Saving 60" 70" + Display Panels From Cracks...
  • Michale32086
    • Nov 2011
    • 1453
    Re: Saving 60" 70" + Display Panels From Cracks...
    Unfortunately, that almost requires 2 persons for the larger panels 60"+
    The biggest issue I had before was stretching my arms wide enough to delicately lift a panel that is 55" wide or more..
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      A two person job was what I had in mind once you get to these larger sets.
      Perhaps the better solution when single handed may be the tilt method but although I could see the panel being removed from the frame I'm unsure how easy it would be to place it back into the frame.
      Even with the suction cups you would have to be very careful that you lifted the panel without stressing should you lift one end slightly higher than the other, although you could use a piece of timber or such like to span between the two suction cups and lift on that.
      • eccerr0r
        Sell or Shim Solar panels?
        by eccerr0r
        Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
        However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
        So now what to do with these small panels?
        I could sell them...
        Or I could shim them....
        03-29-2025, 01:07 AM
        Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook Specification for Upgrade or Repair
        This specification for the Microsoft SPANISH MEXICO HDWR COMMERCIAL PLAT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPANISH MEXICO HDWR COMMERCIAL PLAT boardview and SPANISH MEXICO HDWR COMMERCIAL PLAT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
        09-07-2024, 12:40 AM
      • marillo
        Circular marks left on TV screen after using suction cups
        by marillo
        I’ve got a bit of an issue with my TV. I used suction cups to handle the panel while waiting for new backlights to arrive, and they ended up staying on the screen for a few days. Now that I’ve removed them, I can see two large circular marks where the cups were.
        The screen wasn’t powered on during that time, but the circles are still clearly visible when the TV is off (and I think slightly visible even when it’s on).
        Any tips for fixing it would be greatly appreciated. Cleaning doesnt help. I guess it s pressure damage and not reversible...
        Today, 02:38 PM
      • TrueSword88
        KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
        by TrueSword88
        Hi All
        I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
        I've reset the unit to factory default & rerun the initial setup but no change.
        IF I choose any other mode, example: Standard, flickering disappears.
        I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
        I've taken the unit apart,...
        05-05-2023, 06:07 PM
      • jason123
        Epic failure of the screen suction holders
        by jason123
        Just sharing a failure of the suction cups used for screen removal. I don't know if these require special maintenance, but they came with no literature.
        Today i was repairing a Vizio E70-E3 (70" 4k TV) with bad backlight. One of the suction cups failed and the panel hit the ground and shattered. I got these from SJ so they're supposed to be decent quality.
        Anything you guys do to maintain the rubber on these? I wipe them with damp rag before use, then wipe dry. Any hints / tips?
        10-06-2022, 02:39 PM
