LG42LC55 sound from main board
  • andrewblueboy
    • Feb 2017
    • 47
    • uk
    Re: LG42LC55 sound from main board
    Still no luck with this. cant seem to find one any were. Can these be taken apart so i could unwind it to make repair. if so how does this come apart. ive tried youtube but cant find the kind i have to dismantle.. Really need some help with this one..
    Thankyou
    • R_J
      • Jun 2012
      • 9625
      They can't be taken apart, if you found where it was broken, try adding another piece of wire to extend it, you said you could not get continuity when checking it but did you scrape away the varnish on the wire before trying to check it? are there any numbers on the transformer?
      • andrewblueboy
        • Feb 2017
        • 47
        • uk
        no i didnt remove the varnish
        number are SLI-002 ANY0714FC
        i give it ago cleaning the wire. theres not much to grab as it so small
        i shall let you know how i get on
        thankyou
        • andrewblueboy
          • Feb 2017
          • 47
          • uk
          think ive done more damadge than good as theres a couple of loose strands come way from that piece of coil
          • andrewblueboy
            • Feb 2017
            • 47
            • uk
            decided to get another board
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              #26
              Good choice.
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • JDC
                by JDC
                ONN 100012588
                Long answer:
                07-15-2022, 07:39 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • mrautom8
                Samsung TV UN75H6350AFXZC main board schematics?
                by mrautom8
                Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                While relay is on, all voltage rails are present and steady (scoped) on main board.
                I love a good logic puzzle but getting lost without any schematics.
                No shorts on ANY capacitor main board.
                Thermal camera shows 3.3V inductor getting warm instantly but...
                10-19-2025, 06:32 PM
