Samsung UN60H6203AF LED TV Screen Won't Turn On
    Re: Samsung UN60H6203AF LED TV Screen Won't Turn On
    The readings are not correct.
    The exposed pins that you can see from the Top side of the board are the ODD number pin, the EVEN number pins you will have to probe from the back side of the connector using thin probe.
    There is pins assignment chart printed on the board for those 10 pins, so you should have 10 pin names and Voltage for each pin except for the GND pins.
    So according to the chart:
    Pin1 A13V = ???V
    Pin3 A13V = ???V
    Pin5 A13V = ???V
    Pin7 A13V = ???V
    Pin9 GND
    Pin 2 UD = ???V
    Pin 4 PWM_BLU = ???V
    Pin 6 PS_ON = ???V
    Pin 8 GND
    Pin 10 GND
    • vergezee
      • Apr 2018
      • 14
      Pin1 A13V = ???V
      Pin3 A13V = ???V
      Pin5 A13V = ???V
      Pin7 A13V = ???V
      Pin9 GND
      Pin 2 UD = ???V
      Pin 6 PS_ON = ???V
      Pin 8 GND
      Pin 10 GND
      Ok thanks for clearing that up. I was a little confused from the diagram. I'll check it out tonight after work.
      • vergezee
        • Apr 2018
        • 14
        Does this look correct?
        Pin1 A13V = 18V
        Pin3 A13V = 18V
        Pin5 A13V = 19V
        Pin7 A13V = 18V
        Pin9 GND
        Pin 2 UD = 4V
        Pin 4 PWM_BLU = 4V
        Pin 6 PS_ON = 4V
        Pin 8 GND
        Pin 10 GND
        • vergezee
          • Apr 2018
          • 14
          Does anyone know what the proper voltage readings should be?
          • CapLeaker
            Leaking Member
            • 7976
            I think there is something wrong with your meter. Check the battery on it.
              The meter may have low batteries Voltage but the reported Voltage readings indicate the needed Voltage and control Voltages are present.
              The Voltage reading in post #10 indicated open circuit in the second string of the LED.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                #27
                +10
                And that is why when the Black lead was on GND and the Red lead on S- the backlights came on.
                • vergezee
                  • Apr 2018
                  • 14
                  The batteries in the multimeter are brand new. How should I proceed?
                  • CapLeaker
                    Leaking Member
                    • 7976
                    Borrow a DMM from a friend? Your meter shows voltages present, but it reads a bit high. The main is sending BLon, so it has to be something with the led string
                    • vergezee
                      • Apr 2018
                      • 14
                      Is there a chance it could be the power supply board?
                        You can buy a replacement power supply board and find out, you can also buy LED tester for about $35.
                        Also see my post 11, 26.
                        • ngth82
                          • Jul 2015
                          • 541
                          OP: how comfortable are you with opening this TV up?
                          In lieu of doing that, i would suggest getting an LED backlight tester. See: http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
                          You can find the same thing on eBay for cheaper - it's probably the best $30-$50 that you can spend on trouble shooting backlight issues.
                          Anyway, once you get it, apply the red probe to the + lead of the backlight wire, and the black probe to the - nead of the backlight wire. Make sure you have it DISCONNECTED from your power board first. Report back when you have had a chance to do so.
                          If the backlights turn on and stay on, then we can say it's potentially a power board problem. If the backlights DON"T turn on at all, or they shut off during testing, then it's an LED strip problem.
                          -Thomas
                          I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
                          • vergezee
                            • Apr 2018
                            • 14
                            Just got back from vacay. I've ordered one off of eBay and will report back the results asap. Thanks everybody!
                            • Bambam33
                              • Aug 2020
                              • 33
                              Originally posted by Andrew F. Ali
                              +10
                              Hi, old thread so hope someone can still help. Same bn44-00775a board on a un60h6203. Original problem was one strip of lights went out so i got the strobing. Replaced the entire set of backlight strings and no lights at all. Forced backlight on mode and still 405v with no lights. I tested the individual leds again and all of them work. I have continuity on the wiring harness and measure 405v at the + of the top string and have voltage at each + on each strip all the way down enough that it should light the strips. Like the thread above, I can measure V from chassis grnd to s+ or s- at the connector pin on the psb and the lights all barely light up. I can also measure V from chassis gnd to the very last - on the very bottom led strip and all leds light very dimly. If unplugged for a whiile, i can plug psb in and all leds shine bright for a few milliseconds, then completely off. Seems like a continuity problem but i can figure out where or what else to try. Any ideas?
                              • Bambam33
                                • Aug 2020
                                • 33
                                By the way, i am jamie from NOLA, sorry for jumping straight in guys.
                                • Bambam33
                                  • Aug 2020
                                  • 33
                                  I just put the multimeter into diode test mode and measured from chassis gnd to that very last - and all leds light up bright to full strngth. Same for the very last +. ???
                                  • Bambam33
                                    • Aug 2020
                                    • 33
                                    Anybody?
                                      So the TV is powered up and turned on, then you set meter in Diode mode and put the probes on the chassis and the - pin of the LED connector, you better check to see if your meter is still OK.
                                      You can only use Voltage mode when testing live circuit, do not use Ohm or Diode mode to test live circuit, you can damage your meter and the board.
                                      What you did is providing the - (Cathode) return to circuit ground through your meter, instead of going through the MOSFET and current sensing resistor to circuit ground.
                                      Show us good clear straight shot pictures of the whole top and bottom side of YOUR power supply board, and also the whole back side of the TV showing all the boards.
                                      • Bambam33
                                        • Aug 2020
                                        • 33
                                        Thank u for the response.
                                        • Bambam33
                                          • Aug 2020
                                          • 33
                                          I tried to get the lighting right on the pocs without reflection. I didnt have the tconn board uncovered.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
                                          • andrestecno
                                            ASUS X201e - The screen does not turn on and remains black
                                            by andrestecno
                                            I'm dealing with an intermittent problem and can't find a solution. Sometimes my notebook starts up and everything works fine. However, after I turn it off and try to turn it on again, the motherboard starts, but the screen stays black. It seems like the notebook freezes and a green LED with a light bulb icon stays on.
                                            If anyone has the service manual or any suggestions on how to fix this issue, I would greatly appreciate it.
                                            Thanks in advance!
                                            07-18-2024, 07:14 PM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
                                            09-06-2024, 11:40 PM
