Saving 60" 70" + Display Panels From Cracks...
  • Michale32086
    • Nov 2011
    • 1453
    My initial experience in TV repair taught me that, a backlight (LED-LCD) problem (where the problem is specifically the LEDs or LCDs) was akin to a cracked screen.. Not repairable...
    I subsequently learned that it IS possible to replace bad LED/LCD strips if one is careful..
    Such careful-ness REALLY comes into play in the larger TVs...
    With TVs 50" or less, I can hold my own.. I have about a 80%-90% success rate.... Things get dice'er when I am on a 52" or 55"... Bout 65% success rate.....
    When I hit 60 or above, things usually go sideways... It's 50/50. On those, sometimes I get the bear, sometimes the bear gets me...
    Is there a commercial device/framework that allows (ideally) one person to lift off and move 60" display panels??
    Barring a ready-made commercial device, anyone have any ideas on constructing one??
    I see one of two possibilities..
    Thin slates that slide under the panel...
    Or suction cups that latch onto the top of the panel and lift it off..
    The former has the disadvantage of coming in direct contact with the underside of the panel and maybe causing scratches.. The latter, there is the possibility of losing suction in mid move and the whole thing comes crashing down..
    Anyone have any other ideas for such a device??
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Saving 60" 70" + Display Panels From Cracks...
    If only they would make them so the leds strips were removable from the rear of the panel. Slide the strips out on one or other side. Not a major alteration to set manufacture or cost, but a great help to the repairer.
    • Michale32086
      • Nov 2011
      • 1453
      A-frakin'-men to that!!!
      OTOH, a successful LED/LCD repair job usually nets me a pretty decent repair fee...
      • Michale32086
        • Nov 2011
        • 1453
        I am picturing in my head, a device that uses both suction cups and cross pieces under the display panel..
        Picture an adjustable framework of suction cups that you can stick onto the top of the panel.. Then, from one side, lift up the panel and slide in flat slats covered in cloth to minimize scratching.. Figure 4 or 5 cross slats under the panel should be sufficient to hold the panel securely without any bending or twisting.. Then a bar that runs horizontally atop the whole contraption so that a single person can lift the panel off and place it on a separate work surface...
        That's what I am picturing.. Where is Howard Wolowitz when ya need 'im!!
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          The problem with suction cups appears to be if it puts too much suction on the panel it can leave circles on the display that can be seen when reassembled and running.
          After saying this it's only one person who has reported this problem on the forum.
          • Michale32086
            • Nov 2011
            • 1453
            ACK! That wouldn't be good...
            • gabiz_ro
              • Mar 2011
              • 167
              • Romania
              One big frame with some shaft or spindle
              Some wires,adjustable in lenght,as many as you need,but more I think is better.
              Little suction cup,big ones may crack glass when used.
              Also can be used some vacuum pump (more easy to release when need it)
              Place frame on top of glass panel,attach each suction cup and adjust cable lenght.
              Then spin all shafts using some device and glass panel will be lifted.
              If you adjust wire lenght OK then all glass will be lifted in proper manner,no bending,no crack.
              You may even let it on device,if big enough (and no earthquake or tornado are announced),repair backlight then revese shafts spin and will go down on his place.
              If not clear enough,something like a crane but with multiple points of attach.
              • Michale32086
                • Nov 2011
                • 1453
                That's top of the line thinking!!
                Probably outside of my skill-set, but wow...
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  I lift them of with the plastic outer shell complete
                  I just tape the screen to the plastic shell in a few places . have had no issues
                  I have seen some take of the back with the screen laying down , but thats asking for problems when resembling and not aligning the diffuses
                  I have also gone away from replacing individual leds as they don't seem to last (do it for friends only)
                  I buy complete sets ,that way i can sell for a good price
                  • SLK001
                    • May 2014
                    • 264
                    I remove the big panels by standing the set upright on its side, then tilting it slightly until the panel begins to move forward, then I grab the panel and lean it, upright, against a wall.
