Vizio VW42L FHDTV10A will not turn on without unplugging and plugging TV back in
    Re: Vizio VW42L FHDTV10A will not turn on without unplugging and plugging TV back in
    Originally posted by ken_taz
    budm, No, I didn't put the marks on there. I bought this TV brand new, so it must've been done at the factory.
    I heated the main board up and the TV turned on and stayed on without any vertical lines. The only thing is now there is no sound at all. The vertical lines and the sound are related I'm sure.
    I tested the output voltages and the regulators while nothing was working, except for the logo and the back light. Everything tested the same as stated in my findings from my original post except that it now has the 5.01v at pin B and 3.35v at pin A. I did notice that when I got the TV running the voltage at pin A varied quite a bit while a video was being played, 1.75v - 3.25v.
    Next thing is to localize the heating area to help narrowing down the area.
    • ken_taz
      • Jun 2018
      • 48
      ce23 ce50 dont look good from here .. if they turn out bad change all same values on that board .
      p.s where do the speakers plug in ? i am failing to see an audio chip .
      Thanks petehall347, yeah the pictures don't show those caps very clearly. They look fine and are not bloated at all in real time.
      I have attached a photo with the audio plug circled in yellow.
      • ken_taz
        • Jun 2018
        • 48
        Thank you budm, I will work on that tomorrow and report my findings.
          • 12206
          • U.S.
          nomoresonys, you are talking about the main board, not the power board correct?
          The main board, which I have pictured below, has a total of approx. 72 caps. on it.
          The power board, in pictures two and three, has quite a few less than the main.
          I agree, it would be a much easier job to have a meter to check these caps. instead of playing the guessing game. Lol
          Ah ok, I see what you mean, I was looking at your first mainboard pic. it didn't show the whole board, that IS a shitload of electro. caps.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Not sure what pin a and b are. Voltages shouldn't be fluctuating
              • 12206
              • U.S.
              #26
              Hmmm, could be a bad voltage regulator.
              • ken_taz
                • Jun 2018
                • 48
                Thanks nomoresonys. I've posted all of the regulator voltages from the main board in my original post. The voltages have remained the same and nobody has said anything about the voltages being off from what they should be.
                  • 12206
                  • U.S.
                  #28
                  Good question, wonder if U16 is correct, nothing on pin 2?
                  • ken_taz
                    • Jun 2018
                    • 48
                    U16 is a 5v output regulator. The 2 pin is ground.
                      Post #1
                      U20
                      )11
                      1084
                      0739AL
                      Pin 1 = .55v
                      Pin 2 = 1.79v
                      Pin 3 = 3.32v
                      U19
                      )11
                      1084
                      0739AL
                      Pin 1 = 1.26v
                      Pin 2 = 2.52v
                      Pin 3 = 5.07v
                      U15
                      )11
                      1084
                      0739AL
                      Pin 1 = 2.09v
                      Pin 2 = 3.35v
                      Pin 3 = 5.07v
                      U22
                      AMC1117
                      F0748F
                      Pin 1 = 2.10v
                      Pin 2 = 3.36v
                      Pin 3 = 5.12v
                      U21
                      AMC1117
                      F0748F
                      Pin 1 = .00v
                      Pin 2 = 1.26v
                      Pin 3 = 2.51v
                      U17
                      AMC1117
                      F0748F
                      Pin 1 = 2.10v
                      Pin 2 = 3.37v
                      Pin 3 = 5.07
                      U44
                      J302
                      G9117
                      Pin 1 = 8.46v
                      Pin 2 = 9.72v
                      Pin 3 = 11.42
                      All those readings are correct, you can easily tell by subtract the output pin Voltage reading by the Adj pin reading, the result should be 1.25V +/- 3% (1.213 ~ 1.288V)
                      • ken_taz
                        • Jun 2018
                        • 48
                        Update on the sound not working. My bad, I had the sound cables plugged into the wrong ports for the component input. Sorry, the sound does work when the video is playing. I haven't track down which spot to heat to make the main board work properly yet.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          #32
                          You did say in #19 that you had a varying voltage. Do you still have that?
                          • ken_taz
                            • Jun 2018
                            • 48
                            Yes, pin A on the power board outputs. I think it has something to do with the back light. It is a constant 3.35v with just the power turned on and no video playing. With video playing the voltage varies from around 1.75v to 3.25v depending on the video.
                            When the back light wouldn't come on, I had a very low voltage at pin A .12v and pin B .03v. Pin B is a constant 5.01v regardless of operation when the back light is on.
                              If you look at the pin labels on the INVERTER board and trace it back to the power supply board pin A, B, C then you will know what each pin is. VIZIO usually uses Pin 'A' for BL-ON, and pin 'B' for 'DIM', most of the time pin 'C' is not used.
                              The power supply is used junction point for routing the control signal from the main board to the inverter board.
                              • ken_taz
                                • Jun 2018
                                • 48
                                Ok budm. I didn't have much luck tracking down the area that needed to be heated yesterday. I heated a smaller area than the day before to start narrowing it down. The TV started up fine after the first heating, but I still wanted to narrow it down to a smaller area. I could not get the TV to malfunction again all day after letting it sit for hours at a time. It was a pretty warm day and I'm working in my garage without air conditioning, so I'm guessing that had something to do with it.
                                I went out first thing this morning while it was still cool out. Plugged the TV in and hit the power button. The logo turned white, the back light came on, but nothing else happened. The TV then shut off. I hit the power button again. Same thing, logo turned white, back light came on, only this time it did not shut off. It wouldn't shut off with the power button so I unplugged it to turn it off. I then placed a piece of cardboard along the line in the picture below, and lightly heated the corner of the board. I hit the power button and the TV came on normally, but shut off after like 15 seconds of being on. I hit the power button again and it powered on and stayed on this time.
                                As far as the pin "A" pin "B" thing goes, the only description or labels are on the wires which I am having a very hard time reading. I'm not real concerned with this right now. Thank you for your input on that issue.
                                  You have 3 lytic caps in that section, try replacing them.
                                  BTW, can we see the pictures of the whole back side of the TV showing how all the boards are connected together? I cannot tell what that white connector go to what board.
                                  • ken_taz
                                    • Jun 2018
                                    • 48
                                    Ok budm, no problem. It goes to the manual control panel. I will work on replacing those caps. Thank you!
                                      BTW, for pin point heating of the lytics cap, sometime I use 25W iron on the top of the suspected cap to heat it up for about 15 ~ 25 seconds then plug in and see if the symptom will go away or not.
                                      • ken_taz
                                        • Jun 2018
                                        • 48
                                        Good idea. I was trying to think of a way to pinpoint it even better without ruining the cap in the process. Hair dryers are a good starting point but when it comes to really heating a tiny area....not so much. Thanks!
                                        • R_J
                                          • 9560
                                          This manual has similar parts in that area, on page 164 are the transistors U43 (page 160) is vga control ic. Looks like your problem could be associated with OPCTRL (4 or 5) lines
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
