LG42LC55 sound from main board
  • andrewblueboy
    • Feb 2017
    • 47
    hi all
    i picked up a tv,but it comes with a problem. it can stay on for 10 -mins to half an hour then can turn off yet sometimes it can be seconds. i ve changed one bulging capacitor.
    ive also notieced the black box on the power supply makes arc sound before it goes off,yet when running ok its quite.
    so what i like to know is the black box the problem ,is it easy to change or am i better off getting another board. anyinfor appricated
    thannkyou
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    Re: LG42LC55 sound from main board
    check the soldering
    • andrewblueboy
      • Feb 2017
      • 47
      check the soldering
      will do thanks
      • andrewblueboy
        • Feb 2017
        • 47
        ive tried the resolder and it seems to be the same so ive takin the black thing off and used a multimeter in diode mode
        1 to 2 nothin
        3 to 4 beep
        5 to 6 beep
        could someone confirm ive done this right or wrong
        oh and i think it might be a transformer
        thankyou
          • 12274
          • U.S.
          Did one of these not long ago, had the samwa caps, you probably should have at least changed all the caps in that area where one was bad, never hurts to go up a little in voltage, keep the same uf, in my case I went up from 1500 to 2200 uf, seems to be working ok.
          • andrewblueboy
            • Feb 2017
            • 47
            hi there i did check caps with my meter all were in there limits . although no harm in changing them as there only pennys. you say up the the volts a little but keep the same uf spec the same, wouldnt the 1500 to 2200 uf be to much.
            ive takin the black box and looks ok but needing advice on this and were to get a replacement if need. thanks for your input
              • 12274
              • U.S.
              the one I went from 1500 to 2200, was surrounded by 2200 uf caps, so I put in a 2200, seems to work ok, not sure if someone maybe put a different one in before I got it or not, will know better after a month or so, I don't expect any issues but you never know.
                • 12274
                • U.S.
                An Indian guy? testing transformers. https://www.youtube.com/watch?v=GW_-ycgJXhg
                • R_J
                  • 9588
                  On your transformer you should measure resistance between, 1 & 2, 3 & 4 , 5 & 6
                  Beeps only mean there is some continuity but every meter beeps at different resistance,
                  So measure the resistance on either the 200Ω or 2000Ω scale
                  recheck 1 & 2
                    So the caps ESR are all OK?
                    • andrewblueboy
                      • Feb 2017
                      • 47
                      very informative video there. going off that i think my transformer my be faulty between 3-4 pins no beeb in diode
                      • andrewblueboy
                        • Feb 2017
                        • 47
                        hi yes i have a meser-100 meter .only just got it and becoming very handy
                        • andrewblueboy
                          • Feb 2017
                          • 47
                          recheck 1 & 2
                          hi there
                          right here goes
                          1-2 27.2
                          3-4 OL
                          5-6 0.5
                          this done on fluke 113 so my ohms is auto
                          thankyou for input
                          • R_J
                            • 9588
                            So the winding between 3 & 4 is open (OL), it should read the same as 1 & 2
                            5&6 is the primary, 1&2 is one secondary and 3&4 is another secondary
                            Check where the wire from the winding connects to the pin it could be broken at the pin, if not the winding is open.
                            On your meter you can push the "range" button to select the resistance range. 600Ω, 6kΩ, 60kΩ
                            In post #4 you said 1&2 were open (nothin)
                            • andrewblueboy
                              • Feb 2017
                              • 47
                              So the winding between 3 & 4 is open, it should read the same as 1 & 2
                              thankyou for that information now im slowly getting a understanding of this. hopefully i could fix the pin if not time to look for another one.
                              • petehall347
                                • Jan 2015
                                • 4439
                                • United Kingdom
                                his transistors are diodes
                                  • 12274
                                  • U.S.
                                  Indeed and his bridge rectifiers are diodes too, lol.
                                  • andrewblueboy
                                    • Feb 2017
                                    • 47
                                    ive found were the wire has snapped near the pin,although not longer enough to solder direct to the pin. so is it possible i could solder a new pieace of wire in to make the connection. if thats possible what could i use to cover the pin from as i had to remove sort of hard glue type stuff which covered the pin .
                                    thankyou
                                    • petehall347
                                      • Jan 2015
                                      • 4439
                                      • United Kingdom
                                      extend it or see if a turn can be removed for more length
                                      • andrewblueboy
                                        • Feb 2017
                                        • 47
                                        tried to unwind the wire to make it longer but it so tightly wrapped also i put meter on the piece off wire and theres no reading at all on that winding. been trying to dismantle but no joy. do you know were i could get a replacement as im having no joy except ebay and thats a complete board.
                                        thanks for infro tho
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