                    In the factory, they use a suction cup apparatus to move the panels around and place in the set. They are very pricey. In this post, I discuss a couple of dual suction cup grippers as lifters.
                    • flocko
                      • Nov 2012
                      • 1121
                      (I posted this a long time ago, still works for me every time)I use a sheet of thick brown rapping paper (I have a roll 48" wide) , and slide this under the panel from the end without the tabs, then with a second pair of hands lift away like you would with a person on a blanket.the paper supports the screen and refitting it is just the reverse. I have with help used this for screen sizes up to 70" with no problems. I hope this is of help to you Flocko
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Thanx to all the great replies and ideas..
                          • 12094
                          • U.S.
                          +1, This seems like better method than just grabbing it up from a flat position, a lot less stress on panel.
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Could something like this.....
                            https://www.ebay.com/itm/4-1-2-Doubl...UAAOxy5P9RGrUG
                            ... be used without cracking or damaging the panel??
                            • maxvalutech
                              • 804
                              • australia
                              I see today in a catalogue an 82" set now available - good luck!!!!!
                              • Michale32086
                                • Nov 2011
                                • 1453
                                ACK!!!
                                While I would love to have that one on my wall, I would dread having to change an LED strip!!!
                                • SLK001
                                  • May 2014
                                  • 264
                                  Harbor Freight has these dual suckers. I still don't trust them enough to actually lift a large panel lying flat. The glass is aawwffuull thin on those.
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Yea, I hear ya... I might pick up a pair and see how the work. I have a bunch of 60s and 70s who's screens are already cracked..
                                    I'll let ya know how it pans out..
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      Well, I gotta say... If I had had these nifty doodads, I would not have destroyed at least a dozen TVs....
                                      Ahh well.. Live and learn...
                                      Available at Harbor Freight ($4 for the single orange ones and $8 for the paired red ones)....
                                      The single orange ones work great for the under 50" and under TVs... For the +50", the red ones provide better support and control...
                                      I was kinda wary using the red dual suction ones because they have a real grip to them.. But I tested it and it didn't mess with the integrity of the panel..
                                      All that's left is some suction marks that wipe right off..
                                      So, these handy doodads look like the answer to my prayers...
                                      Hopefully, the thickness of the panels is constant..
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        I think a mixture of two methods may well work best.
                                        Use suction cups to initially lift the panel to give sufficient clearance for flocko's method of sliding the thick brown paper underneath. Then the suction cups could be released minimising the time the vacuum cups are attached to the panel avoiding the possibility of damaging it due to much pressure possibly created by the suction cups.
                                        • eccerr0r
                                          Sell or Shim Solar panels?
                                          by eccerr0r
                                          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                                          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                                          So now what to do with these small panels?
                                          I could sell them...
                                          Or I could shim them....
                                          03-29-2025, 01:07 AM
                                          Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPANISH MEXICO HDWR COMMERCIAL PLAT boardview and SPANISH MEXICO HDWR COMMERCIAL PLAT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 12:40 AM
                                        • TrueSword88
                                          KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
                                          by TrueSword88
                                          Hi All
                                          I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
                                          I've reset the unit to factory default & rerun the initial setup but no change.
                                          IF I choose any other mode, example: Standard, flickering disappears.
                                          I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
                                          I've taken the unit apart,...
                                          05-05-2023, 06:07 PM
                                        • jason123
                                          Epic failure of the screen suction holders
                                          by jason123
                                          Just sharing a failure of the suction cups used for screen removal. I don't know if these require special maintenance, but they came with no literature.
                                          Today i was repairing a Vizio E70-E3 (70" 4k TV) with bad backlight. One of the suction cups failed and the panel hit the ground and shattered. I got these from SJ so they're supposed to be decent quality.
                                          Anything you guys do to maintain the rubber on these? I wipe them with damp rag before use, then wipe dry. Any hints / tips?
                                          10-06-2022, 02:39 PM
                                        • NolesFan
                                          Can LED panels be used from different TV's ( or the internals to the panel )?
                                          by NolesFan
                                          I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
                                          06-23-2025, 09:19 AM
