is out and disconnected - probably a tcon fault. If there is not, try connecting it back to tv and see if it then has shorts - sometimes the smd capacitors on source board (panel) have shorts and then as you connect it, it shorts out something on your tcon.
                    Also, see what voltages you get, you need 12V from MBO, and then on tcon you have AVVD, HAVVD and etc.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      if your t con has two ribbon cables going too the lcd panel pcb dissconnect one ribbon cable turn the tv on what do you see on the screen? re connect that ribbon cable and try disconnecting the other cable what do you see on the screen?
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        Hi Tiki and Vince - I have disconnected 1 TCon Cable at a Time and it is the same.
                        There doesn't seem to be any Graphics when I connect it to a Laptop, or when I try and scroll through menus nothing shows up.
                        I will Photograph the TCon in a minute and upload it
                        • Ritchie_Uk
                          Prawnography
                          • Mar 2021
                          • 185
                          • Uk
                          Here
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            Here
                            did you gheck the voltage on both sides of t con fuse (just too the left of lvds cable conector).
                            • lotas
                              • Jan 2016
                              • 4753
                              • Russia
                              Check the voltage at 12v. and the LEDs on the T-con are on.
                              • Ritchie_Uk
                                Prawnography
                                • Mar 2021
                                • 185
                                • Uk
                                Hey Lotas Thankyou
                                I only saw 1 Fuse, but let me check, and will update you know
                                • Ritchie_Uk
                                  Prawnography
                                  • Mar 2021
                                  • 185
                                  • Uk
                                  Lotas, How did you know those were fuses?
                                  Was it from the Photos?
                                  • Ritchie_Uk
                                    Prawnography
                                    • Mar 2021
                                    • 185
                                    • Uk
                                    Lotas sorry to keep posting, but 1 of the LEDS glow with the meter on Diode mode and the other dosnt.
                                    What would that imply please?
                                    Top on Glows
                                    Bottom one dosnt glow
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      only one is a fuse 2 are leds 1 is a capacitor
                                      on the led that does not light swap your multi meter leads around does the led now light?
                                      • Ritchie_Uk
                                        Prawnography
                                        • Mar 2021
                                        • 185
                                        • Uk
                                        Hi Vince
                                        it still dosnt light with the leads swapped around
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
